MCUBoot usb with openthread sample
I have a custom board with a BMD345-A-R module and working with ncs v2.2.0. It has an USB port to comunicate with a RaspberryPi. The board works perfectly cause I have tried several examples:
- Serial MCUBoot -> I can manage firmware updates with mcumgr via USB.
-  openthread -> I configure the project RCP mode and I can connect with ot-ctl (from my RaspberryPi) to my custom board (RCP).
I have to add this "CONFIG_BOARD_ENABLE_DCDC=n" to my prj.conf and mcuboot.conf. Resuming, I have created an openthread project and added the code necessary to enable MCUBoot like the tutorial explain.
My problem is openthread is working fine but I cant communicate with mcumgr. I try:
mcumgr --conntype serial --connstring "/dev/ttyACM0,baud=115200" echo hello
But has no response.
I have add the next configuration files to openthread project:
overlay-rcp.conf
overlay-usb-nrf-br.conf
usb.overlay
I tried adding "overlay-cdc.conf" too like SMP_Server indicate to build it, but it is the same result, Openthread works but mcumgr not.
I tried the SMP_Server sample with the next build command:
west build  -p  -b nrf52840dk_nrf52840    zephyr/samples/subsys/mgmt/mcumgr/smp_svr    --    -DOVERLAY_CONFIG='overlay-cdc.conf;custom_config.conf'    -DDTC_OVERLAY_FILE=usb.overlay
And it works too. Mcumgr communicates ok. custom_config.conf has "CONFIG_BOARD_ENABLE_DCDC=n" and I added it to the mcuboot.conf in child_image folder too.
I attach the project, maybe you can try it on a nrf52840DK board.0272.coprocessor_custom.zip
  • I have tried with the sample "mcuboot_serial_recovery_cdc_acm" and if I push the button when I switch on the board I enable mcumgr and I can send commands. But with the "mcuboot_serial_recovery_cdc_acm_wait" I cant send an mcumgr command while bootloader is on.
  • I'm trying to advance in parallel with my custom project. I have implemented to openthread sample the MCUBoot serial_recovery. The prj.conf from the main aplicattion:
    CONFIG_NETWORKING=y
    CONFIG_NET_L2_OPENTHREAD=y
    # Disable certain parts of Zephyr IPv6 stack
    CONFIG_NET_IPV6_NBR_CACHE=n
    CONFIG_NET_IPV6_MLD=n
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_MAX_LEVEL=1
    CONFIG_LOG_MODE_MINIMAL=n
    CONFIG_LOG_BACKEND_SPINEL=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_BOOT_BANNER=n
    # Kernel options
    CONFIG_MAIN_STACK_SIZE=2560
    CONFIG_INIT_STACKS=y
    # Increase logging thread stack size due to Spinel backend needs
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
    # Set OpenThread NCP architecture
    CONFIG_OPENTHREAD_COPROCESSOR=y
    CONFIG_OPENTHREAD_COPROCESSOR_NCP=y
    # Add features required for NCP
    CONFIG_OPENTHREAD_DIAG=y
    CONFIG_OPENTHREAD_DHCP6_SERVER=y
    CONFIG_OPENTHREAD_COMMISSIONER=y
    CONFIG_OPENTHREAD_BORDER_AGENT=y
    CONFIG_OPENTHREAD_BORDER_ROUTER=y
    CONFIG_OPENTHREAD_UDP_FORWARD=y
    CONFIG_OPENTHREAD_ENABLE_SERVICE=y
    CONFIG_BOOTLOADER_MCUBOOT=y
    I build it with:
    overlay-rcp.conf
    usb.overlay
    The mcuboot.conf:
    CONFIG_SIZE_OPTIMIZATIONS=y
    CONFIG_SINGLE_APPLICATION_SLOT=y
    # Enable MCUboot Serial Recovery
    CONFIG_MCUBOOT_SERIAL=y
    CONFIG_UART_CONSOLE=n
    # Point Serial Recovery to CDC_ACM
    CONFIG_BOOT_SERIAL_CDC_ACM=y
    CONFIG_MCUBOOT_INDICATION_LED=y
    But I have error building. If I comment "CONFIG_BOOT_SERIAL_CDC_ACM" then it build correctly. The error I get building with "CONFIG_BOOT_SERIAL_CDC_ACM=y" is:
    west build --build-dir /home/scada/Documents/coprocessor_bootloader/build /home/scada/Documents/coprocessor_bootloader --pristine --board nrf52840dk_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/home/scada/Documents/ublox_bmd345_nrf52840-main/ubx_bmd345_nrf52840;/home/scada/Documents/coprocessor_custom;/home/scada/Documents/coprocessor_bootloader" -DDTC_OVERLAY_FILE:STRING="/home/scada/Documents/coprocessor_bootloader/usb.overlay" -DCONF_FILE:STRING="/home/scada/Documents/coprocessor_bootloader/prj.conf" -DOVERLAY_CONFIG:STRING="/home/scada/Documents/coprocessor_bootloader/overlay-rcp.conf;/home/scada/Documents/coprocessor_bootloader/overlay-usb-nrf-br.conf"
    -- Application: /home/scada/Documents/coprocessor_bootloader
    -- Found Python3: /home/scada/ncs/toolchains/v2.2.0/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: /home/scada/.cache/zephyr
    -- Zephyr version: 3.2.99 (/home/scada/ncs/v2.2.0/zephyr)
    -- Board: nrf52840dk_nrf52840
    -- Found host-tools: zephyr 0.15.1 (/home/scada/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (/home/scada/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: /home/scada/ncs/toolchains/v2.2.0/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/scada/ncs/v2.2.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
    -- Found devicetree overlay: /home/scada/Documents/coprocessor_bootloader/usb.overlay
    -- Generated zephyr.dts: /home/scada/Documents/coprocessor_bootloader/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/scada/Documents/coprocessor_bootloader/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/scada/Documents/coprocessor_bootloader/build/zephyr/dts.cmake
    warning: SHELL_PROMPT_UART (defined at subsys/shell/backends/Kconfig.backends:36) was assigned the
    value 'ncp-uart:~$ ' but got the value ''. Check these unsatisfied dependencies:
    SHELL_BACKEND_SERIAL (=n), SHELL_BACKENDS (=n), SHELL (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SHELL_PROMPT_UART and/or look up
    SHELL_PROMPT_UART in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    Parsing /home/scada/Documents/coprocessor_bootloader/Kconfig
    Loaded configuration '/home/scada/ncs/v2.2.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
    Merged configuration '/home/scada/Documents/coprocessor_bootloader/prj.conf'
    Merged configuration '/home/scada/Documents/coprocessor_bootloader/overlay-rcp.conf'
    Merged configuration '/home/scada/Documents/coprocessor_bootloader/overlay-usb-nrf-br.conf'
    Configuration saved to '/home/scada/Documents/coprocessor_bootloader/build/zephyr/.config'
    Kconfig header saved to '/home/scada/Documents/coprocessor_bootloader/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: /home/scada/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    CMake Warning at /home/scada/ncs/v2.2.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
      CONFIG_USB_DEVICE_VID has default value 0x2FE3.
      This value is only for testing and MUST be configured for USB products.
    CMake Warning at /home/scada/ncs/v2.2.0/zephyr/subsys/usb/device/CMakeLists.txt:28 (message):
      CONFIG_USB_DEVICE_PID has default value 0x100.
    -- Found Python3: /home/scada/ncs/toolchains/v2.2.0/usr/local/bin/python3.8 (found version "3.8.2") found components: Interpreter
    === child image mcuboot -  begin ===
    loading initial cache file /home/scada/Documents/coprocessor_bootloader/build/mcuboot/child_image_preload.cmake
    -- Application: /home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: /home/scada/ncs/v2.2.0/nrf/modules/mcuboot/usb.overlay
    -- Found devicetree overlay: /home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: /home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr/dts.cmake
    Parsing /home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Merged configuration '/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/boards/nrf52840dk_nrf52840.conf'
    Merged configuration '/home/scada/ncs/v2.2.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration '/home/scada/Documents/coprocessor_bootloader/child_image/mcuboot.conf'
    Merged configuration '/home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr/include/generated/autoconf.h'
    CMake Warning at /home/scada/ncs/v2.2.0/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
            --- WARNING: To maintain the integrity of secure boot, ---
            --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
    CMake Warning at /home/scada/ncs/v2.2.0/zephyr/CMakeLists.txt:824 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
    MCUBoot bootloader key file: /home/scada/ncs/v2.2.0/bootloader/mcuboot/root-ec-p256.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/scada/Documents/coprocessor_bootloader/build/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at /home/scada/ncs/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
              --- WARNING: Using default MCUBoot key, it should not ---
              --- be used for production.                           ---
    -- OpenThread Source Directory: /home/scada/ncs/v2.2.0/modules/lib/openthread
    -- OT_ANYCAST_LOCATOR=""
    -- OT_ASSERT=OFF --> OPENTHREAD_CONFIG_ASSERT_ENABLE=0
    -- OT_BACKBONE_ROUTER=OFF --> OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0
    -- OT_BACKBONE_ROUTER_DUA_NDPROXYING=""
    -- OT_BACKBONE_ROUTER_MULTICAST_ROUTING=""
    -- OT_BORDER_AGENT=ON --> OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1
    -- OT_BORDER_ROUTER=ON --> OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1
    -- OT_BORDER_ROUTING=""
    -- OT_BORDER_ROUTING_COUNTERS=""
    -- OT_CHANNEL_MANAGER=OFF --> OPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0
    -- OT_CHANNEL_MONITOR=OFF --> OPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0
    -- OT_CHILD_SUPERVISION=OFF --> OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=0
    -- OT_COAP=OFF --> OPENTHREAD_CONFIG_COAP_API_ENABLE=0
    -- OT_COAP_BLOCK=OFF --> OPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0
    -- OT_COAP_OBSERVE=OFF --> OPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0
    -- OT_COAPS=OFF --> OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0
    -- OT_COMMISSIONER=ON --> OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1
    -- OT_CSL_AUTO_SYNC=OFF --> OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0
    -- OT_CSL_DEBUG=OFF --> OPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0
    -- OT_CSL_RECEIVER=OFF --> OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=0
    -- OT_DATASET_UPDATER=OFF --> OPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0
    -- OT_DHCP6_CLIENT=OFF --> OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0
    -- OT_DHCP6_SERVER=ON --> OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1
    -- OT_DIAGNOSTIC=ON --> OPENTHREAD_CONFIG_DIAG_ENABLE=1
    -- OT_DNS_CLIENT=OFF --> OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0
    -- OT_DNS_DSO=OFF --> OPENTHREAD_CONFIG_DNS_DSO_ENABLE=0
    -- OT_DNSSD_SERVER=OFF --> OPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0
    -- OT_DUA=OFF --> OPENTHREAD_CONFIG_DUA_ENABLE=0
    -- OT_ECDSA=OFF --> OPENTHREAD_CONFIG_ECDSA_ENABLE=0
    -- OT_EXTERNAL_HEAP=OFF --> OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0
    -- OT_FIREWALL=""
    -- OT_HISTORY_TRACKER=OFF --> OPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0
    -- OT_IP6_FRAGM=OFF --> OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0
    -- OT_JAM_DETECTION=OFF --> OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0
    -- OT_JOINER=OFF --> OPENTHREAD_CONFIG_JOINER_ENABLE=0
    -- OT_LEGACY=OFF --> OPENTHREAD_CONFIG_LEGACY_ENABLE=0
    -- OT_LINK_METRICS_INITIATOR=OFF --> OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0
    -- OT_LINK_METRICS_SUBJECT=OFF --> OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0
    -- OT_LINK_RAW=OFF --> OPENTHREAD_CONFIG_LINK_RAW_ENABLE=0
    -- OT_LOG_LEVEL_DYNAMIC=OFF --> OPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0
    -- OT_MAC_FILTER=OFF --> OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0
    -- OT_MESSAGE_USE_HEAP=""
    -- OT_MLE_LONG_ROUTES=OFF --> OPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0
    -- OT_MLR=OFF --> OPENTHREAD_CONFIG_MLR_ENABLE=0
    -- OT_MTD_NETDIAG=OFF --> OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=0
    -- OT_MULTIPLE_INSTANCE=OFF --> OPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0
    -- OT_NAT64_BORDER_ROUTING=""
    -- OT_NAT64_TRANSLATOR=""
    -- OT_NEIGHBOR_DISCOVERY_AGENT=OFF --> OPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0
    -- OT_NETDATA_PUBLISHER=OFF --> OPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0
    -- OT_OTNS=OFF --> OPENTHREAD_CONFIG_OTNS_ENABLE=0
    -- OT_PING_SENDER=ON --> OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1
    -- OT_PLATFORM_NETIF=OFF --> OPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0
    -- OT_PLATFORM_UDP=OFF --> OPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0
    -- OT_REFERENCE_DEVICE=OFF --> OPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0
    -- OT_SERVICE=ON --> OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1
    -- OT_SETTINGS_RAM=OFF --> OPENTHREAD_SETTINGS_RAM=0
    -- OT_SLAAC=OFF --> OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0
    -- OT_SNTP_CLIENT=OFF --> OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0
    -- OT_SRP_CLIENT=OFF --> OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0
    -- OT_SRP_SERVER=OFF --> OPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0
    -- OT_TIME_SYNC=OFF --> OPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0
    -- OT_TREL=OFF --> OPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0
    -- OT_TX_BEACON_PAYLOAD=""
    -- OT_UDP_FORWARD=ON --> OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1
    -- OT_UPTIME=OFF --> OPENTHREAD_CONFIG_UPTIME_ENABLE=0
    -- OT_RCP_RESTORATION_MAX_COUNT=0
    -- Package Name: OPENTHREAD
    -- Setting default package version: 0759de4fc
    -- Package Version: 0759de4fc
    -- Configuring done
    -- Generating done
    [1/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/pkcs5.c.obj
    [2/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/home/scada/ncs/v2.2.0/mbedtls/library/x509.c.obj
    [3/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/home/scada/ncs/v2.2.0/mbedtls/library/x509_create.c.obj
    [4/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/home/scada/ncs/v2.2.0/mbedtls/library/x509write_csr.c.obj
    [5/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/home/scada/ncs/v2.2.0/mbedtls/library/x509_crl.c.obj
    [6/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/home/scada/ncs/v2.2.0/mbedtls/library/x509_crt.c.obj
    [7/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/home/scada/ncs/v2.2.0/mbedtls/library/x509_csr.c.obj
    [8/437] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (/home/scada/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
    [9/437] Preparing syscall dependency handling
    [10/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/asn1parse.c.obj
    [11/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/asn1write.c.obj
    [12/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/bignum.c.obj
    [13/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/nist_kw.c.obj
    [14/437] Creating directories for 'mcuboot_subimage'
    [15/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/base64.c.obj
    [16/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/oid.c.obj
    [17/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/padlock.c.obj
    [18/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/platform.c.obj
    [19/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/platform_util.c.obj
    [20/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/version.c.obj
    [21/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/home/scada/ncs/v2.2.0/mbedtls/library/constant_time.c.obj
    [22/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto.c.obj
    [23/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_aead.c.obj
    [24/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_cipher.c.obj
    [25/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_client.c.obj
    [26/437] No download step for 'mcuboot_subimage'
    [27/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_ecp.c.obj
    [28/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_hash.c.obj
    [29/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_rsa.c.obj
    [30/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_slot_management.c.obj
    [31/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_mac.c.obj
    [32/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/psa_crypto_storage.c.obj
    [33/437] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a
    [34/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/pem.c.obj
    [35/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
    [36/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/pkcs12.c.obj
    [37/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/pkparse.c.obj
    [38/437] No update step for 'mcuboot_subimage'
    [39/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/pkwrite.c.obj
    [40/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/dhm.c.obj
    [41/437] Generating misc/generated/syscalls_subdirs.trigger
    [42/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/cipher.c.obj
    [43/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/cipher_wrap.c.obj
    [44/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/md.c.obj
    [45/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/pk.c.obj
    [46/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/pk_wrap.c.obj
    [47/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/sha1.c.obj
    [48/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/sha256.c.obj
    [49/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/sha512.c.obj
    [50/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/ripemd160.c.obj
    [51/437] No patch step for 'mcuboot_subimage'
    [52/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/md5.c.obj
    [53/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/aesni.c.obj
    [54/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/aria.c.obj
    [55/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/camellia.c.obj
    [56/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/des.c.obj
    [57/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/cmac.c.obj
    [58/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/ccm.c.obj
    [59/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/chachapoly.c.obj
    [60/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/ecdh.c.obj
    [61/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/ecdsa.c.obj
    [62/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/ecp.c.obj
    [63/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/ecp_curves.c.obj
    [64/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/gcm.c.obj
    [65/437] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/scada/ncs/v2.2.0/mbedtls/library/hkdf.c.obj
    [66/437] No configure step for 'mcuboot_subimage'
    [66/437] Performing build step for 'mcuboot_subimage'
    [1/216] Preparing syscall dependency handling
    [2/216] Generating include/generated/version.h
    [3/216] Generating misc/generated/syscalls_subdirs.trigger
    [4/216] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [5/216] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [6/216] Generating include/generated/driver-validation.h
    [7/216] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [8/216] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [9/216] Generating include/generated/offsets.h
    [10/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [11/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [12/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/base64.c.obj
    [13/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [14/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [15/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [16/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [17/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [18/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [19/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [20/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [21/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [22/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [23/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [24/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [25/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [26/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [27/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [28/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [29/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [30/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [31/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [32/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [33/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
    [34/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [35/216] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [36/216] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [37/216] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [38/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [39/216] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [40/216] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [41/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_device.c.obj
    [42/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_transfer.c.obj
    [43/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_work_q.c.obj
    [44/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_descriptor.c.obj
    [45/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/cdc_acm.c.obj
    [46/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [47/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [48/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [49/216] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [50/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [51/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [52/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/serial_recovery_cbor.c.obj
    [53/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_decode.c.obj
    [54/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_encode.c.obj
    [55/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/zcbor_common.c.obj
    [56/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
    [57/216] Building C object zephyr/CMakeFiles/zephyr.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/boot_serial/src/boot_serial.c.obj
    [58/216] Generating linker_zephyr_pre1.cmd
    [59/216] Generating linker_zephyr_pre0.cmd
    [60/216] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/__/__/misc/empty_file.c.obj
    [61/216] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [62/216] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [63/216] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [64/216] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [65/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [66/216] Generating zephyr/autogen-pubkey.c
    [67/216] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [68/216] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [69/216] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [70/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [71/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [72/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [73/216] Linking C static library zephyr/libzephyr.a
    [74/216] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [75/216] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [76/216] Linking C static library zephyr/arch/common/libisr_tables.a
    [77/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [78/216] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [79/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [80/216] Building C object CMakeFiles/app.dir/main.c.obj
    [81/216] Building C object CMakeFiles/app.dir/os.c.obj
    [82/216] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [83/216] Building C object CMakeFiles/app.dir/keys.c.obj
    [84/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [85/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [86/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [87/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [88/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [89/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [90/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [91/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [92/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
    [93/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
    [94/216] Building C object CMakeFiles/app.dir/single_loader.c.obj
    [95/216] Building C object CMakeFiles/app.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [96/216] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [97/216] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [98/216] Linking C static library zephyr/arch/common/libarch__common.a
    [99/216] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [100/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [101/216] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [102/216] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [103/216] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [104/216] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [105/216] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [106/216] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [107/216] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [108/216] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [109/216] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [110/216] Linking C static library app/libapp.a
    [111/216] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
    [112/216] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [113/216] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [114/216] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj
    [115/216] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [116/216] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [117/216] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [118/216] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [119/216] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [120/216] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj
    [121/216] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [122/216] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [123/216] Linking C static library zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a
    [124/216] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [125/216] Linking C static library zephyr/drivers/usb/device/libdrivers__usb__device.a
    [126/216] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [127/216] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [128/216] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [129/216] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [130/216] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [131/216] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
    [132/216] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [133/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [134/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [135/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [136/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [137/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [138/216] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [139/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [140/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [141/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [142/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [143/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [144/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [145/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [146/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [147/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [148/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [149/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [150/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [151/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [152/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [153/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [154/216] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [155/216] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [156/216] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [157/216] Linking C static library zephyr/drivers/hwinfo/libdrivers__hwinfo.a
    [158/216] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [159/216] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [160/216] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [161/216] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [162/216] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/scada/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [163/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
    [164/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [165/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [166/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [167/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [168/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [169/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
    [170/216] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [171/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [172/216] Building C object modules/segger/CMakeFiles/modules__segger.dir/home/scada/ncs/v2.2.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [173/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_usbd.c.obj
    [174/216] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/scada/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [175/216] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [176/216] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [177/216] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [178/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [179/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [180/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [181/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [182/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [183/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [184/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [185/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [186/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [187/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [188/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [189/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [190/216] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [191/216] Linking C static library modules/segger/libmodules__segger.a
    [192/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [193/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [194/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [195/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [196/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [197/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [198/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [199/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [200/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [201/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [202/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [203/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [204/216] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [205/216] Linking C static library zephyr/kernel/libkernel.a
    [206/216] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    : && ccache /home/scada/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/drivers/usb/device/libdrivers__usb__device.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/hwinfo/libdrivers__hwinfo.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"/home/scada/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/thumb/v7e-m+fp/hard"  -L/home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  /home/scada/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.16.a  /home/scada/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /home/scada/Documents/coprocessor_bootloader/build/mcuboot/zephyr && /home/scada/ncs/toolchains/v2.2.0/usr/local/lib/python3.8/site-packages/cmake/data/bin/cmake -E echo
    /home/scada/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
    /home/scada/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 10808 bytes
    collect2: error: ld returned 1 exit status
    [89/437] cd /home/scada/Documents/coprocessor_bootloader/build/modules/openthread/build && /home/scada/ncs/toolchains/v2.2.0/usr/local/lib/python3.8/site-packages/cmake/data/bin/cmake -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0;OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1;OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1;OPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0;OPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0;OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=0;OPENTHREAD_CONFIG_COAP_API_ENABLE=0;OPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0;OPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0;OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0;OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0;OPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0;OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=0;OPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1;OPENTHREAD_CONFIG_DIAG_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0;OPENTHREAD_CONFIG_DNS_DSO_ENABLE=0;OPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0;OPENTHREAD_CONFIG_DUA_ENABLE=0;OPENTHREAD_CONFIG_ECDSA_ENABLE=0;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0;OPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0;OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0;OPENTHREAD_CONFIG_JOINER_ENABLE=0;OPENTHREAD_CONFIG_LEGACY_ENABLE=0;OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0;OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0;OPENTHREAD_CONFIG_LINK_RAW_ENABLE=0;OPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0;OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0;OPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0;OPENTHREAD_CONFIG_MLR_ENABLE=0;OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=0;OPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0;OPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0;OPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0;OPENTHREAD_CONFIG_OTNS_ENABLE=0;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0;OPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0;OPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0;OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1;OPENTHREAD_SETTINGS_RAM=0;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0;OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0;OPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0;OPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0;OPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0;OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1;OPENTHREAD_CONFIG_UPTIME_ENABLE=0;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_3;OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=1;_ANSI_SOURCE;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=1;__PROGRAM_START;NRF52840_XXAA;NRF_802154_CCA_CORR_LIMIT_DEFAULT=2;NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45;NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45;NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=16;NRF_802154_PENDING_EXTENDED_ADDRESSES=16;NRF_802154_RX_BUFFERS=16;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_ENCRYPTION_ENABLED=1;NRF_802154_SECURITY_WRITER_ENABLED=1;NRF_802154_IE_WRITER_ENABLED=1;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;NRF_802154_ECB_PRIORITY=-1;NRF_802154_SWI_PRIORITY=1;MBEDTLS_CONFIG_FILE="nrf-config.h";MBEDTLS_USER_CONFIG_FILE="nrf-config-user.h"" -P /home/scada/ncs/v2.2.0/modules/lib/openthread/etc/cmake/print.cmake
    PACKAGE_NAME=OPENTHREAD
    KERNEL
    __ZEPHYR__=1
    _FORTIFY_SOURCE=1
    _ANSI_SOURCE
    __PROGRAM_START
    NRF52840_XXAA
    MBEDTLS_CONFIG_FILE=nrf-config.h
    MBEDTLS_USER_CONFIG_FILE=nrf-config-user.h
    [415/437] Linking CXX static library zephyr/kernel/libkernel.a
    FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
    cd /home/scada/Documents/coprocessor_bootloader/build/mcuboot && /home/scada/ncs/toolchains/v2.2.0/usr/local/lib/python3.8/site-packages/cmake/data/bin/cmake --build . --
    [417/437] Linking CXX executable zephyr/zephyr_pre0.elf
    FATAL ERROR: command exited with status 1: /home/scada/ncs/toolchains/v2.2.0/usr/local/bin/cmake --build /home/scada/Documents/coprocessor_bootloader/build
     *  The terminal process terminated with exit code: 1.
    I have not yet been able to recreate your issue today as it's taken longer time than expected, so I will leave you with some answers to some of your questions before the weekend starts, and I'll get back to you as soon as possible on Monday.
    This should be possible, and it leaves me suspecting the following:
    1. As a sanity check: Could you verify that you're using the nRF USB on the long side of the nRF52840DK (you've mentioned that you're building for 52840dk earlier so I'm assuming you're developing on that DK as well)
    This should be possible, so I will add this to the investigation list as well. It could indicate that you're not using the nRF USB (which is why I'm asking the previous question), or it could indicate that the USB is being used by something else, such as the RCP.
    Line 480 in the error log says something about flash overflow. Can you see how large your application is (both with and without the bootloader(s))
    Andreas
  • As a sanity check: Could you verify that you're using the nRF USB on the long side of the nRF52840DK (you've mentioned that you're building for 52840dk earlier so I'm assuming you're developing on that DK as well)
    Yes, Im using J3 connector (nRF USB)
    I don't think so because in the samples you shared me (https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/main/bootloader_samples/serial_recovery/mcuboot_serial_recovery_cdc_acm_wait) the main app is empty.
