Software engineer here and very new to electronics. I programmed a nrf52840 dongle that activates a signal with a transistor. Now, I'd like to hide it inside the wall but there's no electrical wiring available so I'd like to connect the dongle to a battery instead. The obvious solution would be to stick it in a powerbank but the powerbanks I found are a bit bulky and expensive.
Is there a DIY module I could use to power the dongle from a battery?
As an alternative, I saw that it was also possible to power the Dongle without going through USB but then I am not sure if I can connect a battery pack directly or if I would need a module in between to regulate the voltage.
I found some modules on Aliexpress and Alibaba by searching "powerbank module" but I'm not sure which one would be suitable and also not sure how to use them, I guess their buyers are not noobs like me.
Any tips appreciated.
Thanks
