Zephyr BLE connection management
I have a bluetooth central app which connects to several BLE peripherals and am now working on fixing various connection reliability issues.
White lists and bonding are bring used and I am forcing connection loss via use of faraday bags.
I have questions related to connection management.
1) Use of bt_conn_le_create() verses bt_conn_le_create_auto() ?
On my initial scan of peripherals, I make my initial connection to the peripheral using bt_conn_le_create(); security level is set to L2 and the device is added to the whitelist.
On disconnects I call bt_conn_le_create_auto() to listen for whitelisted devices so they can reconnect.
Is a better schema to just do the scans, and add my peripheral devices to the white list. Then use bt_conn_le_create_auto() to connect to the white listed devices. When any peripheral is disconnected (callback); then call bt_conn_le_create_auto() to listen for the peripheral reconnecting?
Also Is it only necessary to set the security level to L2 on that initial connection; or must this be done on seeing each reconnection?
A similar question with regards to service discovery; must I only do this on the inital make of connection; or must this be done on each reconnection?
2) Use of bt_conn_ref() and bt_conn_unref() ?
Should bt_conn_unref() only be used when I am no-longer interested in a connection. IE seeing a deliberate disconnection? or should this be done for every disconnection I see even these environmental ones; where I hope to see the device reconnect?
KInd Regards,
Owain
  • Hi Hung,
    Any hints here?
    Unfortunately samples don't go into this detail.
    Owain
  • This looks to be to do with the connection reference counters.
    If I remove the bt_conn_unref() from the disconnect() callback and just re'arm the wit for incoming connection with bt_conn_le_create_auto(); then I can merrily loose and regain the sensor at random and the connection is reconnected after each period of disconnect.
    So only if it is a deliberately disconnect a peripherl should one do a bt_conn_unref()?
    This may be answer to one of my initial questions.
    1. The flow looks correct. Security and service discovery should be executed on each connection.
    2. bt_conn_unref would decrement a connection’s reference count. It is used when the connection counter involved the application.
    Amanda H.
  • Hi Amanda,
    So in the connected() callback we are given the reference to the connection (A reference counter has been incremented in the stack somewhere?).
    And in the disconnected() callback I must explicitly call bt_conn_unref()? this is not very symmetrical. Counter incremented inside the stack but decremented outside the stack. Where is that reference counter incremented?
    Its funny because at the moment the bt_conn_unref() is commented out in my disconnect routine before disconnect routine calls bt_conn_le_create_auto() and the device is merrily disconnecting/reconnecting as peripheral RF connection is blocked/freed using a faraday bag.
    See here attached a trace where bt_conn_unref() is called on disconnect(); this results in an assertion that related to refrence counters.
    Owain
  • In fact if I search through all sample code; one sees most examples using bt_conn_unref(); but only some that have calls to bt_conn_ref().
1 2
