Cannot bind app key for one of the model with PYACI Script
Hello
I am trying to bind app key for one of the models with the help of PYACI Python script. I am using latest version v5.0.0 for PYACI script and downloaded it here: https://github.com/NordicSemiconductor/nRF5-SDK-for-Mesh , also with same version of documentation for commands https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v2.1.1%2Fmd_scripts_interactive_pyaci_README.html.  And I am using Raspberry pi where my py script is running and nRF52840 with Serial Script running connected to Raspberry Pi with Ports /dev/ttyACM0 (or) /dev/ttyACM1. I am trying to bind app key for Sensor_Server Example and i get like this where all the earlier commands works well.
NOTE: examples are connected to Laptop which is obvious where we can run with bluetooth
 I also tried with Mesh Chat sample like above and get same problem
Another Question: we can identify the sample with last model ID where vendor Setup Model ID bound to "0059000a" which is 8 bit and where it should be 4 bit. Even in app i get the same ID
which is ok to setup in app but in this command - cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x1000)) it should have only 4 bit right?
Please help me as soon as possible. I really in need of help to continue my work further
Regards
  • Hello Hieu
    Firstly no need of apology i understand your busy schedule, and Pyaci is working with server and client when i changed TTL=2 as you said, Thank You very much for getting back to my question and solving it.
    BTW it would be more easier if these info is included in Pyaci instructions itself, so that developers might understand it and it would be less burden on you people.
    I am glad to tell i solved my issue with my code as well with your guidance. Much obliged.
    Regards
    Sai
  • Hello Sai,
    It's excellent to know things are working for you.
    In this particular case, the minimum TTL is a part of the Mesh specification. It is a limit for all Mesh application, not just the PyACI script.
    However, I do agree that it would be nice if there are some comments on the PyACI script code that would remind us of that.
    Yet, the PyACI script and the nRF5 SDK for Mesh are now in maintenance mode, and there likely won't be any change on that. So it will be the state of thing. But we will keep looking out for this kind of improvement in the nRF Connect SDK (NCS), our current solution.
    I recently learn that in NCS, there is the Bluetooth Mesh Shell feature. It is completely different from the PyACI script, but it is capable of the same jobs, and is the recommended solution now. When you have time, please check it out.
    More details on the Mesh Shell feature is going to be a different topic, so I will digress. Please free free to open a new DevZone question if you have any questions about it though.
    Hieu
  • Hello Hieu
    I wanted to express my gratitude for your valuable suggestions and recommendations. I truly appreciate your seamless assistance in addressing my questions. I am particularly interested in trying out the "Bluetooth Mesh Shell Feature" that you mentioned. Once again, thank you for your hard work and support.
    Best Regards
    Sai
