Hi !
I have selected sample https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.2.0/nrf/samples/bluetooth/peripheral_uart/README.html#peripheral-uart
as basis for evaluate USB_CDC_ACM connectivity to app core and USB_CDC_ACM Recovery mode ( app and network core) via MCUBoot bootloader.
I assume SMP server need to be allocated in MCUBoot and App core and Network core can be updated ( without using any copies in flash memory ) by using mcumgr utility.
1.
I hide some definition in environmental variables for operate with simple command line :
west build --build-dir ./build . --pristine --board nrf5340dk_nrf5340_cpuapp -- -DBOARD_ROOT=. -DDTC_OVERLAY_FILE="app.overlay" -DCONF_FILE="prj.conf"
this configuration can be compiled and flashed without any problems. I can see some debug traces from DK board via ACM0 and 1 USB serial ports.
I assume VS and command line build environment is configured properly.
2. Change App core connectivity from serial to USB_CDC_ACM according recommendation
west build --build-dir ./build . --pristine --board nrf5340dk_nrf5340_cpuapp -- -DBOARD_ROOT=. -DDTC_OVERLAY_FILE="usb.overlay" -DCONF_FILE="prj_cdc.conf"
Errors
Loaded configuration '/home/yevgen/ncs/v2.2.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration '/home/yevgen/nsctest/cpuapp/prj_cdc.conf'
warning: BT_SMP (defined at subsys/bluetooth/host/Kconfig:317, subsys/bluetooth/host/Kconfig:317) has direct dependencies (BT_CONN && BT_HCI_HOST && BT_RPC_STACK) || (BT_CONN && BT_HCI_HOST && BT_HCI && BT) with value n, but is currently being y-selected by the following symbols:
- BT_NUS_SECURITY_ENABLED (defined at /home/yevgen/nsctest/cpuapp/Kconfig:23), with value y, direct dependencies y (value: y)
error: Aborting due to Kconfig warnings
CMake Error at /home/yevgen/ncs/v2.2.0/zephyr/cmake/modules/kconfig.cmake:328 (message):
command failed with return code: 1
if I disable BT security, other errors popups
42 | #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
/home/yevgen/ncs/v2.2.0/zephyr/include/zephyr/bluetooth/bluetooth.h:375:30: note: in definition of macro 'BT_DATA'
375 | .data_len = (_data_len), \
../src/main.c:43:33: note: in expansion of macro 'DEVICE_NAME'
43 | #define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
../src/main.c:76:53: note: in expansion of macro 'DEVICE_NAME_LEN'
76 | BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
So it is exists some errors in application ?
3. I have returned to original configuration DCONF_FILE="prj.conf" and try to add MCUBoot configuration to application and configure MCUBoot itself.
e.g add extra lines to prj.conf
# MCUBoot serial
CONFIG_MCUBOOT_SERIAL=y
CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y
# The following configurations are required to support serial recovery of the
# network image
CONFIG_PCD_APP=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
CONFIG_NRF53_RECOVERY_NETWORK_CORE=y
CONFIG_MCUBOOT_INDICATION_LED=y
OR
west build --build-dir ./build . --pristine --board nrf5340dk_nrf5340_cpuapp -- -DBOARD_ROOT=. -DDTC_OVERLAY_FILE="app.overlay" -DCONF_FILE="prj.conf" -DOVERLAY_CONFIG="nrf5340dk_mcuboot_sr_net.conf"
and
Merged configuration '/home/yevgen/nsctest/cpuapp/prj.conf'
warning: BOOT_IMAGE_ACCESS_HOOKS (defined at modules/Kconfig.mcuboot_bootutil:24) was assigned the
value 'y' but got the value 'n'. Check these unsatisfied dependencies: MCUBOOT_BOOTUTIL_LIB (=n).
See docs.zephyrproject.org/.../kconfig.html and/or look up
BOOT_IMAGE_ACCESS_HOOKS in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: FLASH_SIMULATOR (defined at drivers/flash/Kconfig.simulator:6) was assigned the value 'y'
but got the value 'n'. Check these unsatisfied dependencies: DT_HAS_ZEPHYR_SIM_FLASH_ENABLED (=n).
FLASH_SIMULATOR in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: FLASH_SIMULATOR_DOUBLE_WRITES (defined at drivers/flash/Kconfig.simulator:25) was assigned
the value 'y' but got the value 'n'. Check these unsatisfied dependencies: FLASH_SIMULATOR (=n). See
up FLASH_SIMULATOR_DOUBLE_WRITES in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
/home/yevgen/nsctest/cpuapp/prj.conf:53: warning: attempt to assign the value 'y' to the undefined symbol MCUBOOT_SERIAL
/home/yevgen/nsctest/cpuapp/prj.conf:54: warning: attempt to assign the value 'y' to the undefined symbol MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD
/home/yevgen/nsctest/cpuapp/prj.conf:65: warning: attempt to assign the value 'y' to the undefined symbol NRF53_RECOVERY_NETWORK_CORE
/home/yevgen/nsctest/cpuapp/prj.conf:67: warning: attempt to assign the value 'y' to the undefined symbol MCUBOOT_INDICATION_LED
4. Could it be possible to guide me with MCUBoot configuration for this project ?
The next features are expected:
- SMP server located in MCUBoot only
- Serial recovery method is used for update App and Network cores ( no extra copies of firmware in mcu's flash memory or external serial memory )
- USB_CDC_ACM connectivity to MCUBoot
- Enable multiimage build e.g *zip what contains updates for both cores.
5. Also not so clear how to change child network core project for current image. Looks like it is hardcoded somewhere.
Eugene
