During some test I saved a couple of session data files in the PPK2 tool v3.5.3
After trying opening it, I get the following error:
Hey Jos,
Yes, the fix should be mentioned in the Power Profiler apps changelog on GitHub: https://github.com/NordicSemiconductor/pc-nrfconnect-ppk/blob/main/Changelog.md
Simon
I have the same issue with opening files. I've also tried open them on Linux and iOS.
I get the following error message: "The file: F:\ppk-20230616.ppk requires 2.99880136 gigabytes, but the application you are using is limited to 2.147483647 gigabytes."
The PPK-file size is only 4 megabytes.
Power profiler version v3.5.5
IK
This is because .ppk files are compressed, so when opened they are much larger than the file size indicates. You need to reduce the amount of allocated memory, to something that gives an estimated RAM requirement lower than 1GB. The "estimated RAM requirement" can be seen above the start button in the Power profiler app. We've not yet released a fix for this on Windows I'm afraid. The only way to open this file would be to use the MacOS or Linux version of the Power Profiler app.
Simon
Thank you for quick reply.
I have tried to open on MacOS and Linux already. I wasn't able to open it on either of those.
I've tried to copy the files also, with no luck.
IK
What kind of error(s) are you seeing on the other operating systems? I can ask the devs if there's anything we can do here if you really need to review this specific file, but if possible I'd recommend decreasing the RAM requirement as explained and do a "smaller" sample measurement that is readable.
Simon
