Is there any way to configure the flash data default values during programming phase with Keil IDE?
In IAR, it is possible using a file ".s43" included in the project which defines all the default flash data.
Best regards
Best regards
I am not an expert in IAR but i am assuming the in .s43 file you give default values to be set in the flash memory addresses.
In KEIL you can do something like this for the flash addresses you want to set in any .c or .h file (as it suits you) using the attribute feature
#if defined ( __CC_ARM )
#define SETTING_ADDRESS_IN_FLASH 0x20007F60
#define SETTINGS_VALUE 0x200
uint32_t some_setting_in_flash __attribute__((at(SETTING_ADDRESS_IN_FLASH))) = SETTINGS_VALUE;
The compiler will then generate the hex file with flash address and the value for it which will automatically flashed while programming your application into the device.
Thank you for your answer.
