Trouble setting up new workstation
I am setting up a new workstation but when trying to build code that was working on another computer I am getting the following error
C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.2.0/zephyr -IC:/ncs/v2.2.0/nrf/drivers/mpsl/clock_control -IC:/ncs/v2.2.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.2.0/zephyr/subsys/bluetooth -IC:/ncs/v2.2.0/zephyr/subsys/settings/include -IC:/ncs/v2.2.0/nrf/include -IC:/ncs/v2.2.0/nrf/lib/multithreading_lock/. -IC:/ncs/v2.2.0/nrf/subsys/bluetooth/controller/. -IC:/ncs/v2.2.0/zephyr/drivers/flash -IC:/ncs/v2.2.0/nrf/tests/include -IC:/ncs/v2.2.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.2.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.2.0/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.2.0/modules/lib/zcbor/include -IC:/ncs/v2.2.0/nrfxlib/mpsl/include -IC:/ncs/v2.2.0/nrfxlib/mpsl/include/protocol -IC:/ncs/v2.2.0/nrfxlib/softdevice_controller/include -IC:/ncs/v2.2.0/zephyr/subsys/mgmt/mcumgr/lib/mgmt/include -IC:/ncs/v2.2.0/zephyr/subsys/mgmt/mcumgr/lib/util/include -IC:/ncs/v2.2.0/zephyr/subsys/mgmt/mcumgr/lib/smp/include -IC:/ncs/v2.2.0/zephyr/subsys/mgmt/mcumgr/lib/cmd/img_mgmt/include -IC:/ncs/v2.2.0/zephyr/subsys/mgmt/mcumgr/lib/cmd/os_mgmt/include -isystem C:/ncs/v2.2.0/zephyr/lib/libc/minimal/include -isystem c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include -isystem c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include-fixed -isystem C:/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros C:/Users/JasonClyde/Documents/GitHub/Controller_Firmware/build_v4/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.2.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/Users/JasonClyde/Documents/GitHub/Controller_Firmware=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.2.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.2.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
c:\Users\Clyde\Documents\GitHub\C_Firmware\src\main.c:1:10: fatal error: bluetooth/bluetooth.h: No such file or directory
    1 | #include <bluetooth/bluetooth.h>
I am trying to use cpp properties to include the path for zephyr but the error is still there even if I don't include it and instead use
    "configurations": [
            "name": "Win32",
            "includePath": [
                "${workspaceFolder}/**",
                "C:/ncs/2.2.0/**"
            "defines": [
                "_DEBUG",
                "UNICODE",
                "_UNICODE"
            "intelliSenseMode": "windows-gcc-arm",
            "configurationProvider": "nrf-connect",
            "cStandard": "gnu17",
            "cppStandard": "c++20",
            "compilerPath": ""
    "version": 4
I downloaded the toolchain through toolchain manager and its not saying there are any missing extensions in vs code. This is a new computer so I am assuming I just forgot to install something but I've followed the instructions provided.
  • Hello Clyde,
    I am not sure what you mean with using cpp properties to include zephyr (headers?). Please enlighten me.
    From nRF Connect SDK (NCS) v2.0.0, the correct include statement for public zephyr headers is #include <zephyr/bluetooth/bluetooth.h>. The reason is that public headers were moved to zephyr/include from Zephyr v3.1.0 and is documented in these release notes.
    Does the new workstation and the previous workstation have the same version of NCS? If not, you should
    • take a look at the release notes in-between the releases if you want to upgrade the NCS version.
    • install the same version of NCS at the new workstation.
    Also, how do you launch VS Code? Environment variables need to be set to successfully build with VS Code, and these are set up for you when you launch VS Code from the Toolchain Manager.
    Kind Regards,
    Maria
  • Thank you, you were correct that it had to do with migrating NCS versions. The link you provided included a python script that helped convert all my includes that worked
