combining sdk_config.h files with CMSIS
I want to combine code that uses both the libuarte library and the spi library.
When I look at the sdk_config.h file of the libuart example with CMSIS, I see this:
When I look at the sdk_config.h file of the SPI example with CMSIS, I see this:
Note that the SPI example has an entire "Application" branch of settings that is not contained in the libuarte example.
You might imagine that the SPI example is a superset of the libuarte example, but that's not the case. There are many settings in the sdk_config.h for the libuarte example that don't exist in the SPI example.
How do I use CMSIS to "drag" the settings I need from one project to another such that I can combine the functionality of the two examples?
