I'm using nRF Connect SDK v2.2.0 and the central_bas sample project with MCUBoot in serial recovery to implement a firmware update functionality for a custom board. I got it to run on my board and got output via UART. Also mcumgr commands like "image list" were working fine.
Yesterday I came back into office after a break and everytime I send "image list" to my board, I get an NMP timeout.
Now I tried the sample project on an nRF5340DK but I got the same result. If I change my configuration so that mcumgr works via UART (CONFIG_MCUMGR=y and CONFIG_MCUMGR_SMP_UART=y) it works perfectly fine. The used connection string for mcumgr is:
mcumgr conn add nrf53 type="serial" connstring="dev=COM5,baud=115200,mtu=512" mcumgr -c nrf53 image list
Was there an update to the SDK or nRF Connect for VS Code that broke some functionality? Can anyone reproduce this issue?
Alex
prj.conf of central_bas:
# # Copyright (c) 2019 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_BT=y CONFIG_BT_DEBUG_LOG=y CONFIG_BT_CENTRAL=y CONFIG_BT_SMP=y CONFIG_BT_GATT_CLIENT=y CONFIG_BT_GATT_DM=y CONFIG_HEAP_MEM_POOL_SIZE=1024 CONFIG_BT_BAS_CLIENT=y CONFIG_BT_SCAN=y CONFIG_BT_SCAN_FILTER_ENABLE=y CONFIG_BT_SCAN_UUID_CNT=1 CONFIG_BT_PRIVACY=y CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y CONFIG_DK_LIBRARY=y ### Added first-stage bootloader ### CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0+1" # maj.min.rev+build ### Some command handlers require a large stack. Important for mcumgr, would otherwise timeout CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 ### From UART example ### CONFIG_UART_ASYNC_API=y CONFIG_NRFX_UARTE0=y CONFIG_UART_0_ASYNC=y CONFIG_SERIAL=y
prj.conf of MCUBoot:
CONFIG_PM=n CONFIG_MAIN_STACK_SIZE=10240 CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h" CONFIG_BOOT_SWAP_SAVE_ENCTLV=n CONFIG_BOOT_ENCRYPT_RSA=n CONFIG_BOOT_ENCRYPT_EC256=n CONFIG_BOOT_ENCRYPT_X25519=n CONFIG_BOOT_UPGRADE_ONLY=n CONFIG_BOOT_BOOTSTRAP=n ### mbedTLS has its own heap # CONFIG_HEAP_MEM_POOL_SIZE is not set ### We never want Zephyr's copy of tinycrypt. If tinycrypt is needed, ### MCUboot has its own copy in tree. # CONFIG_TINYCRYPT is not set # CONFIG_TINYCRYPT_ECC_DSA is not set # CONFIG_TINYCRYPT_SHA256 is not set CONFIG_FLASH=y CONFIG_FPROTECT=y ### Various Zephyr boards enable features that we don't want. # CONFIG_BT is not set # CONFIG_BT_CTLR is not set # CONFIG_I2C is not set CONFIG_LOG=y CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL ### Ensure Zephyr logging changes don't use more resources CONFIG_LOG_DEFAULT_LEVEL=0 ### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y CONFIG_CBPRINTF_NANO=y CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0 ### Added for serial recovery ### CONFIG_MCUBOOT_SERIAL=y CONFIG_BOOT_SERIAL_UART=y ### Only CONFIG_UART_CONSOLE=n should be necessary CONFIG_UART_CONSOLE=n #CONFIG_CONSOLE=n #CONFIG_CONSOLE_HANDLER=n ### Enable wait for serial recovery ### CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=y CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=1500
