spacious flash memory
Hello guys,
I'm using the NRF52832 chip and I have a flash memory space problem.
My application is using 84K of flash, but it seems exaggerated because I wrote few lines of code (3000).
I'm in doubt if it could be some compiler configuration (keil uvision) or if the application is really using all this space.
could someone tell me?
plese, forgive my english,
I'm from Brazil
    It shouldn't be too much in itself with 84K. You should have plenty more to use.
    It sounds like you either have some project configuration issues, or you have added some large buffers in your 3000 lines of code that eats up all the flash. Is it possible for me to reproduce the issue you are seeing? If so, can you please try to .zip your application folder and upload it here? Please test that you are still able to replicate the issue if you unzip it in an unmodified SDK.
    And what SDK version are you using by the way?
    Edvin
