RSA example fails on psa_sign_hash returning -133
I have one problem report and some related questions:
Problem report:
When executing the RSA sampe provided with SDK 2.1.0 on the nRD5340DK board the psa_sign_hash function fails with -133 (PSA_ERROR_NOT_PERMITTED).
The explanation PSA_ERROR_NOT_PERMITTED informs me that a policy is preventing the operation. But as I am using a unmodified sample code. I cannot see which policy change I should have caused. Can you help finding the cause of this behavior?
Questions:
1) I have a requirement to implement RSA OAEP(SHA1) public key encryption using 3072 bit keys. The CryptoCell on the nRF5340 has a upper limit of 2048 bit keys. The question is, how can I implement the required encryption operation? Is using mbed_tsl directly an option or is the 2048 bit key limit also imposed on this API?
2) When attempting to do RSA OAEP(SHA1) using a supposedly supported 2048 bit key, this fails with return code -147 (PSA_ERROR_HARDWARE_FAILURE). There are no sample code performing RSA public key encryption using the CryptoCell, is this operation not supported?
    Checking with our developers, it seems that our PSA Crypto API does not yet support 2048 bit keys.
    Instead, I suggest that you use the mbedtls API directly.
    I think the API you look for is https://github.com/nrfconnect/sdk-mbedtls/blob/main/library/psa_crypto_rsa.h.
    Sigurd Hellesvik
  • Hi Sigurd
    Thanks for your effort!
    Using the mbed_tsl API does works for RSA 3072 bit encryption.
    I think that you should make tickets on the found problems:
     - RSA signing sample included in SDK does not work.
     - PSA cannot be used for RSA encryption (I could not make it work even for 1024 bit keys)
    I have added my mbed_tsl code for other with similar problems:
    // Output size must be == keysize == keysizeBits / 8
    bool mbedTslTest(const uint8_t *input, size_t input_len, uint8_t *output) {
      mbedtls_rsa_context rsa;
      /* Initialize RSA Context */
      mbedtls_rsa_init(&rsa);
      int ret = mbedtls_rsa_set_padding(&rsa, MBEDTLS_RSA_PKCS_V21, MBEDTLS_MD_SHA1);
      if (ret) {
        LOG_INF("failed! to confuigure padding: -%04x", -ret);
        return (ret);
      ret = mbedtls_rsa_import_raw(&rsa,
                                   &RSA_N_3072[0], sizeof(RSA_N_3072),
                                   NULL, 0,
                                   NULL, 0,
                                   NULL, 0,
                                   &RSA_E_3072[0], sizeof(RSA_E_3072));
      if (ret) {
        LOG_INF("failed! mbedtls_rsa_import_raw: -%04x", -ret);
        return (ret);
      ret = mbedtls_rsa_complete(&rsa);
      if (ret) {
        LOG_INF("failed! mbedtls_rsa_complete: -%04x", -ret);
        return (ret);
      ret = mbedtls_rsa_rsaes_oaep_encrypt(&rsa, mbedtls_random, NULL, NULL, 0, input_len, input, output);
      if (ret) {
        LOG_INF("failed! mbedtls_rsa_rsaes_oaep_encrypt: -%04x", -ret);
        return false;
      LOG_INF("Success");
      return true;
    PSA can be use as RNG:
    int mbedtls_random( void *p_rng, unsigned char *output,
                                 size_t outputLen ){
      psa_status_t status = psa_generate_random(output, outputLen);
      if (status != PSA_SUCCESS) {
        LOG_ERR("psa_generate_random failed! (Error: %d)", outputLen);
        return -1;
      return 0;
    Regards Tonny
  • Tony,
    I ran into PSA_ERROR_NOT_SUPPORT (-134)  error when trying to use RSA decryption with a 2048 bit key.  I traced down the error to the mbedtls_psa_rsa_export_key() function being conditionally compiled to a hard coded failure.  I added the following statements to my prj.conf file and now I am working.  Caveat: I am using an older version of the SDK (v1.7) - so YMMV.
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_PK_WRITE_C=y
  • Hi John
    Thanks for the information!
    I think you are correct that a lot might have changed in the SDK around PSA (and mbed_tsl integration).
    Fortunately I was able to use the mbed_tsl API directly, but spend quite some time realizing that.
    In SDK 2.1.1 the unmodified "RSA" sample that uses PSA does not work (even on the nRF5340DK board). So I will stick with the mbed_tsl API for now.
  • Hi Sigurd,
    does the PSA Crypto api support 2048 bit RSA OEAP operation, from SDK 2.7.0 upwards ?
    Thanks in advance !
    Kind regards
    Riccardo
