Configure Bluetooth: Peripheral UART application, bootloader and etc.
Hi !
I have selected sample https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.2.0/nrf/samples/bluetooth/peripheral_uart/README.html#peripheral-uart
as basis for evaluate USB_CDC_ACM connectivity to app core and USB_CDC_ACM Recovery mode ( app and network core) via MCUBoot bootloader.
I assume SMP server need to be allocated in MCUBoot and App core and Network core can be updated  ( without using any copies in flash memory ) by using mcumgr utility.
1.
I hide some definition in environmental variables for operate with simple command line :
west build --build-dir ./build  . --pristine --board nrf5340dk_nrf5340_cpuapp -- -DBOARD_ROOT=. -DDTC_OVERLAY_FILE="app.overlay" -DCONF_FILE="prj.conf"
this configuration can be compiled and flashed without any problems. I can see some debug traces from DK board via ACM0 and 1 USB serial ports.
I assume VS and command line build environment is configured properly.
2. Change App core connectivity from serial to USB_CDC_ACM according recommendation
west build --build-dir ./build  . --pristine --board nrf5340dk_nrf5340_cpuapp -- -DBOARD_ROOT=. -DDTC_OVERLAY_FILE="usb.overlay" -DCONF_FILE="prj_cdc.conf"
Errors
Loaded configuration '/home/yevgen/ncs/v2.2.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration '/home/yevgen/nsctest/cpuapp/prj_cdc.conf'
warning: BT_SMP (defined at subsys/bluetooth/host/Kconfig:317, subsys/bluetooth/host/Kconfig:317) has direct dependencies (BT_CONN && BT_HCI_HOST && BT_RPC_STACK) || (BT_CONN && BT_HCI_HOST && BT_HCI && BT) with value n, but is currently being y-selected by the following symbols:
- BT_NUS_SECURITY_ENABLED (defined at /home/yevgen/nsctest/cpuapp/Kconfig:23), with value y, direct dependencies y (value: y)
error: Aborting due to Kconfig warnings
CMake Error at /home/yevgen/ncs/v2.2.0/zephyr/cmake/modules/kconfig.cmake:328 (message):
command failed with return code: 1
if I disable BT security, other errors popups
42 | #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
/home/yevgen/ncs/v2.2.0/zephyr/include/zephyr/bluetooth/bluetooth.h:375:30: note: in definition of macro 'BT_DATA'
375 | .data_len = (_data_len), \
../src/main.c:43:33: note: in expansion of macro 'DEVICE_NAME'
43 | #define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
../src/main.c:76:53: note: in expansion of macro 'DEVICE_NAME_LEN'
76 | BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
So it is exists some errors in application ?
3. I have returned to original configuration DCONF_FILE="prj.conf" and try to add MCUBoot configuration to application and configure MCUBoot itself.
e.g add extra lines to prj.conf
# MCUBoot serial
CONFIG_MCUBOOT_SERIAL=y
CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y
# The following configurations are required to support serial recovery of the
# network image
CONFIG_PCD_APP=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
CONFIG_NRF53_RECOVERY_NETWORK_CORE=y
CONFIG_MCUBOOT_INDICATION_LED=y
OR
west build --build-dir ./build . --pristine --board nrf5340dk_nrf5340_cpuapp -- -DBOARD_ROOT=. -DDTC_OVERLAY_FILE="app.overlay" -DCONF_FILE="prj.conf" -DOVERLAY_CONFIG="nrf5340dk_mcuboot_sr_net.conf"
and
Merged configuration '/home/yevgen/nsctest/cpuapp/prj.conf'
warning: BOOT_IMAGE_ACCESS_HOOKS (defined at modules/Kconfig.mcuboot_bootutil:24) was assigned the
value 'y' but got the value 'n'. Check these unsatisfied dependencies: MCUBOOT_BOOTUTIL_LIB (=n).
See docs.zephyrproject.org/.../kconfig.html and/or look up
BOOT_IMAGE_ACCESS_HOOKS in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: FLASH_SIMULATOR (defined at drivers/flash/Kconfig.simulator:6) was assigned the value 'y'
but got the value 'n'. Check these unsatisfied dependencies: DT_HAS_ZEPHYR_SIM_FLASH_ENABLED (=n).
FLASH_SIMULATOR in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: FLASH_SIMULATOR_DOUBLE_WRITES (defined at drivers/flash/Kconfig.simulator:25) was assigned
the value 'y' but got the value 'n'. Check these unsatisfied dependencies: FLASH_SIMULATOR (=n). See
up FLASH_SIMULATOR_DOUBLE_WRITES in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
/home/yevgen/nsctest/cpuapp/prj.conf:53: warning: attempt to assign the value 'y' to the undefined symbol MCUBOOT_SERIAL
/home/yevgen/nsctest/cpuapp/prj.conf:54: warning: attempt to assign the value 'y' to the undefined symbol MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD
/home/yevgen/nsctest/cpuapp/prj.conf:65: warning: attempt to assign the value 'y' to the undefined symbol NRF53_RECOVERY_NETWORK_CORE
/home/yevgen/nsctest/cpuapp/prj.conf:67: warning: attempt to assign the value 'y' to the undefined symbol MCUBOOT_INDICATION_LED
4. Could it be possible to guide me with MCUBoot configuration for this project ?
The next features are expected:
- SMP server located in MCUBoot only
- Serial recovery method is used for update App and Network cores ( no extra copies of firmware in mcu's flash memory or external serial memory )
- USB_CDC_ACM connectivity to MCUBoot
- Enable multiimage build e.g *zip what contains updates for both cores.
5. Also not so clear how to change child network core project for current image. Looks like it is hardcoded somewhere.
Eugene
  • Hi !
    Can it be some RAM partition ?
    I can see these lines in generated .config
    CONFIG_NRF53_MCUBOOT_PRIMARY_1_RAM_FLASH=y
    CONFIG_NRF53_RAM_FLASH_SIZE=0x40000
    And writing to it translated to network flash ?
    Eugene
  • From partition_manager_report:
      ram_flash (0x40000 - 256kB):
    | 0x0: mcuboot_primary_1 (0x40000 - 256kB) |
    | 0x40000: ram_flash (0x0 - 0B)            |
      sram_primary (0x80000 - 512kB):
    | 0x20000000: pcd_sram (0x2000 - 8kB)           |
    | 0x20002000: sram_primary (0x6e000 - 440kB)    |
    | 0x20070000: rpmsg_nrf53_sram (0x10000 - 64kB) |
    As you see, mcuboot_primary_1 is inside ram_flash.
    I think that the image is written to mcuboot_primary_1, and then PCD is used to transfer the image to the network core via pcd_sram.
    Sigurd Hellesvik
  • Hi !
    But it is not visible any delay like flash whole network image from SRAM to flash,
    Can flashing be done block by block ? Or due SHA calculations, it is loaded to SRAM as first step.
    Just to understand at what point image verification done in case of app and network images in case of recovery flashing.
    Image can be flashed but not boot or if it not pass verification , it is not even flashing.
    Eugene
