I need to upgrade firmware with MCUBoot (buttonless). I have read these tutorials:
I have a nrf52840dk and working with ncs v2.2.0 and my limitation is that I have to use the J3 USB connector.
If I follow the steps provided in the first tutorial (SMP_Server), I can build the sample with the next command:
west build -p -b nrf52840dk_nrf52840 zephyr/samples/subsys/mgmt/mcumgr/smp_svr -- -DOVERLAY_CONFIG=overlay-cdc.conf -DDTC_OVERLAY_FILE=usb.overlay
I can acces to mcumgr through J3 usb connector:
mcumgr --conntype serial --connstring "/dev/ttyACM0,baud=115200" echo hello hello
So now I can go to the second tutorial I provided. There I can see how to modify a sample to be uploaded to the board. I just have to add to the prj.conf:
# Enable mcumgr. CONFIG_MCUMGR=y # Enable most core commands. CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_MCUMGR_CMD_OS_MGMT=y # Ensure an MCUboot-compatible binary is generated. CONFIG_BOOTLOADER_MCUBOOT=y # Enable the serial mcumgr transport. CONFIG_MCUMGR_SMP_UART=y # Disable UART Console and enable the RTT console CONFIG_UART_CONSOLE=n CONFIG_RTT_CONSOLE=y CONFIG_USE_SEGGER_RTT=y # Some command handlers require a large stack. CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
And add in the main the next code:
#include "os_mgmt/os_mgmt.h" #include "img_mgmt/img_mgmt.h" #inside main os_mgmt_register_group(); img_mgmt_register_group();
So now I can compile a blinky sample with that modification and I can upgrade my board with the blinky sample. The problem is that once the board is updated, the J3 usb connector is not available anymore.
I decided to modify the blinky sample to be FLASHED and that the J3 usb port is available. So the first step was include in the building command the same overlay-cdc.conf and usb.overlay that are included in the SMP_Server sample.
I modified the main.c file too, because in the last post of this thread tell that the USB has to be initialized, including:
#include <zephyr/usb/usb_device.h>
//inside main
if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
int rc = usb_enable(NULL);
if (rc) {
LOG_ERR("Failed to enable USB");
return;
And obviously the prj.conf is modified too:
CONFIG_GPIO=y # Enable mcumgr. CONFIG_MCUMGR=y # Enable most core commands. CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_MCUMGR_CMD_OS_MGMT=y # Ensure an MCUboot-compatible binary is generated. CONFIG_BOOTLOADER_MCUBOOT=y # Enable the serial mcumgr transport. CONFIG_MCUMGR_SMP_UART=y # Disable UART Console and enable the RTT console CONFIG_UART_CONSOLE=n CONFIG_RTT_CONSOLE=y CONFIG_USE_SEGGER_RTT=y # Some command handlers require a large stack. CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
When I build and flash into my DK board I can see the J3 port available (ls /dev/tty*), but mcumgr is nos responding. What more should I add from the SMP_Server sample to my blinky project to enable mcumgr?
I attach the project in the case you want to check something:
