How to read a frame from hm01b0 image sensor?
I am attempting to connect the Arducam hm01b0 to the nRF52840-DK embedded board, utilizing bare metal programming. The sensor comes with the following pins for serial interface. To access 4-bit interface( D1,D2,D3 and D4), the user has to solder the pins. However I am trying to get the HM01B0 working over the 1-bit interface and try to capture an image.
I am able to read and write to the sensor registers over I2C. The datasheet presents the following timings characteristics to capture an image.
I have connected the logic analyzer and I am able to see the corresponding waveform that is the data is being streamed over D0 line.
For 1 bit interface,the image sensor has a frame rate of 30 FPS and the frequency of PCLK is 36 Mhz. I know that GPIO pins would not be able to read the input signals in this
frequency range but I don't know how else to read a serial line. One option is making the image sensor as SPIM master and nrf52840 as SPIM slave. The image sensor provides the clock over PCLK which can be configured as SPI clock and the line D0 can be configured as MOSI line. However to read valid data bits/bytes over the serial line, VSYNC and HSYNC should also be read and made sure that their value is according to the serial video interface timings diagram. So I tried to read the serial line D0 by configuring it as a GPIO pin and I read 0x00 always.
How can I configure the image sensor and capture an image?
This is the code I have written,
// array to hold a complete frame
uint8_t  frameBuffer[324][324];
#define PIN_VSYNC      (28)
#define PIN_HSYNC      (29)
#define PIN_PCLK       (30)
#define PIN_D0         (31)
// initialise the pins of sensor
void hm0360_init()
    // GPIO I/P
    nrf_gpio_cfg_input(PIN_VSYNC, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_input(PIN_HSYNC, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_input(PIN_PCLK, NRF_GPIO_PIN_PULLUP);
    // GPIO O/P
     nrf_gpio_cfg_input(PIN_D0,NRF_GPIO_PIN_PULLUP);
    for(int i = 0; i < 324 ; i++){
        for(int j = 0; j < 324 ; j++){
            frameBuffer[i][j] = 0;
void hm01b0_read_frame_bits()
   int VSYNC_count = -1, HREF_count = 0;
   int incomingBits;
    unsigned char byte = 0;
    int byteArrayIndex = 0;
    int bitCount = 0;
while(nrf_gpio_pin_read(PIN_VSYNC) == LOW) { }
while(nrf_gpio_pin_read(PIN_VSYNC) == HIGH)
	while(nrf_gpio_pin_read(PIN_HSYNC) == false && nrf_gpio_pin_read(PIN_VSYNC) == HIGH) { }
    VSYNC_count++;
	HREF_count = 0;
	//Read a row
	while(nrf_gpio_pin_read(PIN_HSYNC) == true)
		while(nrf_gpio_pin_read(PIN_PCLK) == false) { }
		// read 0 always
		incomingBits = nrf_gpio_pin_read(PIN_D0);
		byte = (byte << 1) | incomingBits;
		bitCount++;
		if (bitCount == 8) {
			frameBuffer[VSYNC_count][HREF_count++] = byte;
			bitCount = 0;
			byte = 0;
		if (VSYNC_count == 324) {
		while(nrf_gpio_pin_read(PIN_PCLK) == true) { }
You can find the datasheet of the image sensor here : www.uctronics.com/.../HM01B0-MWA-image-sensor-datasheet.pdf
  • MCLK is an input signal i.e nrf52840-dk has to provide to clock for synchronisation. where as pclk is an output signal i.e the hm01b0 provides the clock. Hence I thought of using spi with nrf52840 as slave device.
  • Hi,  is their any progress on this subject, are you able to retrieve image at  low frame per second, thx
  • The job is feasible with nRF5 SPIS module.
     Beware: SPIS options are designed a bit limited, compared to SPIM.
     Clock source: Configure GPIOTE clock output to HM01B0 MCLK pin, then configure HM01B0 for external MCLK.
         Also set gated clock and serial interface from camera for use with SPIS of Nordic micro.
       Set camera mode for streaming one frame at a time.
    2. Unlike SPIM, SPIS cannot be triggered internally, only through its declared CS_IN pin.
        HSYNC may be used to trigger reading whole 324x324 pixels, each line as a single SPI transfer,
        but HSYNC needs to be inverted for use as CS_line.
        Unlike SPIM, SPIS buffer cannot increment after each transaction,
        and more to say: before next transaction buffers MUST be set again
        (With receive buffer address incremented) in SPIS event handler, after each NRF_DRV_SPIS_XFER_DONE.
     3. It's possible to use H1B0 HSYNC for CS after inverting it on GPIOTE (toggling CS_OUT with PPI from HSYNC).
         Dummy CS_OUT needs to be routed physically to pin CS_IN, declared in SPI_S.
         It is good idea to advance HSYNC in HM01B0, to allow for some added delay between HSYNC and CS_IN.
  • I am attempting to do the same thing. I know it is possible because it was documented in a Science Robotics article in 2020. Here is some information that will hopefully help everyone (pp. 5):
    To allow the Bluetooth chip to read the image sensor data directly at the highest frame rate requires a direct memory access (DMA) feature. The DMA feature, however, is only exposed for certain common communication protocols, none of which are supported by the camera. The camera only outputs data and clock signals. To read the camera data, we repurposed the serial peripheral interface (SPI) interface, which does have access to DMA. Reading data over the SPI interface requires a data signal, a clock signal, and a chip select (CS) signal. We could directly use the camera’s data and clock outputs for the first two. However, to provide the missing CS signal required by the protocol, we leveraged the line-valid output of the camera. This signal was configured to trigger an interrupt on the Bluetooth chip, which toggles an output pin to spoof the missing CS signal.
    This will be my first project with the NRF52832. I don't really know where to start. Probably with some simpler practice problems?
