Hi everyone, I'm trying to create a ble app uart coexist example to nrf52840. However after I add everything like this thread and the existing example on nrf52832, I'm running to this problems below.
This is in the model_common.c
First of all, if you've recently started developing your application and are relatively new to developing with Nordic Semiconductor SDKs, we recommend you start with nRF Connect SDK instead of nRF5 SDK due to the nRF5 SDK being in maintenance mode. Let me know if you need any pointers on getting started with nRF Connect SDK.
In addition to whats under Including nRF5 SDK for Mesh functionality in an nRF5 SDK example you will also need to add the changes in the other sections to your environment, and adding the changes in the first section does not work.
Another reason for why you're getting that error might be due to interrupt-priorities might not be set correct. There might be some pointers at infocenter.nordicsemi.com/index.jsp
Let me know if this clarifies your questions,
Andreas
