zephyr rtos and some other question on ble:
I Have a peripheral over ble I have to question?
When the peripherl send a message ,(send a Notify  over ble) is possible to know  when the device  receive the Layer2  ACK ?
In this way I can make a mesure of the time I need for the transmittion  with the number of the L2 Repeatition ?
Is possible for  a peripheral to be connected from with a Central only if a central have a Particular "Name" ? So I can accept e/o filter the connection ?
 Thank And Best Regards
Novello G.
  • When the peripherl send a message ,(send a Notify  over ble) is possible to know  when the device  receive the Layer2  ACK ?
    The answer depends a bit on how low level you want to go, but from the documentation you can find for instance:
    Attribute value changes can be notified using bt_gatt_notify() API, alternatively there is bt_gatt_notify_cb() where is is possible to pass a callback to be called when it is necessary to know the exact instant when the data has been transmitted over the air.
    The peripheral can not do filtering on cental device name, the reason thsi is not possible is that there is no information in the packets (scan request and/or connect request) from the central that may provide information about the name of the central device.
    Kenneth
