pstorage function not working
I want to use pstorage with ble uart to store the data over bluetooth to flash . I did the coding for the pstorage operations. But the problem is that the pstorage store, clear and update functions not making the callback to exampleb_cb_handler.But the the load operation is working fine. The pstorage_access_status_get always show count greater than 0. what I am doing wrong?
    static void example_cb_handler(pstorage_handle_t  * handle,
                               uint8_t              op_code,
                               uint32_t             result,
                               uint8_t            * p_data,
                               uint32_t             data_len){
	 app_uart_put('e');
    switch(op_code)
       case PSTORAGE_LOAD_OP_CODE:
           if (result == NRF_SUCCESS)
               // Store operation successful.
						 app_uart_put('l');
						 app_uart_put('f');
               // Store operation failed.
           // Source memory can now be reused or freed.
					 case PSTORAGE_UPDATE_OP_CODE:
						 app_uart_put('u');
               // Update operation successful.
               // Update operation failed.
						 app_uart_put('f');
					 case PSTORAGE_CLEAR_OP_CODE:
						 pstorage_wait_flag = 0;
						 app_uart_put('c');
               // Clear operation successful.
						 app_uart_put('f');
               // Clear operation failed.
					 case PSTORAGE_STORE_OP_CODE:
						 app_uart_put('s');
						 app_uart_put('f');
    void example_pstorage_init(void)
		uint32_t retval;
pstorage_handle_t       base_handle;
pstorage_handle_t block_handle;
pstorage_module_param_t param;
uint8_t         source_data[500]={79,79,0,0,0,0,0,0,125,0,69,68,82,83,84};
uint8_t         dest_data[500];
 		retval = pstorage_init();
		if(retval == NRF_SUCCESS)
					// Module initialization successful.
   // Initialization failed, take corrective action.
param.block_size  = 1024;
param.block_count = 1;
param.cb          = example_cb_handler;
retval = pstorage_register(&param, & base_handle);
	app_uart_put(retval);
if (retval == NRF_SUCCESS)
    // Registration successful.
    // Failed to register, take corrective action.
retval = pstorage_block_identifier_get(&base_handle, 0, &block_handle);
    // Get Block Identifier successful.
    // Failed to get block id, take corrective action.
retval = pstorage_clear(&block_handle, 1024);
pstorage_wait_flag = 1;
//while(pstorage_wait_flag) { power_manage(); }
uint32_t    count;
pstorage_store(&block_handle, source_data, 500, 0);
pstorage_load(dest_data, &block_handle, 100, 0);
retval = pstorage_access_status_get(&count);
app_uart_put(count);
for(i=0;i<100;i++)
	app_uart_put(dest_data[i]);
