Connecting nRF5340 LE Audio to other LE Audio equipment
I'm trying to connect the nRF5340 LE Audio example to another LE Audio equipment: VOCE by Nexum (https://www.nexum-design.com/
I asked Nexum if this was possible and got this reply:
Hi, This is totally ok if you set VOCE as Auracast TX mode. but please note, the standard sample rate of Auracast is 24K sample rate. And VOCE now is set by 48Kh. We will upgrade our VOCE to support 16 / 24Khz by next upgrade. now, you need to make sure nRF5340 as Auracast RX device can also support 16bit/48K sample rate. BR, NEXUM
I also opened a ticket on DevZone earlier but thought this got a little off topic,
 Building nRF5340_audio example for nRF5340-DK (not NRF5340-AUDIO-DK)
I was able to build the example and connect two nRF5340-Audio-DK kits.
Do you have any advice for how to attack this?
I'm currently trying out different config parameters in addition to adding LOG_INF(...) to see if nRF5340 sees the VOCE device. But i have't got any closer..
Thanks in advance for any reply on this,
Best,
Håkon
  • Hi Håkon,
    Which audio controller do you use?
    Do you have sniffer trace of the communication between the devices?
    I think you have missed several of my previous questions.
    dejans said:
    hakved_vea said:
    so that is selected both indexes BIT(1) and BIT(2). This is what ISO Receive had in the sync parameters.
    Could you specify these sync parameters in ISO Receive?
    hakved_vea said:
    Then I was able to get the audio stream from VOCE to play on nRF5340, however the sound is disturbed.
    Could you provide more information about the sound? How is it disturbed?
    dejans said:
    Could you show the current folder structure of your project which is programmed on nRF5340 audio DK?
    dejans said:
    How did you build and flash your application?
    dejans said:
    hakved_vea said:
    When listening to songs I can recognize the song playing, however it sounds broken.
    How did you verify that the sound is broken? How does it sound broken?
    dejans said:
    hakved_vea said:
    I see that from the terminal printout that:
    nRF5340 have define Channel allocation: 0x1
    while VOCE sets Channel allocation: 0x0
    What implications does this have?
    Could you show the terminal output?
    Dejan
  • Hi Dejan,
    not sure if I understood the question, I'm using the nRF5340-Audio-DK with I2S and onchip hw codec, and the LC3 software.
    I do not have a sniffer, only using the nRF5340 to debug the incoming data, and trace trough the parsing functions.
    ISO Receive is coded with both BIT(0) and BIT(1), however i can change it in the code to only select one of the streams. The same crash happens when selecting only BIT(1) and trying to sync with VOCE. however, both settings work nRF5340 to nRF5340.
    it is hard to explain. It sounds like there is a lot of noise and the actual audio is played in the background, the audio is also distorted, like it is passed trough a bad mixer. The debug printout gives warnings of duplicated audio package and troughs every second frame.
     This was answered in my previous post.
    I have provided you with this in previous posts:
    Difference between nRF5340 and VOCE
    VOCE:
      BIG INFO[0]:
        [DEVICE]: 54:B7:E5:B3:75:7A (public)
        sid 0x08                  *!* Advertiser SID
        num_bis 2                     Number of BISes in the BIG
        nse 8                     *!* Maximum number of subevents in each isochronous event
        interval 0x0010 (20 ms)   *!* Interval between two BIG anchor point (N * 1.25 ms)
        bn 2                      *!* The number of new payloads in each BIS event
        pto 0                         Offset used for pre-transmissions
        irc 4                     *!* The number of times a payload is transmitted in a BIS event
        max_pdu 100                   Maximum size, in octets, of the payload
        sdu_interval 10000 us         The interval, in microseconds, of periodic SDUs.
        max_sdu 100                   Maximum size of an SDU, in octets.
        phy LE 2M                     Channel PHY
        without framing               Channel framing mode
        not encrypted                 Whether or not the BIG is encrypted
      PER_ADV_SYNC[0]:
        [DEVICE]: 54:B7:E5:B3:75:40 (public)
        tx_power 0
        RSSI -41
        CTE 0
        data length 42
        data: 29 16 51 18 00 00 00 01 02 06 00 00 00 00 0a 02 01 08 02 02 01 03 04 64 00 00 01 06 05 03 01 00 00 00 02 06 05 03 02 00 00 00
        16          Service data, 16-bit UUID
        51 18       BT_UUID_BASIC_AUDIO
        00 00 00    QoS Presentation Delay
        01          Number of subgroups in the BASE
        02          Number of BIS in the subgroup
        06          Codec ID
        00 00       Codec Company ID
        00 00       Codec Company Vendor ID
        0a          Codec configuration data length
        02          LTV: length
        01          LTV: type: Sampling_Frequency
        08          LTV: Value: 48000
        02          LTV: length
        02          LTV: type: Frame_Duration
        01          LTV: Value:  Use 10 ms codec frames
        03          LTV: length
        04          LTV: type: Octets_Per_Codec_Frame
        64 00       LTV: Value: 100
        00          codec metadata length
        01          Unique index of the BIS
        06          codec config data length
        05          LTV: length
        03          LTV: type: Audio_Channel_Allocation
        01 00 00 00 LTV: Value: Front Left
        02          Unique index of the BIS
        05          LTV: length
        02 00 00 00 LTV: Value: Front Right
    nRF5340:
      BIG INFO[0]:
        [DEVICE]: 34:F6:FB:BC:69:8C (random)
        sid 0x00                  *!* Advertiser SID
        nse 5                     *!* Maximum number of subevents in each isochronous event
        interval 0x0008 (10 ms)   *!* Interval between two BIG anchor point (N * 1.25 ms)
        bn 1                      *!* The number of new payloads in each BIS event
        irc 5                     *!* The number of times a payload is transmitted in a BIS event
      PER_ADV_SYNC[0]:
        [DEVICE]: 1F:0E:61:A3:79:A3 (random)
        tx_power 0
        RSSI -40
        CTE 0
        data length 40
        data: 27 16 51 18 10 27 00 01 02 06 00 00 00 00 10 02 01 08 02 02 01 05 03 01 00 00 00 03 04 64 00 04 03 02 04 00 01 00 02 00
        10 27 00    QoS Presentation Delay
        06          Codec ID
        10          Codec configuration data length
        02          LTV: length
        08          LTV: Value: 48000 Hz
        02          LTV: length
        05          LTV: length
        03          LTV: length
        04          codec metadata length
        03          LTV: length
        02          LTV: type: Streaming_Audio_Contexts
        04 00       LTV: Value: Bitfield of Context Type values
        00          codec config data length
    *** Booting Zephyr OS build v3.2.99-ncs1 ***
    HL [00:00:00.351,654] [1B][0m<inf> fw_info: [1B][0;32m
    	 nRF5340 Audio nRF5340 Audio DK cpuapp
    	 NCS base version: 2.2.0
    	 Cmake run : Fri Jan 27 13:46:00 2023[1B][0m[1B][0m
    HL [00:00:00.351,654] [1B][0m<inf> fw_info: ------- DEBUG BUILD -------[1B][0m
    HL [00:00:00.351,684] [1B][0m<inf> fw_info: [1B][0;36mHEADSET left device[1B][0m[1B][0m
    HL [00:00:00.362,304] [1B][0m<inf> board_version: [1B][0;32mCompatible board/HW version found: 1.0.0[1B][0m[1B][0m
    HL [00:00:02.407,196] [1B][1;33m<wrn> bt_hci_core: Controller to host flow control not supported[1B][0m
    HL [00:00:02.535,919] [1B][0m<inf> ble: MAC: EB:37:46:99:6E:86 (random)[1B][0m
    HL [00:00:02.536,132] [1B][0m<inf> ble: Controller version: 3310[1B][0m
    HL [00:00:02.630,828] [1B][0m<inf> bis_headset: Scanning for broadcast sources[1B][0m
    HL [00:00:02.640,167] [1B][0m<inf> bis_headset: Broadcast source ªªªªªªªªªªªª[1D] found[1B][0m
    HL [00:00:02.847,717] [1B][0m<inf> bis_headset: Codec config for LC3:[1B][0m
    HL [00:00:02.847,747] [1B][0m<inf> bis_headset: 	Frequency: 48000 Hz[1B][0m
    HL [00:00:02.847,747] [1B][0m<inf> bis_headset: 	Frame Duration: 10000 us[1B][0m
    HL [00:00:02.847,747] [1B][0m<inf> bis_headset: 	Octets per frame: 100 (80000 kbps)[1B][0m
    HL [00:00:02.847,778] [1B][0m<inf> bis_headset: 	Frames per SDU: 1[1B][0m
    HL [00:00:02.847,778] [1B][0m<inf> bis_headset: 	Channel allocation: 0x0[1B][0m
    HL [00:00:02.847,778] [1B][0m<inf> bis_headset: Codec config for LC3:[1B][0m
    HL [00:00:02.847,808] [1B][0m<inf> bis_headset: 	Frequency: 48000 Hz[1B][0m
    HL [00:00:02.847,808] [1B][0m<inf> bis_headset: 	Frame Duration: 10000 us[1B][0m
    HL [00:00:02.847,808] [1B][0m<inf> bis_headset: 	Octets per frame: 100 (80000 kbps)[1B][0m
    HL [00:00:02.847,808] [1B][0m<inf> bis_headset: 	Frames per SDU: 1[1B][0m
    HL [00:00:02.847,839] [1B][0m<inf> bis_headset: 	Channel allocation: 0x0[1B][0m
    HL [00:00:02.847,930] [1B][0m<inf> bis_headset: Syncing to broadcast stream index 0[1B][0m
    HL [00:00:02.908,233] [1B][0m<inf> bis_headset: Stream index 0 started[1B][0m
    HL [00:00:02.908,477] [1B][0m<inf> bis_headset: Stream index 0 started[1B][0m
    HL [00:00:02.926,269] [1B][1;33m<wrn> audio_datapath: I2S RX overrun. Single msg[1B][0m
    HL [00:00:02.932,281] [1B][0m<inf> audio_datapath: Drft comp state: CALIB[1B][0m
    HL [00:00:02.933,197] [1B][1;33m<wrn> audio_datapath: Duplicate sdu_ref_us (2574616) - Dropping audio frame[1B][0m
    HL [00:00:02.933,227] [1B][1;33m<wrn> audio_datapath: Duplicate sdu_ref_us (2574616) - Dropping audio frame[1B][0m
    HL [00:00:02.933,258] [1B][1;33m<wrn> audio_datapath: Data received, total underruns: 14[1B][0m
    HL [00:00:02.951,599] [1B][0m<inf> audio_datapath: sdu_ref_us not from consecutive frames[1B][0m
    HL [00:00:02.953,155] [1B][1;33m<wrn> audio_datapath: Duplicate sdu_ref_us (2594617) - Dropping audio frame[1B][0m
    [1B][1;31m--- 3 messages dropped ---
    [1B][0mHL [00:00:02.971,588] [1B][0m<inf> audio_datapath: sdu_ref_us not from consecutive frames[1B][0m
    HL [00:00:02.973,175] [1B][1;33m<wrn> audio_datapath: Duplicate sdu_ref_us (2614617) - Dropping audio frame[1B][0m
    [1B][1;31m--- 5 messages dropped ---
    [1B][0mHL [00:00:02.993,194] [1B][1;33m<wrn> audio_datapath: Duplicate sdu_ref_us (2634617) - Dropping audio frame[1B][0m
    [1B][0mHL [00:00:03.013,244] [1B][1;33m<wrn> audio_datapath: Data received, total underruns: 54[1B][0m
    [1B][1;31m--- 1 messages dropped ---
    [1B][0mHL [00:00:03.031,585] [1B][0m<inf> audio_datapath: sdu_ref_us not from consecutive frames[1B][0m
    [1B][1;31m--- 4 messages dropped ---
    [1B][0mHL [00:00:03.033,264] [1B][1;33m<wrn> audio_datapath: Data received, total underruns: 64[1B][0m
    HL [00:00:03.051,605] [1B][0m<inf> audio_datapath: sdu_ref_us not from consecutive frames[1B][0m
    [1B][0mHL [00:00:03.071,594] [1B][0m<inf> audio_datapath: sdu_ref_us not from consecutive frames[1B][0m
    HL [00:00:03.073,150] [1B][1;33m<wrn> audio_datapath: Duplicate sdu_ref_us (2714617) - Dropping audio frame[1B][0m
    Hope this answered your questions,
    Håkon
  • Hi Håkon,
    Could you provide full application log from nRF5340 audio DK?
    Dejan
  • Hi Dejan,
    Do you want full log with DEBUG level enabled?
    CONFIG_BT_LOG_LEVEL_DBG=y
    Håkon
  • Hi Håkon,
    You can use this option.
    Dejan
