GPIOs work in erratic manner after BLE mesh node is provisioned.
I am developing a capactive touch switch based home automation system. I am running Zephyr RTOS on nRF52832. All the hardware works fine till BLE mesh node is priovisioned. All GPIOs work in an erratic manner after node is provisioned. My project configuration file is as follows
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
#CONFIG_NRFX_COMP=y
#CONFIG_ADC=y
CONFIG_PRINTK=y
#CONFIG_MULTITHREADING=y
#CONFIG_TIMESLICING=y
#CONFIG_TIMESLICE_SIZE=10
#CONFIG_TIMESLICE_PRIORITY=0
CONFIG_INIT_STACKS=n
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_CTLR_LE_PING=n
CONFIG_BT_DATA_LEN_UPDATE=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_ADV_EXT=n
CONFIG_BT_CTLR_PRIVACY=n
CONFIG_BT_CTLR_TX_PWR_PLUS_8=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT=y
CONFIG_BT_TINYCRYPT_ECC=y
CONFIG_BT_RX_STACK_SIZE=4096
CONFIG_BT_L2CAP_TX_BUF_COUNT=8
CONFIG_BT_MESH=y
CONFIG_BT_MESH_RELAY=y
CONFIG_BT_MESH_RELAY_RETRANSMIT_COUNT=3
CONFIG_BT_MESH_LOW_POWER=n
CONFIG_BT_MESH_FRIEND=n
CONFIG_BT_MESH_FRIEND_QUEUE_SIZE=16
CONFIG_BT_MESH_ADV_BUF_COUNT=60
CONFIG_BT_MESH_TX_SEG_MAX=6
CONFIG_BT_MESH_TX_SEG_MSG_COUNT=3
CONFIG_BT_MESH_RX_SEG_MSG_COUNT=3
CONFIG_BT_MESH_CRPL=128
CONFIG_BT_MESH_RPL_STORE_TIMEOUT=120
CONFIG_BT_MESH_MSG_CACHE_SIZE=100
CONFIG_BT_MESH_PB_GATT=y
CONFIG_BT_MESH_PB_ADV=y
CONFIG_BT_MESH_GATT_PROXY=y
#CONFIG_BT_MESH_LPN_SCAN_LATENCY=30
#CONFIG_BT_MESH_LPN_RECV_DELAY=40
#CONFIG_BT_MESH_LPN_POLL_TIMEOUT=300
CONFIG_BT_MESH_SUBNET_COUNT=2
CONFIG_BT_MESH_APP_KEY_COUNT=2
CONFIG_BT_MESH_MODEL_GROUP_COUNT=2
CONFIG_BT_MESH_LABEL_COUNT=3
#CONFIG_BT_MESH_IV_UPDATE_TEST=y
#CONFIG_UART_CONSOLE=n
#CONFIG_BT_DEBUG_MONITOR_UART=y
#CONFIG_BT_DEBUG_LOG=y
##CONFIG_BT_MESH_DEBUG=y
#CONFIG_BT_MESH_DEBUG_PROV=y
#CONFIG_BT_MESH_DEBUG_PROXY=y
#CONFIG_BT_MESH_DEBUG_BEACON=y
#CONFIG_BT_MESH_DEBUG_NET=y
#CONFIG_BT_MESH_DEBUG_TRANS=y
#CONFIG_BT_MESH_DEBUG_SETTINGS=y
#CONFIG_BT_MESH_DEBUG_LOW_POWER=y
#CONFIG_BT_MESH_DEBUG_FRIEND=y
#CONFIG_BT_MESH_DEBUG_MODEL=y
#CONFIG_BT_MESH_DEBUG_ACCESS=y
#CONFIG_BT_MESH_DEBUG_CRYPTO=y
#CONFIG_BT_MESH_DEBUG_ADV=y
#CONFIG_BT_MESH_SELF_TEST=y
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BT_HCI_TX_STACK_SIZE=1024
#CONFIG_BT_DEBUG_HCI_CORE=y
#CONFIG_BT_DEBUG_HCI_DRIVER=y
I suspect that there is some configuration setting which is missing
    Can you please elaborate a bit? What do you mean by erratic manner? Do they stop responding? What are they supposed to do? Are they inputs or outputs? Do you stop seeing events? Or are you no longer able to set output values?
    BR,
    Edvin
  • e.g. provisioning LED connected to P0.25 stops working. After provisioning it is supposed to turn on continuously as per following code snippet
    static void prov_complete(uint16_t net_idx, uint16_t addr)
        int ret;
        printk("provisioning complete for net_idx 0x%04x addr 0x%04x\n", net_idx, addr);
        primary_addr = addr;
        primary_net_idx = net_idx;
        provisioned = true;
        ret = ledonoff(LED7, LED_ON);
    int ledonoff(int ledno, /*leds - 1 to 6*/
             int onoff  /*1 - off, 0 - on*/
        int ret;
        switch (ledno) {
        case 0:
            ret = gpio_pin_set_dt(&lled0, onoff);
        case 1:
            ret = gpio_pin_set_dt(&lled1, onoff);
        case 2:
            ret = gpio_pin_set_dt(&lled2, onoff);
        case 3:
            ret = gpio_pin_set_dt(&lled3, onoff);
        case 4:
            ret = gpio_pin_set_dt(&lled4, onoff);
        case 5:
            ret = gpio_pin_set_dt(&lled5, onoff);
        case 6:
            ret = gpio_pin_set_dt(&lled6, onoff);
        case 7:
            ret = gpio_pin_set_dt(&lled7, onoff);
            ret = FAILURE;
        return ret;
  • As per PS, Pins 27 to 42v(GPIO P0.22 to P0.30) which are located near the radio should be used for low drive low frequency only. I am using it to drive LEDs.  I guess this could be an issue but why does it work very well till the device node is not provisioned?
  • ok, I can't tell exactly what the issue is based on this snippet. Low drive low frequency should be fine for running LEDs. The limitation is that you shouldn't use it for signals that change very fast, such as PWM or high speed SPI and so on.
    Is it mainly LED7 that is not working? Are you sure that LED7 is properly initialized? I see from your comments that:
    Perhaps you forgot to initialize LED7 after adding it?
    Did you try to add some logging, or to perform a debug session to see what the return value from gpio_pin_set_dt is, and that the switch case is actually reached with the correct ledno?
    If so, is there any way for me to reproduce what you are seeing on a DK?
    There are no known issues that GPIOs are not working properly after the device is provisioned.
    Edvin
  • ledonoff(LED7, LED_ON) does not fail. However LED7 does not turn on after provisioning. I tried it in main() function as well as below
        while (1) {
            if (false == provisioned) {
                printk("main_thread: provisioning in progress\n");
                ret = ledonoff(LED7, val); /*turn on/off provisioning LED*/
                k_msleep(SLEEP_TIME_MS);
                val = (val == LED_ON) ? LED_OFF : LED_ON;
                detect_touch();
                for (i = 0; i < 6; i++) {
                    if (true == get_key_status(i)) {
                        clr_key_status(i);
                        toggle_sw_status(i);
                /* k_msleep(SLEEP_TIME_KS); */
            else {
                printk("main:device provisioned\n");
                ret = ledonoff(LED7, LED_ON); /*turn on provisioning LED*/
                if (FAILURE == ret) {
                    printk("Failed to turn on LED7");
                    return;
    I am able to reset the node and LED7 starts blinking after reset. I would suggest you reproduce this problem in nRf52-DK with LED and 220ohm resistor connected on P0.25. Please try with BLE mesh generic on/off server sample
