The nrf24l01+ can disable crc ? Because I want to use my error coding
Thank you
Thank you
Looks like you can disable it, IF you put the device in ShockBurst mode. From the datasheet:
Hi Sigurd,
If I want to disable crc,I will set CONFIG EN_CRC=0 can disable crc?
Thank you
Yes. And you need to disable ESB-mode.
If you are using ESB-mode, then CRC can not be disabled.
