Connecting nRF5340 LE Audio to other LE Audio equipment
I'm trying to connect the nRF5340 LE Audio example to another LE Audio equipment: VOCE by Nexum (https://www.nexum-design.com/
I asked Nexum if this was possible and got this reply:
Hi, This is totally ok if you set VOCE as Auracast TX mode. but please note, the standard sample rate of Auracast is 24K sample rate. And VOCE now is set by 48Kh. We will upgrade our VOCE to support 16 / 24Khz by next upgrade. now, you need to make sure nRF5340 as Auracast RX device can also support 16bit/48K sample rate. BR, NEXUM
I also opened a ticket on DevZone earlier but thought this got a little off topic,
 Building nRF5340_audio example for nRF5340-DK (not NRF5340-AUDIO-DK)
I was able to build the example and connect two nRF5340-Audio-DK kits.
Do you have any advice for how to attack this?
I'm currently trying out different config parameters in addition to adding LOG_INF(...) to see if nRF5340 sees the VOCE device. But i have't got any closer..
Thanks in advance for any reply on this,
Best,
Håkon
  • Hi Håkon,
    Could you provide more information about your setup?
    What would be the roles of nRF5340 and VOCE devices in your case?
    Could you elaborate on your use case?
    Dejan
  • Hi Dejan,
    thanks for your reply,
    I would like VOCE to be connected to a microphone and transmit on a broadcast stream, and then setting up multiple nRF5340 as receivers and connect them to speakers.
    Initially I want to connect the two devices in any way so I can see that they are compatible, then I can use that as a baseline for further development. So if you think switching roles would be easier I can try that first.
    BR,
    Håkon
  • Hi Håkon,
    Our nRF5340 audio in BIS mode supports 16 KHz/24 KHz/48 KHz and it is currently set in compile time. You could consider even replacing VOCE with nRF5340 audio device. This can be done since nRF5340 audio can be set as BIS gateway using microphone as audio source.
    Dejan
  • Hi Dejan,
    Thanks, yes, it would be easier to have nRF5340 on both side, however I want to test the compatibility of Auracast, and the VOCE is already a small portable device easily attached to the person using the microphone.
    Could you provide me with the configurations that might affect the connection of the two devices?
    Is it somewhere in the code that i can print out BLE devices that the nRF5340 sees?
    I think this case would be off interest to a lot of people, since Auracast products mostly will be connected to other vendors equipment.
    Have you at Nordic connected a nRF5340 in BIS mode to any other equipment before?
    Håkon
  • Hi Håkon,
    You could start by looking at nrf5340_audio/src/bluetooth/Kconfig and Kconfig.defaults.
    When using nRF5340 as a receiver of audio broadcast, it is le_audio_bis_headset.c that is going to be used. Printing of devices is possible from scan_recv_cb().
    Your local regional sales manager might be able to provide you this information.
    Dejan
