mqtt_simple sample gets error -2 in getaddrinfo
We have developed our own module based on the nrf9160 DK and want to use it to send data to a MQTT broker. A few days ago on the dev-kit everything worked fine, now the new PCBs have arrived and we get this error in the mqtt_simple sample (as well as in our own code, but in a little different format):
 *** Booting Zephyr OS build v3.2.99-ncs1 ***
[00:00:00.504,638] <inf> mqtt_simple: The MQTT simple sample started
[00:00:00.504,699] <inf> mqtt_simple: Disabling PSM and eDRX
[00:00:00.505,401] <inf> mqtt_simple: LTE Link Connecting...
[00:00:09.277,618] <inf> mqtt_simple: LTE Link Connected!
[00:00:09.277,862] <err> mqtt_simple: getaddrinfo failed: -2
[00:00:09.277,893] <err> mqtt_simple: Failed to initialize broker connection
[00:00:09.277,893] <err> mqtt_simple: client_init: -10
We just added the following config lines to use NB-IoT in the sample:
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_LTE_MODE_PREFERENCE_NBIOT=y
When using the IP address of the moquitto test server, it works perfectly fine.
[00:00:00.568,603] <inf> mqtt_simple: The MQTT simple sample started
[00:00:00.568,664] <inf> mqtt_simple: Disabling PSM and eDRX
[00:00:00.569,366] <inf> mqtt_simple: LTE Link Connecting...
[00:00:11.186,523] <inf> mqtt_simple: LTE Link Connected!
[00:00:11.186,950] <inf> mqtt_simple: IPv4 Address found 91.121.93.94
[00:00:11.187,438] <dbg> mqtt_simple: client_id_get: client_id = nrf-2EB11F7FD373E99C
[00:00:11.598,114] <inf> mqtt_simple: MQTT client connected
[00:00:11.598,144] <inf> mqtt_simple: Subscribing to: my/subscribe/topic len 22
[00:00:11.746,185] <inf> mqtt_simple: SUBACK packet id: 1234
[00:06:48.615,112] <inf> mqtt_simple: MQTT PUBLISH result=0 len=15
[00:06:48.615,203] <inf> mqtt_simple: Received: test with ip address
[00:06:48.615,783] <inf> mqtt_simple: Publishing: test with ip address
[00:06:48.615,814] <inf> mqtt_simple: to topic: my/publish/topic len: 20
[00:06:48.761,352] <inf> mqtt_simple: PUBACK packet id: 39802
Has anybody an idea?
We are using the NCS v2.2.0 with the toolchain 2.2.0 (but tried the 2.1.0 as well, as we used with the dev-kit), modem firmware is 1.2.3
Edit: I forgot to add: when using the same code on the dev-kit, it works also fine with the IP Address and the URL. Modem firmware is here also 1.2.3 - thats the reason we choose 1.2.3 instead of 1.3.3. We also use the same SIM card to prevent any errors from the provider side (bad DNS, APN, whatever...)
Thank you!
BR Thomas
  • Yes, they are both on my desk.
    By the way: with the nrf_setdnsaddr the device reboots after a while. but I think I stopped the trace short before rebooting.
    I have done a trace with the device trying to get the dns address every 10s and the AT commands described as described:
    mqtt_simple_dns_request_redo.bin
    mqtt_simple_dns_request_redo.pcapng
    and the log output:
    [00:00:00.604,675] <inf> nrf_modem_lib_trace: Trace thread ready
    [00:00:00.606,140] <inf> nrf_modem_lib_trace: Trace level override: 2
    [00:00:00.611,389] <inf> mqtt_simple: The MQTT simple sample started
    [00:00:00.639,465] <inf> mqtt_simple: Modem response / reset: OK
    [00:00:00.639,465] <inf> mqtt_simple: Disabling PSM and eDRX
    [00:00:00.640,991] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 4
    OK
    [00:00:00.641,479] <inf> mqtt_simple: Modem response / CGDCONT: OK
    [00:00:00.642,028] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,0,0,255,127
    OK
    [00:00:00.642,059] <inf> mqtt_simple: LTE Link Connecting...
    [00:00:12.160,125] <inf> mqtt_simple: LTE Link Connected!
    [00:00:12.160,949] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"","","23205","7615",9,3,"018B7DDE",292,1401,53,41,"","11100000","11100000","01010100"
    OK
    [00:00:12.161,468] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:00:12.162,017] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,C,8,1,-88,16
    OK
    [00:00:12.162,292] <inf> mqtt_simple: getaddrinfo result: -2
    [00:00:22.163,208] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,46,"","11100000","11100000","01010100"
    OK
    [00:00:22.163,879] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:00:22.164,550] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,C,8,1,-87,21
    OK
    [00:00:22.164,886] <inf> mqtt_simple: getaddrinfo result: -2
    [00:00:32.174,163] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,42,"","11100000","11100000","01010100"
    OK
    [00:00:32.174,743] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:00:32.175,476] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,17
    OK
    [00:00:32.175,811] <inf> mqtt_simple: getaddrinfo result: -2
    [00:00:42.185,119] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,40,"","11100000","11100000","01010100"
    OK
    [00:00:42.185,699] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:00:42.186,248] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,15
    OK
    [00:00:42.186,584] <inf> mqtt_simple: getaddrinfo result: -2
    [00:00:52.195,892] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:00:52.196,441] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:00:52.196,960] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:00:52.197,326] <inf> mqtt_simple: getaddrinfo result: -2
    [00:01:02.206,604] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:01:02.207,336] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:01:02.207,916] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:01:02.208,221] <inf> mqtt_simple: getaddrinfo result: -2
    [00:01:12.217,498] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,42,"","11100000","11100000","01010100"
    OK
    [00:01:12.218,048] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:01:12.218,597] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,17
    OK
    [00:01:12.218,933] <inf> mqtt_simple: getaddrinfo result: -2
    [00:01:22.219,818] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,41,"","11100000","11100000","01010100"
    OK
    [00:01:22.220,520] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:01:22.221,099] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,16
    OK
    [00:01:22.221,405] <inf> mqtt_simple: getaddrinfo result: -2
    [00:01:32.230,743] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,42,"","11100000","11100000","01010100"
    OK
    [00:01:32.231,292] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:01:32.231,872] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,17
    OK
    [00:01:32.232,238] <inf> mqtt_simple: getaddrinfo result: -2
    [00:01:42.241,516] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,42,"","11100000","11100000","01010100"
    OK
    [00:01:42.242,095] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:01:42.242,614] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,17
    OK
    [00:01:42.242,980] <inf> mqtt_simple: getaddrinfo result: -2
    [00:01:52.252,258] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,41,"","11100000","11100000","01010100"
    OK
    [00:01:52.252,838] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:01:52.253,570] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,16
    OK
    [00:01:52.253,906] <inf> mqtt_simple: getaddrinfo result: -2
    [00:02:02.263,214] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,43,"","11100000","11100000","01010100"
    OK
    [00:02:02.263,824] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:02:02.264,373] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,18
    OK
    [00:02:02.264,739] <inf> mqtt_simple: getaddrinfo result: -2
    [00:02:12.274,047] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,38,"","11100000","11100000","01010100"
    OK
    [00:02:12.274,597] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:02:12.275,146] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,13
    OK
    [00:02:12.275,512] <inf> mqtt_simple: getaddrinfo result: -2
    [00:02:22.284,820] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,42,"","11100000","11100000","01010100"
    OK
    [00:02:22.285,369] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:02:22.285,919] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,17
    OK
    [00:02:22.286,285] <inf> mqtt_simple: getaddrinfo result: -2
    [00:02:32.295,593] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,43,"","11100000","11100000","01010100"
    OK
    [00:02:32.296,142] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:02:32.296,722] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,18
    OK
    [00:02:32.297,058] <inf> mqtt_simple: getaddrinfo result: -2
    [00:02:42.306,335] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:02:42.306,915] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:02:42.307,464] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:02:42.307,800] <inf> mqtt_simple: getaddrinfo result: -2
    [00:02:52.317,047] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:02:52.317,626] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:02:52.318,145] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:02:52.318,511] <inf> mqtt_simple: getaddrinfo result: -2
    [00:03:02.327,789] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:03:02.328,338] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:03:02.328,887] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:03:02.329,254] <inf> mqtt_simple: getaddrinfo result: -2
    [00:03:12.330,261] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:03:12.330,841] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:03:12.331,420] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:03:12.331,756] <inf> mqtt_simple: getaddrinfo result: -2
    [00:03:22.341,094] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,42,"","11100000","11100000","01010100"
    OK
    [00:03:22.341,644] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:03:22.342,376] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,17
    OK
    [00:03:22.342,712] <inf> mqtt_simple: getaddrinfo result: -2
    [00:03:32.352,050] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,43,"","11100000","11100000","01010100"
    OK
    [00:03:32.352,600] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:03:32.353,179] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,18
    OK
    [00:03:32.353,546] <inf> mqtt_simple: getaddrinfo result: -2
    [00:03:42.362,823] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,39,"","11100000","11100000","01010100"
    OK
    [00:03:42.363,403] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:03:42.363,922] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,14
    OK
    [00:03:42.364,288] <inf> mqtt_simple: getaddrinfo result: -2
    [00:03:52.373,565] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,40,"","11100000","11100000","01010100"
    OK
    [00:03:52.374,145] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:03:52.374,877] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,15
    OK
    [00:03:52.375,213] <inf> mqtt_simple: getaddrinfo result: -2
    [00:04:02.384,521] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,40,"","11100000","11100000","01010100"
    OK
    [00:04:02.385,131] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:04:02.385,681] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,15
    OK
    [00:04:02.386,047] <inf> mqtt_simple: getaddrinfo result: -2
    [00:04:12.395,355] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,38,"","11100000","11100000","01010100"
    OK
    [00:04:12.395,904] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:04:12.396,453] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,13
    OK
    [00:04:12.396,820] <inf> mqtt_simple: getaddrinfo result: -2
    [00:04:22.406,127] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:04:22.406,677] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:04:22.407,409] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:04:22.407,745] <inf> mqtt_simple: getaddrinfo result: -2
    [00:04:32.417,083] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,42,"","11100000","11100000","01010100"
    OK
    [00:04:32.417,633] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:04:32.418,182] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,17
    OK
    [00:04:32.418,548] <inf> mqtt_simple: getaddrinfo result: -2
    [00:04:42.427,795] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:04:42.428,375] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:04:42.428,924] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:04:42.429,260] <inf> mqtt_simple: getaddrinfo result: -2
    [00:04:52.438,507] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:04:52.439,086] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:04:52.439,605] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:04:52.439,971] <inf> mqtt_simple: getaddrinfo result: -2
    [00:05:02.440,979] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:05:02.441,558] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:05:02.442,138] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:05:02.442,474] <inf> mqtt_simple: getaddrinfo result: -2
    [00:05:12.451,812] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:05:12.452,362] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:05:12.452,911] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:05:12.453,277] <inf> mqtt_simple: getaddrinfo result: -2
    [00:05:22.462,585] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,39,"","11100000","11100000","01010100"
    OK
    [00:05:22.463,134] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:05:22.463,684] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,14
    OK
    [00:05:22.464,050] <inf> mqtt_simple: getaddrinfo result: -2
    [00:05:32.473,358] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,40,"","11100000","11100000","01010100"
    OK
    [00:05:32.473,907] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:05:32.474,487] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,15
    OK
    [00:05:32.474,853] <inf> mqtt_simple: getaddrinfo result: -2
    [00:05:42.484,130] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:05:42.484,710] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:05:42.485,229] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:05:42.485,595] <inf> mqtt_simple: getaddrinfo result: -2
    [00:05:52.494,873] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,41,"","11100000","11100000","01010100"
    OK
    [00:05:52.495,452] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:05:52.496,185] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,16
    OK
    [00:05:52.496,520] <inf> mqtt_simple: getaddrinfo result: -2
    [00:06:02.505,828] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:06:02.506,439] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:06:02.506,988] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:06:02.507,354] <inf> mqtt_simple: getaddrinfo result: -2
    [00:06:12.516,662] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:06:12.517,211] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:06:12.517,944] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:06:12.518,280] <inf> mqtt_simple: getaddrinfo result: -2
    [00:06:22.527,618] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:06:22.528,167] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:06:22.528,717] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:06:22.529,083] <inf> mqtt_simple: getaddrinfo result: -2
    [00:06:32.538,391] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,41,"","11100000","11100000","01010100"
    OK
    [00:06:32.538,940] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:06:32.539,489] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,16
    OK
    [00:06:32.539,855] <inf> mqtt_simple: getaddrinfo result: -2
    [00:06:42.549,102] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:06:42.549,682] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:06:42.550,415] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:06:42.550,750] <inf> mqtt_simple: getaddrinfo result: -2
    [00:06:52.551,788] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:06:52.552,337] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:06:52.552,947] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:06:52.553,283] <inf> mqtt_simple: getaddrinfo result: -2
    [00:07:02.562,591] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,41,"","11100000","11100000","01010100"
    OK
    [00:07:02.563,201] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:07:02.563,751] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,16
    OK
    [00:07:02.564,117] <inf> mqtt_simple: getaddrinfo result: -2
    [00:07:12.573,425] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,41,"","11100000","11100000","01010100"
    OK
    [00:07:12.573,974] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:07:12.574,523] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,16
    OK
    [00:07:12.574,890] <inf> mqtt_simple: getaddrinfo result: -2
    [00:07:22.584,197] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:07:22.584,747] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:07:22.585,479] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:07:22.585,815] <inf> mqtt_simple: getaddrinfo result: -2
    [00:07:32.595,153] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,41,"","11100000","11100000","01010100"
    OK
    [00:07:32.595,733] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:07:32.596,282] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,16
    OK
    [00:07:32.596,649] <inf> mqtt_simple: getaddrinfo result: -2
    [00:07:42.605,926] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,41,"","11100000","11100000","01010100"
    OK
    [00:07:42.606,506] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:07:42.607,025] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,16
    OK
    [00:07:42.607,391] <inf> mqtt_simple: getaddrinfo result: -2
    [00:07:52.616,668] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:07:52.617,248] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:07:52.617,980] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:07:52.618,316] <inf> mqtt_simple: getaddrinfo result: -2
    [00:08:02.627,624] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:08:02.628,234] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:08:02.628,784] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:08:02.629,150] <inf> mqtt_simple: getaddrinfo result: -2
    [00:08:12.638,458] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,40,"","11100000","11100000","01010100"
    OK
    [00:08:12.639,007] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:08:12.639,739] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,15
    OK
    [00:08:12.640,075] <inf> mqtt_simple: getaddrinfo result: -2
    [00:08:22.649,414] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,42,"","11100000","11100000","01010100"
    OK
    [00:08:22.649,963] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:08:22.650,512] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,17
    OK
    [00:08:22.650,878] <inf> mqtt_simple: getaddrinfo result: -2
    [00:08:32.660,156] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,43,"","11100000","11100000","01010100"
    OK
    [00:08:32.660,705] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:08:32.661,285] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,18
    OK
    [00:08:32.661,621] <inf> mqtt_simple: getaddrinfo result: -2
    [00:08:42.662,597] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,40,"","11100000","11100000","01010100"
    OK
    [00:08:42.663,177] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:08:42.663,757] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,15
    OK
    [00:08:42.664,093] <inf> mqtt_simple: getaddrinfo result: -2
    [00:08:52.673,370] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,42,"","11100000","11100000","01010100"
    OK
    [00:08:52.673,950] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:08:52.674,499] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,17
    OK
    [00:08:52.674,865] <inf> mqtt_simple: getaddrinfo result: -2
    [00:09:02.684,143] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,43,"","11100000","11100000","01010100"
    OK
    [00:09:02.684,753] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:09:02.685,302] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,18
    OK
    [00:09:02.685,668] <inf> mqtt_simple: getaddrinfo result: -2
    [00:09:12.694,976] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,44,"","11100000","11100000","01010100"
    OK
    [00:09:12.695,526] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:09:12.696,075] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,19
    OK
    [00:09:12.696,441] <inf> mqtt_simple: getaddrinfo result: -2
    [00:09:22.705,749] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,44,"","11100000","11100000","01010100"
    OK
    [00:09:22.706,298] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:09:22.706,848] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,19
    OK
    [00:09:22.707,214] <inf> mqtt_simple: getaddrinfo result: -2
    [00:09:32.716,522] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,55,41,"","11100000","11100000","01010100"
    OK
    [00:09:32.717,071] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:09:32.717,651] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-86,16
    OK
    [00:09:32.718,017] <inf> mqtt_simple: getaddrinfo result: -2
    [00:09:42.727,294] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,42,"","11100000","11100000","01010100"
    OK
    [00:09:42.727,874] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:09:42.728,393] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,17
    OK
    [00:09:42.728,759] <inf> mqtt_simple: getaddrinfo result: -2
    [00:09:52.738,037] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,42,"","11100000","11100000","01010100"
    OK
    [00:09:52.738,616] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:09:52.739,349] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,17
    OK
    [00:09:52.739,685] <inf> mqtt_simple: getaddrinfo result: -2
    [00:10:02.749,023] <inf> mqtt_simple: Modem response / monitor: %XMONITOR: 1,"3AT","3AT","23205","7615",9,3,"018B7DDE",292,1401,54,39,"","11100000","11100000","01010100"
    OK
    [00:10:02.749,572] <inf> mqtt_simple: Modem response / CGDCONT: +CGDCONT: 0,"IP","m2m.drei.at","10.71.192.243",0,0
    OK
    [00:10:02.750,122] <inf> mqtt_simple: Modem response / CEINFO: +CEINFO: 0,1,I,8,2,-87,14
    OK
    [00:10:02.750,488] <inf> mqtt_simple: getaddrinfo result: -2
    [00:10:12.750,579] <err> mqtt_simple: getaddrinfo failed: -2
    [00:10:12.750,610] <err> mqtt_simple: Failed to initialize broker connection
    [00:10:12.750,640] <err> mqtt_simple: client_init: -10
    uart:~$
    I will do the same with the devkit, but the trace is not getting logged at the moment. I will upload as soon as it works...
  • Hm, that log shows, that the device ip-address is stable and the signal conditions are well.
    Really mystic. Once you have the capture with the DNS requests, it will be very interesting to see, what that shows (FMPOV, only the one of the trace collector preview is required).
  • The problem for the trace was: I adapted the boardfile for UART1 (trace output) for our board just for fast tests and haven't added a new custom board. So here is the trace output incl. a mqtt test message:
    mqtt_simple_dns_request_redo_devkit.bin
    mqtt_simple_dns_request_redo_devkit.pcapng
    For my (not that high experienced) eyes: we see some DNS requests with a source and a destination, and a response from this DNS server (213.94.78.16). But from where does the device know this DNS server?
    Btw.: can the board definition cause any problem in this case regarding the DNS/address resolution? Our hardware is basically the devkit but with minor changes to the GPIOs and the debugger part has been removed - HF part, etc. is the same...
    And the hardware revision is different from the devkit and nowhere mentioned: BQA vs. B1A
    BR Thomas
  • > nslookup 213.94.78.16
    > 16.78.94.213.in-addr.arpa    name = pdnsvip1.drei.com.
    Looks like the DNS of your provider.
    Maybe AT+CGCONTRDP=0 helps to see, if that is assigned to the device by your provider.
  • I don't think, this is related to the modem hardware revision, and the issue is even with the "current modem hw release".
    > (small ext. antenna, ~ -90dBm to ~ -100dBm).
    FMPOV, the ext. antenna belongs to the "HF part" and is changed.
    Some experts told me, that for the most antennas, you need a matching ground-plane. Not sure, if that applies for your antenna. Also not sure, what the "signal strength" value really refer to.
    I'm still not clear, why the capture "trace_with_dns.bin" contains the changing ip-addresses, but your log trace_with_dns.bin the ip-address is stable.
    Anyway, once you have some trace of your dev, without "nrf_setdnsaddr", it will be very interesting, what that shows.
