Cannot bind app key for one of the model with PYACI Script
Hello
I am trying to bind app key for one of the models with the help of PYACI Python script. I am using latest version v5.0.0 for PYACI script and downloaded it here: https://github.com/NordicSemiconductor/nRF5-SDK-for-Mesh , also with same version of documentation for commands https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v2.1.1%2Fmd_scripts_interactive_pyaci_README.html.  And I am using Raspberry pi where my py script is running and nRF52840 with Serial Script running connected to Raspberry Pi with Ports /dev/ttyACM0 (or) /dev/ttyACM1. I am trying to bind app key for Sensor_Server Example and i get like this where all the earlier commands works well.
NOTE: examples are connected to Laptop which is obvious where we can run with bluetooth
 I also tried with Mesh Chat sample like above and get same problem
Another Question: we can identify the sample with last model ID where vendor Setup Model ID bound to "0059000a" which is 8 bit and where it should be 4 bit. Even in app i get the same ID
which is ok to setup in app but in this command - cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x1000)) it should have only 4 bit right?
Please help me as soon as possible. I really in need of help to continue my work further
Regards
  • Your parameters order is backwards. 0x0059 is the Company ID for Nordic, and 0x000A is the Vendor Model ID for the Chat Model that Nordic decided.
    See: Chat sample walk-through — nRF Connect SDK 2.3.0 documentation (nordicsemi.com)
  • Oh yes right thank you.
    Could you please post the full log of your attempt, in text form. In addition to the normal steps, each time before you call model_app_bind(), please also you run the following:
    ## This is 1st and 2nd node provisioning ##
    In [1]: db = MeshDB("database/example_database.json")
    In [2]: db.provisioners
    Out[2]: [{'name': 'BT Mesh Provisioner', 'UUID': _UUID(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'), 'allocated_unicast_range': [{'low_address': 0010, 'high_address': 7fff}], 'allocated_group_range': [{'low_address': c000, 'high_address': feff}]}]
    In [3]: p = Provisioner(device, db)
    In [4]: 2023-04-04 21:54:47,078 - INFO - COM6: Success
    2023-04-04 21:54:47,080 - INFO - COM6: Success
    2023-04-04 21:54:47,084 - INFO - COM6: SubnetAdd: {'subnet_handle': 0}
    2023-04-04 21:54:47,088 - INFO - COM6: AppkeyAdd: {'appkey_handle': 0}
    2023-04-04 21:54:47,091 - INFO - COM6: AppkeyAdd: {'appkey_handle': 1}
    In [4]:
    In [4]: p.scan_start()
    2023-04-04 21:54:53,633 - INFO - COM6: Success
    In [5]: 2023-04-04 21:54:53,754 - INFO - COM6: Received UUID 7faea34d1484433380515cb2eb7b8ccc with RSSI: -50 dB
    In [5]:
    In [5]: p.scan_stop()
    2023-04-04 21:55:00,198 - INFO - COM6: Success
    In [6]: p.provision(name="chat")
    In [7]: 2023-04-04 21:55:13,857 - INFO - COM6: Provision: {'context': 0}
    2023-04-04 21:55:13,917 - INFO - COM6: Link established
    2023-04-04 21:55:14,053 - INFO - COM6: Received capabilities
    2023-04-04 21:55:14,054 - INFO - COM6: Number of elements: 1
    2023-04-04 21:55:14,058 - INFO - COM6: OobUse: {'context': 0}
    2023-04-04 21:55:14,311 - INFO - COM6: ECDH request received
    2023-04-04 21:55:14,317 - INFO - COM6: EcdhSecret: {'context': 0}
    2023-04-04 21:55:14,927 - INFO - COM6: Provisioning complete
    2023-04-04 21:55:14,927 - INFO - COM6:  Address(es): 0x10-0x10
    2023-04-04 21:55:14,929 - INFO - COM6:  Device key: REDACTED
    2023-04-04 21:55:14,930 - INFO - COM6:  Network key: REDACTED
    2023-04-04 21:55:14,932 - INFO - COM6: Adding device key to subnet 0
    2023-04-04 21:55:14,932 - INFO - COM6: Adding publication address of root element
    2023-04-04 21:55:14,936 - INFO - COM6: DevkeyAdd: {'devkey_handle': 8}
    2023-04-04 21:55:14,937 - INFO - COM6: AddrPublicationAdd: {'address_handle': 0}
    2023-04-04 21:55:15,105 - INFO - COM6: Provisioning link closed
    In [7]:
    In [7]: cc = ConfigurationClient(db)
    In [8]: device.model_add(cc)
    In [9]: cc.publish_set(8, 0)
    In [10]: cc.composition_data_get()
    In [11]: 2023-04-04 21:55:42,796 - INFO - COM6: PacketSend: {'token': 1}
    2023-04-04 21:55:42,825 - INFO - COM6: {event: MeshTxComplete, data: {'token': 1}}
    In [11]:
    In [11]: cc.composition_data_get()
    In [12]: 2023-04-04 21:55:52,327 - INFO - COM6: PacketSend: {'token': 2}
    2023-04-04 21:55:52,350 - INFO - COM6: {event: MeshTxComplete, data: {'token': 2}}
    2023-04-04 21:55:52,503 - INFO - COM6.ConfigurationClient: Received composition data (page 0x00): {
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": 10,
      "features": {
        "relay": 0,
        "proxy": 0,
        "friend": 0,
        "low_power": 2
      "elements": [
          "index": 0,
          "location": "0001",
          "models": [
              "modelId": "0000"
              "modelId": "0002"
              "modelId": "0059000a"
    In [12]:
    In [12]: cc.appkey_add(0)
    In [13]: 2023-04-04 21:55:55,314 - INFO - COM6: PacketSend: {'token': 3}
    2023-04-04 21:55:55,367 - INFO - COM6: {event: MeshTxComplete, data: {'token': 3}}
    2023-04-04 21:55:55,436 - INFO - COM6.ConfigurationClient: Appkey status: AccessStatus.SUCCESS
    2023-04-04 21:55:55,438 - INFO - COM6.ConfigurationClient: Appkey add 0 succeded for subnet 0 at node 0010
    In [13]:
    In [13]: cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x0059,0x000a))
    In [14]: 2023-04-04 21:56:12,008 - INFO - COM6: PacketSend: {'token': 4}
    2023-04-04 21:56:12,031 - INFO - COM6: {event: MeshTxComplete, data: {'token': 4}}
    2023-04-04 21:56:12,043 - INFO - COM6.ConfigurationClient: Model app bind status: AccessStatus.INVALID_MODEL
    In [14]:
    In [14]: cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x0059,0x000a,0x0059))
    TypeError                                 Traceback (most recent call last)
    Cell In[14], line 1
    ----> 1 cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x0059,0x000a,0x0059))
    TypeError: ModelId.__init__() takes from 2 to 3 positional arguments but 4 were given
    In [15]: cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x000a,0x0059))
    In [16]: 2023-04-04 21:56:40,723 - INFO - COM6: PacketSend: {'token': 5}
    2023-04-04 21:56:40,749 - INFO - COM6: {event: MeshTxComplete, data: {'token': 5}}
    2023-04-04 21:56:40,757 - INFO - COM6.ConfigurationClient: Model app bind status: AccessStatus.SUCCESS
    2023-04-04 21:56:40,761 - INFO - COM6.ConfigurationClient: Appkey bind 0 to model 0059000a at 0010
    In [16]:
    In [16]: p.scan_start()
    2023-04-04 21:57:30,853 - INFO - COM6: Success
    In [17]: 2023-04-04 21:57:35,388 - INFO - COM6: Received UUID 3442243ef35a46a58bbddbc10ca5395a with RSSI: -66 dB
    In [17]:
    In [17]: p.scan_stop()
    2023-04-04 21:57:42,453 - INFO - COM6: Success
    In [18]: p.provision(name="chat1")
    In [19]: 2023-04-04 21:57:54,168 - INFO - COM6: Provision: {'context': 0}
    2023-04-04 21:57:54,245 - INFO - COM6: Link established
    2023-04-04 21:57:54,382 - INFO - COM6: Received capabilities
    2023-04-04 21:57:54,382 - INFO - COM6: Number of elements: 1
    2023-04-04 21:57:54,385 - INFO - COM6: OobUse: {'context': 0}
    2023-04-04 21:57:54,666 - INFO - COM6: ECDH request received
    2023-04-04 21:57:54,674 - INFO - COM6: EcdhSecret: {'context': 0}
    2023-04-04 21:57:57,268 - INFO - COM6: Provisioning complete
    2023-04-04 21:57:57,277 - INFO - COM6:  Address(es): 0x11-0x11
    2023-04-04 21:57:57,282 - INFO - COM6:  Device key: REDACTED
    2023-04-04 21:57:57,286 - INFO - COM6:  Network key: REDACTED
    2023-04-04 21:57:57,288 - INFO - COM6: Adding device key to subnet 0
    2023-04-04 21:57:57,290 - INFO - COM6: Adding publication address of root element
    2023-04-04 21:57:57,294 - INFO - COM6: DevkeyAdd: {'devkey_handle': 9}
    2023-04-04 21:57:57,297 - INFO - COM6: AddrPublicationAdd: {'address_handle': 1}
    2023-04-04 21:57:57,445 - INFO - COM6: Provisioning link closed
    In [19]:
    In [19]: cc.publish_set(9, 1)
    In [20]: cc.composition_data_get()
    In [21]: 2023-04-04 21:58:10,288 - INFO - COM6: PacketSend: {'token': 6}
    2023-04-04 21:58:10,313 - INFO - COM6: {event: MeshTxComplete, data: {'token': 6}}
    In [21]: cc.composition_data_get()
    In [22]: 2023-04-04 21:58:18,670 - INFO - COM6: PacketSend: {'token': 7}
    2023-04-04 21:58:18,693 - INFO - COM6: {event: MeshTxComplete, data: {'token': 7}}
    2023-04-04 21:58:18,847 - INFO - COM6.ConfigurationClient: Received composition data (page 0x00): {
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": 10,
      "features": {
        "relay": 0,
        "proxy": 0,
        "friend": 0,
        "low_power": 2
      "elements": [
          "index": 0,
          "location": "0001",
          "models": [
              "modelId": "0000"
              "modelId": "0002"
    In [22]:
    In [22]: cc.appkey_add(0)
    In [23]: 2023-04-04 21:58:22,615 - INFO - COM6: PacketSend: {'token': 8}
    2023-04-04 21:58:22,681 - INFO - COM6: {event: MeshTxComplete, data: {'token': 8}}
    2023-04-04 21:58:22,753 - INFO - COM6.ConfigurationClient: Appkey status: AccessStatus.SUCCESS
    2023-04-04 21:58:22,755 - INFO - COM6.ConfigurationClient: Appkey add 0 succeded for subnet 0 at node 0011
    In [23]:
    In [23]: cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x0059,0x000a))
    In [24]: 2023-04-04 21:58:34,760 - INFO - COM6: PacketSend: {'token': 9}
    2023-04-04 21:58:34,791 - INFO - COM6: {event: MeshTxComplete, data: {'token': 9}}
    2023-04-04 21:58:34,804 - INFO - COM6.ConfigurationClient: Model app bind status: AccessStatus.INVALID_ADDRESS
    In [24]:
    In [24]: cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x000a,0x0059))
    In [25]: 2023-04-04 21:58:50,665 - INFO - COM6: PacketSend: {'token': 10}
    2023-04-04 21:58:50,686 - INFO - COM6: {event: MeshTxComplete, data: {'token': 10}}
    2023-04-04 21:58:50,694 - INFO - COM6.ConfigurationClient: Model app bind status: AccessStatus.INVALID_ADDRESS
    In [25]:
    In [25]: cc.model_app_bind(db.nodes[1].unicast_address + 1, 0, mt.ModelId(0x000a,0x0059))
    In [26]: 2023-04-04 22:01:04,558 - INFO - COM6: PacketSend: {'token': 11}
    2023-04-04 22:01:04,580 - INFO - COM6: {event: MeshTxComplete, data: {'token': 11}}
    2023-04-04 22:01:04,592 - INFO - COM6.ConfigurationClient: Model app bind status: AccessStatus.INVALID_ADDRESS
    In [26]:
    In [26]: cc.model_app_bind(db.nodes[0].unicast_address + 1, 0, mt.ModelId(0x000a,0x0059))
    In [27]: 2023-04-04 22:01:14,926 - INFO - COM6: PacketSend: {'token': 12}
    2023-04-04 22:01:14,952 - INFO - COM6: {event: MeshTxComplete, data: {'token': 12}}
    2023-04-04 22:01:14,962 - INFO - COM6.ConfigurationClient: Model app bind status: AccessStatus.SUCCESS
    2023-04-04 22:01:14,964 - INFO - COM6.ConfigurationClient: Appkey bind 0 to model 0059000a at 0011
    ## This is 3rd node provisioning ##
    In [4]: 2023-04-04 22:19:31,223 - INFO - COM6: Success
    2023-04-04 22:19:31,225 - INFO - COM6: Success
    2023-04-04 22:19:31,229 - INFO - COM6: SubnetAdd: {'subnet_handle': 0}
    2023-04-04 22:19:31,233 - INFO - COM6: AppkeyAdd: {'appkey_handle': 0}
    2023-04-04 22:19:31,237 - INFO - COM6: AppkeyAdd: {'appkey_handle': 1}
    In [4]:
    2023-04-04 22:19:42,574 - INFO - COM6: Success
    In [5]: 2023-04-04 22:19:44,391 - INFO - COM6: Received UUID 3442243ef35a46a58bbddbc10ca5395a with RSSI: -57 dB
    In [5]:
    2023-04-04 22:19:52,264 - INFO - COM6: Success
    In [6]: p.provision(name="chat2")
    In [7]: 2023-04-04 22:20:23,601 - INFO - COM6: Provision: {'context': 0}
    2023-04-04 22:20:23,676 - INFO - COM6: Link established
    2023-04-04 22:20:23,813 - INFO - COM6: Received capabilities
    2023-04-04 22:20:23,813 - INFO - COM6: Number of elements: 1
    2023-04-04 22:20:23,816 - INFO - COM6: OobUse: {'context': 0}
    2023-04-04 22:20:26,155 - INFO - COM6: ECDH request received
    2023-04-04 22:20:26,163 - INFO - COM6: EcdhSecret: {'context': 0}
    2023-04-04 22:20:26,760 - INFO - COM6: Provisioning complete
    2023-04-04 22:20:26,760 - INFO - COM6:  Address(es): 0x12-0x12
    2023-04-04 22:20:26,761 - INFO - COM6:  Device key: REDACTED
    2023-04-04 22:20:26,761 - INFO - COM6:  Network key: REDACTED
    2023-04-04 22:20:26,763 - INFO - COM6: Adding device key to subnet 0
    2023-04-04 22:20:26,764 - INFO - COM6: Adding publication address of root element
    2023-04-04 22:20:26,768 - INFO - COM6: DevkeyAdd: {'devkey_handle': 8}
    2023-04-04 22:20:26,769 - INFO - COM6: AddrPublicationAdd: {'address_handle': 0}
    2023-04-04 22:20:26,930 - INFO - COM6: Provisioning link closed
    In [7]:
    In [11]: 2023-04-04 22:29:09,505 - INFO - COM6: PacketSend: {'token': 1}
    2023-04-04 22:29:09,534 - INFO - COM6: {event: MeshTxComplete, data: {'token': 1}}
    2023-04-04 22:29:09,686 - INFO - COM6.ConfigurationClient: Received composition data (page 0x00): {
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": 10,
      "features": {
        "relay": 0,
        "proxy": 0,
        "friend": 0,
        "low_power": 2
      "elements": [
          "index": 0,
          "location": "0001",
          "models": [
              "modelId": "0000"
              "modelId": "0002"
    In [11]:
    In [11]: cc.appkey_add(0)
    In [12]: 2023-04-04 22:29:21,802 - INFO - COM6: PacketSend: {'token': 2}
    2023-04-04 22:29:21,863 - INFO - COM6: {event: MeshTxComplete, data: {'token': 2}}
    2023-04-04 22:29:21,933 - INFO - COM6.ConfigurationClient: Appkey status: AccessStatus.SUCCESS
    2023-04-04 22:29:21,936 - INFO - COM6.ConfigurationClient: Appkey add 0 succeded for subnet 0 at node 0012
    In [12]:
    In [12]: len(db.nodes)
    Out[12]: 3
    In [13]: db.nodes[0]
    Out[13]: {'UUID': _UUID(b'\x7f\xae\xa3M\x14\x84C3\x80Q\\\xb2\xeb{\x8c\xcc'), 'device_key': Key(REDACTED), 'unicast_address': 0010, 'net_keys': [{'index': 0}], 'config_complete': False, 'name': 'chat', 'security': <SecurityLevel.LOW: 'low'>, 'cid': 0059, 'vid': 0000, 'pid': 0000, 'crpl': 000a, 'features': {'relay': <FeatureState.DISABLED: 0>, 'proxy': <FeatureState.DISABLED: 0>, 'friend': <FeatureState.DISABLED: 0>, 'low_power': <FeatureState.NOT_SUPPORTED: 2>}, 'elements': [{'index': 0, 'location': 0001, 'models': [{'model_id': 0000, 'subscribe': [], 'publish': None, 'bind': []}, {'model_id': 0002, 'subscribe': [], 'publish': None, 'bind': []}, {'model_id': 0059000a, 'subscribe': [], 'publish': None, 'bind': [0]}], 'name': ''}], 'app_keys': [0], 'secure_network_beacon': None, 'network_transmit': None, 'relay_retransmit': None, 'default_TTL': None}
    In [14]: db.nodes[1]
    Out[14]: {'UUID': _UUID(b'4B$>\xf3ZF\xa5\x8b\xbd\xdb\xc1\x0c\xa59Z'), 'device_key': Key(REDACTED), 'unicast_address': 0011, 'net_keys': [{'index': 0}], 'config_complete': False, 'name': 'chat1', 'security': <SecurityLevel.LOW: 'low'>, 'cid': 0059, 'vid': 0000, 'pid': 0000, 'crpl': 000a, 'features': {'relay': <FeatureState.DISABLED: 0>, 'proxy': <FeatureState.DISABLED: 0>, 'friend': <FeatureState.DISABLED: 0>, 'low_power': <FeatureState.NOT_SUPPORTED: 2>}, 'elements': [{'index': 0, 'location': 0001, 'models': [{'model_id': 0000, 'subscribe': [], 'publish': None, 'bind': []}, {'model_id': 0002, 'subscribe': [], 'publish': None, 'bind': []}, {'model_id': 0059000a, 'subscribe': [], 'publish': None, 'bind': [0]}], 'name': ''}], 'app_keys': [0], 'secure_network_beacon': None, 'network_transmit': None, 'relay_retransmit': None, 'default_TTL': None}
    In [15]: db.nodes[2]
    Out[15]: {'UUID': _UUID(b'4B$>\xf3ZF\xa5\x8b\xbd\xdb\xc1\x0c\xa59Z'), 'device_key': Key(REDACTED), 'unicast_address': 0012, 'net_keys': [{'index': 0}], 'config_complete': False, 'name': 'chat2', 'security': <SecurityLevel.LOW: 'low'>, 'cid': 0059, 'vid': 0000, 'pid': 0000, 'crpl': 10, 'features': {'relay': <FeatureState.DISABLED: 0>, 'proxy': <FeatureState.DISABLED: 0>, 'friend': <FeatureState.DISABLED: 0>, 'low_power': <FeatureState.NOT_SUPPORTED: 2>}, 'elements': [{'index': 0, 'location': 0001, 'models': [{'model_id': 0000, 'subscribe': [], 'publish': None, 'bind': []}, {'model_id': 0002, 'subscribe': [], 'publish': None, 'bind': []}, {'model_id': 0059000a, 'subscribe': [], 'publish': None, 'bind': []}], 'name': ''}], 'app_keys': [0], 'secure_network_beacon': None, 'network_transmit': None, 'relay_retransmit': None, 'default_TTL': None}
    In [16]:
    ## This is 3 nodes database file ##
      "$schema": "",
      "appKeys": [
          "boundNetKey": 0,
          "index": 0,
          "key": "REDACTED",
          "name": "lights"
          "boundNetKey": 0,
          "index": 1,
          "key": "REDACTED",
          "name": "locks"
      "groups": [
          "address": 49153,
          "name": "Room 1",
          "parentAddress": 0
          "address": 49154,
          "name": "Room 2",
          "parentAddress": 0
      "ivIndex": 0,
      "ivUpdate": 0,
      "meshName": "BT Mesh",
      "meshUUID": "01020304050607080102030405060708",
      "netKeys": [
          "index": 0,
          "key": "REDACTED",
          "minSecurity": "low",
          "name": "root",
          "phase": 0
      "nodes": [
          "UUID": "7faea34d1484433380515cb2eb7b8ccc",
          "appKeys": [
            0
          "cid": "0059",
          "configComplete": false,
          "crpl": "000a",
          "deviceKey": "REDACTED",
          "elements": [
              "index": 0,
              "location": "0001",
              "models": [
                  "modelId": "0000"
                  "modelId": "0002"
                  "bind": [
                    0
          "features": {
            "friend": 0,
            "lowPower": 2,
            "proxy": 0,
            "relay": 0
          "name": "chat",
          "netKeys": [
            0
          "pid": "0000",
          "security": "low",
          "unicastAddress": 16,
          "vid": "0000"
          "UUID": "3442243ef35a46a58bbddbc10ca5395a",
          "appKeys": [
            0
          "cid": "0059",
          "crpl": "000a",
          "elements": [
              "index": 0,
              "location": "0001",
              "models": [
                  "modelId": "0000"
                  "modelId": "0002"
                  "bind": [
                    0
          "features": {
            "friend": 0,
            "lowPower": 2,
            "proxy": 0,
            "relay": 0
          "name": "chat1",
          "netKeys": [
            0
          "pid": "0000",
          "security": "low",
          "unicastAddress": 17,
          "vid": "0000"
          "appKeys": [
            0
          "cid": "0059",
          "crpl": 10,
          "elements": [
              "index": 0,
              "location": "0001",
              "models": [
                  "modelId": "0000"
                  "modelId": "0002"
          "features": {
            "friend": 0,
            "lowPower": 2,
            "proxy": 0,
            "relay": 0
          "name": "chat2",
          "netKeys": [
            0
          "pid": "0000",
          "security": "low",
          "unicastAddress": 18,
          "vid": "0000"
      "provisioners": [
          "UUID": "00000000000000000000000000000000",
          "allocatedGroupRange": [
              "highAddress": 65279,
              "lowAddress": 49152
          "allocatedUnicastRange": [
              "highAddress": 32767,
              "lowAddress": 16
          "name": "BT Mesh Provisioner"
      "timestamp": "2023-04-04 22:29:21.933455"
    uploaded all three nodes log and also database file looks like all three nodes also taking index "0".
    Regards
  • I have added some comments into your log. Please look at them. I think you must be majorly confused. Please slow down and try to understand each of the functions you are using in the script.\
    In [4]:
    In [5]:
    In [7]:
    In [11]:
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": 10,
      "features": {
        "relay": 0,
        "proxy": 0,
        "friend": 0,
        "low_power": 2
      "elements": [
          "index": 0,
          "location": "0001",
          "models": [
              "modelId": "0000"
              "modelId": "0002"
    In [12]:
    In [13]:
    // Hieu: Expectation: Working with node addr 0x0010, model (0x000a, 0x0059)
    //		 So this command will result in invalid model
    // Hieu: As expected
    In [14]:
    Cell In[14], line 1
    //		 So this command should succeed
    In [16]:
    In [17]:
    In [19]:
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": 10,
      "features": {
        "relay": 0,
        "proxy": 0,
        "friend": 0,
        "low_power": 2
      "elements": [
          "index": 0,
          "location": "0001",
          "models": [
              "modelId": "0000"
              "modelId": "0002"
    In [22]:
    In [23]:
    // Hieu: Expectation: Working with node addr 0x0011, model (0x000a, 0x0059)
    //		 So this command should result in invalid address, because db.nodes[0].unicast_address is 0x0010
    // As expected
    In [24]:
    In [25]:
    // As expected
    //		 So this command should result in invalid address, because db.nodes[1].unicast_address+1 is 0x0012
    // As expected
    In [26]:
    //		 So this command should succeed EVEN THOUGH IT IS MALFORMED, because db.nodes[0].unicast_address+1 is still 0x0011
    // As expected
    In [4]:
    In [5]:
    In [7]:
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": 10,
      "features": {
        "relay": 0,
        "proxy": 0,
        "friend": 0,
        "low_power": 2
      "elements": [
          "index": 0,
          "location": "0001",
          "models": [
              "modelId": "0000"
              "modelId": "0002"
    In [11]:
    In [12]:
    Out[12]: 3
    In [16]:
      "$schema": "",
      "appKeys": [
          "boundNetKey": 0,
          "index": 0,
          "key": "REDACTED",
          "name": "lights"
          "boundNetKey": 0,
          "index": 1,
          "key": "REDACTED",
          "name": "locks"
      "groups": [
          "address": 49153,
          "name": "Room 1",
          "parentAddress": 0
          "address": 49154,
          "name": "Room 2",
          "parentAddress": 0
      "ivIndex": 0,
      "ivUpdate": 0,
      "netKeys": [
          "index": 0,
          "key": "REDACTED",
          "name": "root",
          "phase": 0
      "nodes": [
          "appKeys": [
            0
          "cid": "0059",
          "crpl": "000a",
          "elements": [
              "index": 0,
              "location": "0001",
              "models": [
                  "modelId": "0000"
                  "modelId": "0002"
                  "bind": [
                    0
          "features": {
            "friend": 0,
            "lowPower": 2,
            "proxy": 0,
            "relay": 0
          "name": "chat",
          "netKeys": [
            0
          "pid": "0000",
          "security": "low",
          "vid": "0000"
          "appKeys": [
            0
          "cid": "0059",
          "crpl": "000a",
          "elements": [
              "index": 0,
              "location": "0001",
              "models": [
                  "modelId": "0000"
                  "modelId": "0002"
                  "bind": [
                    0
          "features": {
            "friend": 0,
            "lowPower": 2,
            "proxy": 0,
            "relay": 0
          "name": "chat1",
          "netKeys": [
            0
          "pid": "0000",
          "security": "low",
          "vid": "0000"
          "appKeys": [
            0
          "cid": "0059",
          "crpl": 10,
          "elements": [
              "index": 0,
              "location": "0001",
              "models": [
                  "modelId": "0000"
                  "modelId": "0002"
          "features": {
            "friend": 0,
            "lowPower": 2,
            "proxy": 0,
            "relay": 0
          "name": "chat2",
          "netKeys": [
            0
          "pid": "0000",
          "security": "low",
          "vid": "0000"
      "provisioners": [
              "lowAddress": 49152
              "lowAddress": 16
    Please be informed that I will be out of office (actually from today) and return Tuesday Apr 11 for the Easter holiday.
    Hieu
  • Hello Hieu,
    It works! Thank You so much for your effort and help. one last question: how to chat private with mesh chat example when i provision with PyACI script? where to find the node address?
    Regards
  • Hi Sai,
    You can find it in the provisioning output:
    If your node has more than one element, it will be given an address range, one unicast address for each element.
    (It's in this case that you use db.nodes[idx]+0 to address element 0, db.nodes[idx]+1 to address element 1, etc.)
    The element addressing is only of concerns if you modify the Mesh Chat sample to have more elements. By default, it only has one element.
    Hieu
