mqtt_simple sample gets error -2 in getaddrinfo
We have developed our own module based on the nrf9160 DK and want to use it to send data to a MQTT broker. A few days ago on the dev-kit everything worked fine, now the new PCBs have arrived and we get this error in the mqtt_simple sample (as well as in our own code, but in a little different format):
 *** Booting Zephyr OS build v3.2.99-ncs1 ***
[00:00:00.504,638] <inf> mqtt_simple: The MQTT simple sample started
[00:00:00.504,699] <inf> mqtt_simple: Disabling PSM and eDRX
[00:00:00.505,401] <inf> mqtt_simple: LTE Link Connecting...
[00:00:09.277,618] <inf> mqtt_simple: LTE Link Connected!
[00:00:09.277,862] <err> mqtt_simple: getaddrinfo failed: -2
[00:00:09.277,893] <err> mqtt_simple: Failed to initialize broker connection
[00:00:09.277,893] <err> mqtt_simple: client_init: -10
We just added the following config lines to use NB-IoT in the sample:
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_LTE_MODE_PREFERENCE_NBIOT=y
When using the IP address of the moquitto test server, it works perfectly fine.
[00:00:00.568,603] <inf> mqtt_simple: The MQTT simple sample started
[00:00:00.568,664] <inf> mqtt_simple: Disabling PSM and eDRX
[00:00:00.569,366] <inf> mqtt_simple: LTE Link Connecting...
[00:00:11.186,523] <inf> mqtt_simple: LTE Link Connected!
[00:00:11.186,950] <inf> mqtt_simple: IPv4 Address found 91.121.93.94
[00:00:11.187,438] <dbg> mqtt_simple: client_id_get: client_id = nrf-2EB11F7FD373E99C
[00:00:11.598,114] <inf> mqtt_simple: MQTT client connected
[00:00:11.598,144] <inf> mqtt_simple: Subscribing to: my/subscribe/topic len 22
[00:00:11.746,185] <inf> mqtt_simple: SUBACK packet id: 1234
[00:06:48.615,112] <inf> mqtt_simple: MQTT PUBLISH result=0 len=15
[00:06:48.615,203] <inf> mqtt_simple: Received: test with ip address
[00:06:48.615,783] <inf> mqtt_simple: Publishing: test with ip address
[00:06:48.615,814] <inf> mqtt_simple: to topic: my/publish/topic len: 20
[00:06:48.761,352] <inf> mqtt_simple: PUBACK packet id: 39802
Has anybody an idea?
We are using the NCS v2.2.0 with the toolchain 2.2.0 (but tried the 2.1.0 as well, as we used with the dev-kit), modem firmware is 1.2.3
Edit: I forgot to add: when using the same code on the dev-kit, it works also fine with the IP Address and the URL. Modem firmware is here also 1.2.3 - thats the reason we choose 1.2.3 instead of 1.3.3. We also use the same SIM card to prevent any errors from the provider side (bad DNS, APN, whatever...)
Thank you!
BR Thomas
  • I used "test.mosquitto.org" and our mqtt server, also the CoAP server from the example (californium.eclipseprojects.io).
    I have no other NB-IoT SIM available at the moment, I try hard to get another one...
    But as mentioned before, the dev kit works fine with this SIM card and the same sourcecode. I tested also an other SIM card, but from the same provider and SIM pool, which we use for all our devices in our company.
    At the moment I test with the AT client and the LTE Link Monitor: we have similar signal strength and quality parameters as the devkit, often a few dBm better with our hardware (small ext. antenna, ~ -90dBm to ~ -100dBm).
    BR Thomas
  • Strange. You've tested the "samples/nrf9160/coap_client ?
    Some time ago, I get sometimes a "-EAGAIN" and so I added a loop:
     err = getaddrinfo(CONFIG_COAP_SERVER_HOSTNAME, NULL, &hints, &result);
     while (-err == EAGAIN) {
       k_sleep(K_MSEC(1000));
    Maybe you try a similar approach and limit that to say, "3 retries".
  • Uuups, I used the wrong modem firmware version.
    With 1.2.3 I see the DNS requests in the trace. But it seems, that the DNS responses are missing.
  • OK, I compared it with some traces from my devices.
    "trace_with_dns.bin"
    Contains in the pcapng (converted for version 1.2.3) 3 DNS requests:
    10.165.197.63 8.8.8.8 DNS 76 Standard query 0x375d A test.mosquitto.org
    10.130.12.1    8.8.8.8    DNS    76    Standard query 0x6b9e A test.mosquitto.org
    10.50.56.104 8.8.8.8 DNS 76 Standard query 0x0d59 A test.mosquitto.org
    I don't know, why it uses different source addresses (also the port is changing), but in my traces, that's not the case.
  • I've tested your approach with multiple requests, but the same result:
    uart:~$ *** Booting Zephyr OS build v3.2.99-ncs1 ***
    [00:00:00.495,513] <inf> nrf_modem_lib_trace: Trace thread ready
    [00:00:00.496,826] <inf> nrf_modem_lib_trace: Trace level override: 2
    [00:00:00.501,800] <inf> mqtt_simple: The MQTT simple sample started
    [00:00:00.501,800] <inf> mqtt_simple: Disabling PSM and eDRX
    [00:00:00.502,624] <inf> mqtt_simple: LTE Link Connecting...
    [00:00:07.834,686] <inf> mqtt_simple: LTE Link Connected!
    [00:00:07.834,747] <inf> mqtt_simple: connect to test.mosquitto.org
    [00:00:08.835,296] <inf> mqtt_simple: getaddrinfo result: -2
    [00:00:09.835,662] <inf> mqtt_simple: getaddrinfo result: -2
    [00:00:10.836,059] <inf> mqtt_simple: getaddrinfo result: -2
    [00:00:10.836,120] <err> mqtt_simple: getaddrinfo failed: -2
    [00:00:10.836,120] <err> mqtt_simple: Failed to initialize broker connection
    [00:00:10.836,120] <err> mqtt_simple: client_init: -10
    With 1.2.3 and 1.3.3
