GPIOs work in erratic manner after BLE mesh node is provisioned.
I am developing a capactive touch switch based home automation system. I am running Zephyr RTOS on nRF52832. All the hardware works fine till BLE mesh node is priovisioned. All GPIOs work in an erratic manner after node is provisioned. My project configuration file is as follows
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
#CONFIG_NRFX_COMP=y
#CONFIG_ADC=y
CONFIG_PRINTK=y
#CONFIG_MULTITHREADING=y
#CONFIG_TIMESLICING=y
#CONFIG_TIMESLICE_SIZE=10
#CONFIG_TIMESLICE_PRIORITY=0
CONFIG_INIT_STACKS=n
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_CTLR_LE_PING=n
CONFIG_BT_DATA_LEN_UPDATE=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_ADV_EXT=n
CONFIG_BT_CTLR_PRIVACY=n
CONFIG_BT_CTLR_TX_PWR_PLUS_8=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT=y
CONFIG_BT_TINYCRYPT_ECC=y
CONFIG_BT_RX_STACK_SIZE=4096
CONFIG_BT_L2CAP_TX_BUF_COUNT=8
CONFIG_BT_MESH=y
CONFIG_BT_MESH_RELAY=y
CONFIG_BT_MESH_RELAY_RETRANSMIT_COUNT=3
CONFIG_BT_MESH_LOW_POWER=n
CONFIG_BT_MESH_FRIEND=n
CONFIG_BT_MESH_FRIEND_QUEUE_SIZE=16
CONFIG_BT_MESH_ADV_BUF_COUNT=60
CONFIG_BT_MESH_TX_SEG_MAX=6
CONFIG_BT_MESH_TX_SEG_MSG_COUNT=3
CONFIG_BT_MESH_RX_SEG_MSG_COUNT=3
CONFIG_BT_MESH_CRPL=128
CONFIG_BT_MESH_RPL_STORE_TIMEOUT=120
CONFIG_BT_MESH_MSG_CACHE_SIZE=100
CONFIG_BT_MESH_PB_GATT=y
CONFIG_BT_MESH_PB_ADV=y
CONFIG_BT_MESH_GATT_PROXY=y
#CONFIG_BT_MESH_LPN_SCAN_LATENCY=30
#CONFIG_BT_MESH_LPN_RECV_DELAY=40
#CONFIG_BT_MESH_LPN_POLL_TIMEOUT=300
CONFIG_BT_MESH_SUBNET_COUNT=2
CONFIG_BT_MESH_APP_KEY_COUNT=2
CONFIG_BT_MESH_MODEL_GROUP_COUNT=2
CONFIG_BT_MESH_LABEL_COUNT=3
#CONFIG_BT_MESH_IV_UPDATE_TEST=y
#CONFIG_UART_CONSOLE=n
#CONFIG_BT_DEBUG_MONITOR_UART=y
#CONFIG_BT_DEBUG_LOG=y
##CONFIG_BT_MESH_DEBUG=y
#CONFIG_BT_MESH_DEBUG_PROV=y
#CONFIG_BT_MESH_DEBUG_PROXY=y
#CONFIG_BT_MESH_DEBUG_BEACON=y
#CONFIG_BT_MESH_DEBUG_NET=y
#CONFIG_BT_MESH_DEBUG_TRANS=y
#CONFIG_BT_MESH_DEBUG_SETTINGS=y
#CONFIG_BT_MESH_DEBUG_LOW_POWER=y
#CONFIG_BT_MESH_DEBUG_FRIEND=y
#CONFIG_BT_MESH_DEBUG_MODEL=y
#CONFIG_BT_MESH_DEBUG_ACCESS=y
#CONFIG_BT_MESH_DEBUG_CRYPTO=y
#CONFIG_BT_MESH_DEBUG_ADV=y
#CONFIG_BT_MESH_SELF_TEST=y
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BT_HCI_TX_STACK_SIZE=1024
#CONFIG_BT_DEBUG_HCI_CORE=y
#CONFIG_BT_DEBUG_HCI_DRIVER=y
I suspect that there is some configuration setting which is missing
  • Can you please zip and send the application that you are using to reproduce this? Why do I need a 220ohm resistor?
    I am certain that the GPIOs doesn't stop working after being provisioned, as we have several samples using the GPIOs after the provisioning. Sure you didn't mix up the LED_ON LED_OFF polarity? Perhaps it turns the LED off? I also see that you return after the LED is set to LED_ON. Where does it return to? Do you configure the LED directly after this, perhaps?
    Just to verify that it is in fact not the provisioning that is breaking this, what if you comment out the line:
     if (false == provisioned) {
    And everything in the "else" bracket, and just try to print a message if the device is provisioned. Something like:
        while (1) {
            //if (false == provisioned) {
                printk("main_thread: provisioning in progress\n");
                if (provisioned) {
                    printk("provisioned here");
                ret = ledonoff(LED7, val); /*turn on/off provisioning LED*/
                k_msleep(SLEEP_TIME_MS);
                val = (val == LED_ON) ? LED_OFF : LED_ON;
                detect_touch();
                for (i = 0; i < 6; i++) {
                    if (true == get_key_status(i)) {
                        clr_key_status(i);
                        toggle_sw_status(i);
                /* k_msleep(SLEEP_TIME_KS); */
            //else {
            //    printk("main:device provisioned\n");
            //    ret = ledonoff(LED7, LED_ON); /*turn on provisioning LED*/
            //    if (FAILURE == ret) {
            //        printk("Failed to turn on LED7");
            //        return;
    Does the LED keep blinking? And does the log say "provisioned here" at some point after it has been provisioned?
    Edvin
  • LED keep blinking and RTT log says it is provisioned. Please check your inbox. I have sent you following
    1. source files
    2. board support files
    3. schematic
  • I didn't receive any files. But this suggests that there is no issue with the GPIOs then, don't you agree? Since on that test, it continued to blink.
    Waiting for updates/application files.
  • I found that the problem is with the sample I used in my project \zephyrproject\zephyr\samples\boards\nrf\mesh\nRF805SensorBLEMesh.
    Another sample \zephyrproject\zephyr\samples\boards\nrf\mesh\onoff_level_lighting_vnd_app code works well. I tested it on nRF52-DK. I used P0.25 to connect an LED and a resister to VDD. The LED turns on after provisioning and turns off after reset. I am attaching the modified sample code.OnOffLevelLightingVndApp.zip
