Device is not advertising stuck at SOFTDEVICE_HANDLER_INIT Macro
I have created a customized Services according to nAN36 Document.
  1. SDK using 8.0
  2. Stack S110 8.0
  3. DEV kit PCA10028 nRF51.
  4. J-LInk RTT DEbugger
When the function ble_stack_init(void) get called from main. It stuck somewhere with MACRO
SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
This Macro is defined softdevice_handler.h file. Now how to Proceed further to check where I am lagging...
 ble_uuid_t adv_uuids[] =
				{SOS_BLE_BAS_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN},
				{SOS_UUID_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN},
				{FIND_ME_ALERT_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}
This is service I passed for advertising. And these are defined as
#define   SOS_UUID_BASE	{0xFA,0xFF,0xBE,0x11,0xA7,0x63,0x1C,0xBB,0x7F,0x48,0x27,0x66,0x00,0x00,0x8C,0xF0}
//-----------------------SERVICES UUID VENDOR
#define   SOS_UUID_SERVICE					0x1602
#define   FIND_ME_ALERT_SERVICE			0x1604
#define	SOS_BLE_BAS_SERVICE				0x1606
//-----------------------SERVICE CHARACTERISTIC UUID
#define	  SOS_UUID_EMR_MSG_CHAR			0x1608
#define 	ALERT_UUID_FIND_ME_CHAR		0x1610
#define		SOS_BLE_BAS_CHAR					0x1612
______________________________________________________________
Some one if suggest me the step I follow next to know the problem. And please revert on same if any other part of code require here.
  • Yes I have added my own Error handler there, but execution point may be not reached till that point. Because if it reached there till my error handler than also print the printf statement there. But it reset somewhere inside the sd_softdevice_enable Function which is simply an API, under SVCALL. SO I cant see what is happening inside there... Please clear my one doubt. As I have added three customized services and three characteristics for each services. May be this the main issue?? anything happening inside the sd_softdevice_enable function which is hardwired but I may be providing excessive values to any related parameters.
  • I think You got it your last line sir.... It never returns when it get inside the sd_softdevice_enable function.. OK Can you guide me where I can be wrong with Softdevice.. Because I am using everything as shown in Document. I am using nRF51-DK Hardware Kit and S110 softdevice version 8.0.2.
    One more thing If Softdevice compatibility is the only issue than why Application like Proximity run perfectly with same Softdevice.
