Target Wake Time (TWT) on nRF7002-DK is not working properly
I wrote an application based on the wifi-sta sample to test the Target Wake Time (TWT) feature and measure the current consumption while the nRF7002 is in sleep mode.
My test-setup consists of one nRF7002-DK operating as "Wifi-sta" and one Fritz!Box 7530 AX operating as "Wifi-AP" and a power porfiler kit II to measure the current.
A udp-server was implemented in the application so that the station receives incoming messages from a udp-client (PC) over the Wifi 6 network created by the Wifi-AP ( Fritz!Box 7530 AX ).
The station (nRF7002-DK) was able to connect to the network and receive messages from the udp client.
But when the TWT mode is activated the station (nRF7002-DK) does not receive any messages from the udp-client .
In the next photo you can see the current consumption of the nRF7002 (PPK is connected to P23 on the DK).
As you can see the nRF7002 goes to sleep for the amount of time which was set (wifi twt setup 0 0 1 1 0 0 0 0 150 2000) which is a good indicator but the station does not receive the messages any more form the udp-client !
When i deactivate the TWT feature by (wifi twt teardown_all) the station will be able to receive messages again from the udp cleint.
So, Why cant the station receive messages when the TWT mode is active?
I also repeated the test with different settings for the TWT like:
wifi twt setup 0 0 1 1 1 1 1 1 100 2000
wifi twt setup 0 0 1 1 1 1 0 1 255 2000
wifi twt setup 0 0 1 1 1 1 0 1 255 300
wifi twt setup 1 0 1 1 1 1 0 1 255 300
wifi twt setup 1 0 1 1 0 0 0 0 255 300
wifi twt setup 2 0 1 1 1 1 0 1 200 300
But the result is the same.
No messages were received when the TWT mode is active.
I would be very thankful if you could provide me with solutions or ideas to solve this problem!
Best regards
Tareq
  • Hi Tareq,
    Could you verify that you have correct PPK2 setup as shown in power profiling?
    Have you checked if your Wi-Fi AP fully supports TWT?
    Could you provide more information about your application?
    Have you tried using "wifi twt teardown 0 0 x x" instead of "wifi twt teardown_all"?
    Dejan
  • Hi Dejon
    Thank for your reply.
    I have connected the PPK2 as shown in power profiling and set the parameters of the TWT like:
    wifi twt setup 0 0 1 1 0 1 1 1 65  60000
    As you can see the current consumption is around 13.57µA when the nrf7002 is in sleep mode and around 79µA as average for the TWT-intervall 1min.
    When i try now to send messages from the computer to the station (nrf7002 dk) via UDP the station will not receive any messages!
    When i try to use "wifi twt teardown 0 0 1 1" it works. ( i mean the TWT session will be teared down)
    After that when i try again to send messages from the computer to the station (nrf7002 dk) via UDP the station will receive the messages successfully without any problems.
    This is shown in the next image:
    So, the problem is that the station does not receive the messages when the TWT is activated! Have you checked if your Wi-Fi AP fully supports TWT?
    As AP i am using the fritzbox-7590-ax https://en.avm.de/products/fritzbox/fritzbox-7590-ax/technical-specifications/
    As described in the "technical-specifications" it should support the Wi-Fi 6 (802.11ax) protocol. I i guess that means it should support the TWT feature.
    Below you can find the code of the project.
    Best regards
    Tareq
    prj.conf
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF700X=y
    #CONFIG_NRF700X_REV_A=y
    # WPA supplicant
    CONFIG_WPA_SUPP=y
    CONFIG_NET_L2_WIFI_SHELL=y
    # Below configs need to be modified based on security
    CONFIG_STA_SAMPLE_SSID="wifi6test"
    CONFIG_STA_SAMPLE_PASSWORD="wifi6test"
    CONFIG_STA_KEY_MGMT_WPA2=y
    # System settings
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_NANO=n
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_POSIX_API=n
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_NET_LOG=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_UDP=y
    CONFIG_NET_TCP=y
    CONFIG_NET_DHCPV4=y
    CONFIG_NET_PKT_RX_COUNT=8
    CONFIG_NET_PKT_TX_COUNT=8
    # Below section is the primary contributor to SRAM and is currently
    # tuned for performance, but this will be revisited in the future.
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NET_BUF_DATA_SIZE=128
    CONFIG_HEAP_MEM_POOL_SIZE=153600
    CONFIG_NET_TC_TX_COUNT=0
    CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_MAX_CONTEXTS=5
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_INIT_STACKS=y
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_NET_CONFIG_SETTINGS=y
    CONFIG_NET_SOCKETS_POLL_MAX=4
    # Memories
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_NET_RX_STACK_SIZE=4096
    # Debugging
    CONFIG_STACK_SENTINEL=y
    CONFIG_DEBUG_COREDUMP=y
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
    CONFIG_SHELL_CMDS_RESIZE=n
    # Kernel options
    CONFIG_ENTROPY_GENERATOR=y
    # Logging
    CONFIG_LOG=y
    CONFIG_PRINTK=y
    CONFIG_POSIX_CLOCK=y
    CONFIG_NET_MGMT_EVENT_STACK_SIZE=2048
    CONFIG_SHELL=y
    CONFIG_SHELL_GETOPT=y
    CONFIG_DEVICE_SHELL=y
    CONFIG_DATE_SHELL=y
    main.c
    LOG_MODULE_REGISTER(sta, LOG_LEVEL_DBG);
    #include <nrfx_clock.h>
    #include <zephyr/kernel.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <zephyr/shell/shell.h>
    #include <zephyr/init.h>
    #include <zephyr/net/net_if.h>
    #include <zephyr/net/wifi_mgmt.h>
    #include <zephyr/net/net_event.h>
    #include <zephyr/net/socket.h>
    #include <zephyr/net/net_mgmt.h>
    #include <zephyr/net/net_ip.h>
    #include <zephyr/net/udp.h>
    #include "net_private.h"
    #define WIFI_SHELL_MODULE "wifi"
    #define WIFI_SHELL_MGMT_EVENTS (NET_EVENT_WIFI_CONNECT_RESULT |        \
                    NET_EVENT_WIFI_DISCONNECT_RESULT)
    #define MAX_SSID_LEN        32
    // IP adresse of the server(Receiver)
    #define IP_ADDR "192.168.178.22"
    #define IP_ADDR_client "192.168.178.22"
    #define IP_ADDR_server "192.168.178.21"
    static struct net_mgmt_event_callback wifi_shell_mgmt_cb;
    static struct net_mgmt_event_callback net_shell_mgmt_cb;
    static struct {
        const struct shell *sh;
        union {
            struct {
                uint8_t disconnecting    : 1;
                uint8_t _unused        : 6;
            uint8_t all;
    } context;
    #define PORT     1337
    #define MAXLINE 1024
    // Driver code
    int udp_server(void) {
        int sockfd;
        char buffer[MAXLINE];
        char *hello = "Hello from server";
        struct sockaddr_in servaddr, cliaddr;
        // Creating socket file descriptor
        if ( (sockfd = socket(AF_INET, SOCK_DGRAM, 0)) < 0 ) {
            LOG_ERR("socket creation failed");
            return -errno;
        memset(&servaddr, 0, sizeof(servaddr));
        memset(&cliaddr, 0, sizeof(cliaddr));
        // Filling server information
        servaddr.sin_family = AF_INET; // IPv4
        servaddr.sin_addr.s_addr = INADDR_ANY;
        servaddr.sin_port = htons(PORT);
        // Bind the socket with the server address
        if ( bind(sockfd, (const struct sockaddr *)&servaddr,
                sizeof(servaddr)) < 0 )
            LOG_ERR("bind failed");
            return -errno;
        int len, n;
        len = sizeof(cliaddr); //len is value/result
        while(true) {
            n = recvfrom(sockfd, (char *)buffer, MAXLINE,
                        MSG_WAITALL, ( struct sockaddr *) &cliaddr,
                        &len);
            buffer[n] = '\0';
            printf("Client : %s\n", buffer);
            // If you want to send a response to the sender
            //sendto(sockfd, (const char *)hello, strlen(hello),0, (const struct sockaddr *) &cliaddr,&len);
            //buffer[n] = '\0';
        return 0;
    static int cmd_wifi_status(void)
        struct net_if *iface = net_if_get_default();
        struct wifi_iface_status status = { 0 };
        if (net_mgmt(NET_REQUEST_WIFI_IFACE_STATUS, iface, &status,
                    sizeof(struct wifi_iface_status))) {
            printk("Status request failed\n");
            return -ENOEXEC;
        printk("Status: successful\n");
        printk("==================\n");
        printk("State: %s\n", wifi_state_txt(status.state));
        if (status.state >= WIFI_STATE_ASSOCIATED) {
            uint8_t mac_string_buf[sizeof("xx:xx:xx:xx:xx:xx")];
            printk("Interface Mode: %s\n",
                   wifi_mode_txt(status.iface_mode));
            printk("Link Mode: %s\n",
                   wifi_link_mode_txt(status.link_mode));
            printk("SSID: %-32s\n", status.ssid);
            printk("BSSID: %s\n",
                   net_sprint_ll_addr_buf(
                    status.bssid, WIFI_MAC_ADDR_LEN,
                    mac_string_buf, sizeof(mac_string_buf)));
            printk("Band: %s\n", wifi_band_txt(status.band));
            printk("Channel: %d\n", status.channel);
            printk("Security: %s\n", wifi_security_txt(status.security));
            printk("MFP: %s\n", wifi_mfp_txt(status.mfp));
            printk("RSSI: %d\n", status.rssi);
        return 0;
    static void handle_wifi_connect_result(struct net_mgmt_event_callback *cb)
        const struct wifi_status *status =
            (const struct wifi_status *) cb->info;
        if (status->status) {
            LOG_ERR("Connection request failed (%d)", status->status);
        } else {
            LOG_INF("Connected");
        cmd_wifi_status();
    static void handle_wifi_disconnect_result(struct net_mgmt_event_callback *cb)
        if (context.disconnecting) {
            LOG_INF("Disconnection request %s (%d)",
                 status->status ? "failed" : "done",
                        status->status);
            context.disconnecting = false;
        } else {
            LOG_INF("Disconnected");
        cmd_wifi_status();
    static void wifi_mgmt_event_handler(struct net_mgmt_event_callback *cb,
                         uint32_t mgmt_event, struct net_if *iface)
        switch (mgmt_event) {
        case NET_EVENT_WIFI_CONNECT_RESULT:
            handle_wifi_connect_result(cb);
        case NET_EVENT_WIFI_DISCONNECT_RESULT:
            handle_wifi_disconnect_result(cb);
    static void print_dhcp_ip(struct net_mgmt_event_callback *cb)
        /* Get DHCP info from struct net_if_dhcpv4 and print */
        const struct net_if_dhcpv4 *dhcpv4 = cb->info;
        const struct in_addr *addr = &dhcpv4->requested_ip;
        char dhcp_info[128];
        net_addr_ntop(AF_INET, addr, dhcp_info, sizeof(dhcp_info));
        LOG_INF("IP address: %s", dhcp_info);
    static void net_mgmt_event_handler(struct net_mgmt_event_callback *cb,
        case NET_EVENT_IPV4_DHCP_BOUND:
            print_dhcp_ip(cb);
    static int __wifi_args_to_params(struct wifi_connect_req_params *params)
        params->timeout = SYS_FOREVER_MS;
        /* SSID */
        params->ssid = CONFIG_STA_SAMPLE_SSID;
        params->ssid_length = strlen(params->ssid);
    #if defined(CONFIG_STA_KEY_MGMT_WPA2)
        params->security = 1;
    #elif defined(CONFIG_STA_KEY_MGMT_WPA2_256)
        params->security = 2;
    #elif defined(CONFIG_STA_KEY_MGMT_WPA3)
        params->security = 3;
    #else
        params->security = 0;
    #if !defined(CONFIG_STA_KEY_MGMT_NONE)
        params->psk = CONFIG_STA_SAMPLE_PASSWORD;
        params->psk_length = strlen(params->psk);
        params->channel = WIFI_CHANNEL_ANY;
        /* MFP (optional) */
        params->mfp = WIFI_MFP_OPTIONAL;
        return 0;
    static int wifi_connect(void)
        static struct wifi_connect_req_params cnx_params;
        __wifi_args_to_params(&cnx_params);
        if (net_mgmt(NET_REQUEST_WIFI_CONNECT, iface,
                 &cnx_params, sizeof(struct wifi_connect_req_params))) {
            //LOG_ERR("Connection request failed");
            return -ENOEXEC;
        //LOG_INF("Connection requested");
        return 0;
    static int wifi_disconnect(void)
        int status;
        context.disconnecting = true;
        status = net_mgmt(NET_REQUEST_WIFI_DISCONNECT, iface, NULL, 0);
        if (status) {
            if (status == -EALREADY) {
                //LOG_INF("Already disconnected");
            } else {
            //    LOG_ERR("Disconnect request failed");
                return -ENOEXEC;
        } else {
            //LOG_INF("Disconnect requested");
        return 0;
    void main(void)
        context.all = 0U;
        net_mgmt_init_event_callback(&wifi_shell_mgmt_cb,
                         wifi_mgmt_event_handler,
                         WIFI_SHELL_MGMT_EVENTS);
        net_mgmt_add_event_callback(&wifi_shell_mgmt_cb);
        net_mgmt_init_event_callback(&net_shell_mgmt_cb,
                         net_mgmt_event_handler,
                         NET_EVENT_IPV4_DHCP_BOUND);
        net_mgmt_add_event_callback(&net_shell_mgmt_cb);
    #ifdef CLOCK_FEATURE_HFCLK_DIVIDE_PRESENT
        /* For now hardcode to 128MHz */
        nrfx_clock_divider_set(NRF_CLOCK_DOMAIN_HFCLK,
                       NRF_CLOCK_HFCLK_DIV_1);
        LOG_INF("Starting %s with CPU frequency: %d MHz", CONFIG_BOARD, SystemCoreClock/MHZ(1));
        k_sleep(K_SECONDS(1));
        wifi_connect();
        udp_server();
        //send_udp_datagram();
        k_sleep(K_FOREVER);
    Could you provide information about the NCS version/tag which you used for testing?
    Have you tried decreasing the sleeping time of the TWT Wake Interval from specified 60 seconds to 500 ms?
    For better visibility, when you submit code, you could use Insert->Code.
    Dejan
    I used the nRF Connect SDK 2.2 and the nRF Connect Toolchain 2.2.0
    Yes i have tried decreasing the sleeping time of the TWT Wake Interval from specified 60 seconds to 500 ms on less. But that did not help also!
    Have you tested the TWT feature in such example?
    I mean have you tested sending messages to nRF7002 module while TWT is active?
    What is the WiFi Access point that you have used for the test?
    Tareq
  • Hi Tareq,
    UDP server is expected to work with TWT. In out tests, we were able to run UDP_RX (AP to DK) when TWT was active. We used Qualcomm and ASUS devices as access points.
    Dejan
