mqtt_simple sample gets error -2 in getaddrinfo
We have developed our own module based on the nrf9160 DK and want to use it to send data to a MQTT broker. A few days ago on the dev-kit everything worked fine, now the new PCBs have arrived and we get this error in the mqtt_simple sample (as well as in our own code, but in a little different format):
 *** Booting Zephyr OS build v3.2.99-ncs1 ***
[00:00:00.504,638] <inf> mqtt_simple: The MQTT simple sample started
[00:00:00.504,699] <inf> mqtt_simple: Disabling PSM and eDRX
[00:00:00.505,401] <inf> mqtt_simple: LTE Link Connecting...
[00:00:09.277,618] <inf> mqtt_simple: LTE Link Connected!
[00:00:09.277,862] <err> mqtt_simple: getaddrinfo failed: -2
[00:00:09.277,893] <err> mqtt_simple: Failed to initialize broker connection
[00:00:09.277,893] <err> mqtt_simple: client_init: -10
We just added the following config lines to use NB-IoT in the sample:
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_LTE_MODE_PREFERENCE_NBIOT=y
When using the IP address of the moquitto test server, it works perfectly fine.
[00:00:00.568,603] <inf> mqtt_simple: The MQTT simple sample started
[00:00:00.568,664] <inf> mqtt_simple: Disabling PSM and eDRX
[00:00:00.569,366] <inf> mqtt_simple: LTE Link Connecting...
[00:00:11.186,523] <inf> mqtt_simple: LTE Link Connected!
[00:00:11.186,950] <inf> mqtt_simple: IPv4 Address found 91.121.93.94
[00:00:11.187,438] <dbg> mqtt_simple: client_id_get: client_id = nrf-2EB11F7FD373E99C
[00:00:11.598,114] <inf> mqtt_simple: MQTT client connected
[00:00:11.598,144] <inf> mqtt_simple: Subscribing to: my/subscribe/topic len 22
[00:00:11.746,185] <inf> mqtt_simple: SUBACK packet id: 1234
[00:06:48.615,112] <inf> mqtt_simple: MQTT PUBLISH result=0 len=15
[00:06:48.615,203] <inf> mqtt_simple: Received: test with ip address
[00:06:48.615,783] <inf> mqtt_simple: Publishing: test with ip address
[00:06:48.615,814] <inf> mqtt_simple: to topic: my/publish/topic len: 20
[00:06:48.761,352] <inf> mqtt_simple: PUBACK packet id: 39802
Has anybody an idea?
We are using the NCS v2.2.0 with the toolchain 2.2.0 (but tried the 2.1.0 as well, as we used with the dev-kit), modem firmware is 1.2.3
Edit: I forgot to add: when using the same code on the dev-kit, it works also fine with the IP Address and the URL. Modem firmware is here also 1.2.3 - thats the reason we choose 1.2.3 instead of 1.3.3. We also use the same SIM card to prevent any errors from the provider side (bad DNS, APN, whatever...)
Thank you!
BR Thomas
