nRF5340 Audio DK - gateway central LED colour?
Hi, I just started working with three Audio DK boards. All I'm doing at this stage is trying to familiarise myself with the SDK by building and programming the nrf5340_audio application, as headset for two of the boards and gateway for the third. Building and programming seems to be working OK but I was expecting the central LED to be a different colour on each of the three boards, reflecting their roles as headset (L), gateway and headset (r).
Instead, my gateway device has a blue LED, the same as the device flashed with code for headset (left).
In the image above, the device in the foreground is the right headset. In the background on the left we have the left headset and in the background on the right, the gateway.
Here's how I build and program the gateway:
C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\tools\buildprog>python buildprog.py -c app -b debug -d gateway
|    snr     | snr conn |  device | only reboot  | core app programmed | core net programmed |
| 1050146584 |  ←[33mFalse←[0m   | headset | Not selected |     Not selected    |     Not selected    |
| 1050193182 |   ←[32mTrue←[0m   | gateway | Not selected |     Selected TBD    |     Not selected    |
| 1050112489 |  ←[33mFalse←[0m   | headset | Not selected |     Not selected    |     Not selected    |
Invoking build step
Run: west build C:\ncs\v2.2.0\nrf\applications\nrf5340_audio -b nrf5340_audio_dk_nrf5340_cpuapp -d C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\build\dev_gateway\build_debug
-- Application: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio
-- Using NCS Toolchain 2.2.0 for building. (C:/ncs/toolchains/v2.2.0/cmake)
-- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:\Users\mwoolley\AppData\Local/.cache/zephyr
-- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr)
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.2.0/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_debug/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_debug/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_debug/zephyr/dts.cmake
warning: Experimental symbol NRF5340_AUDIO is enabled.
warning: Experimental symbol BT_ISO_PERIPHERAL is enabled.
warning: Experimental symbol BT_AUDIO is enabled.
warning: Experimental symbol BT_AUDIO_UNICAST_SERVER is enabled.
warning: Experimental symbol BT_VCS is enabled.
warning: Experimental symbol BT_CSIS is enabled.
warning: Experimental symbol BT_MCC is enabled.
warning: Experimental symbol BT_CAP_ACCEPTOR is enabled.
Parsing C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/Kconfig
Loaded configuration 'C:/ncs/v2.2.0/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/prj.conf'
Configuration saved to 'C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_debug/zephyr/.config'
Kconfig header saved to 'C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_debug/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Found assembler: C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- libmetal version: 1.2.0 (C:/ncs/v2.2.0/nrf/applications/nrf5340_audio)
-- Build type:
-- Host:    Windows/AMD64
-- Target:  Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.2.0 (C:/ncs/v2.2.0/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS :  -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
CMake Warning at C:/ncs/v2.2.0/zephyr/CMakeLists.txt:1833 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_debug
[1/421] Generating include/generated/version.h
-- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
[411/421] Linking C executable zephyr\zephyr_pre0.elf
[415/421] Linking C executable zephyr\zephyr_pre1.elf
[421/421] Linking C executable zephyr\zephyr.elf
           FLASH:      559696 B         1 MB     53.38%
             RAM:      101044 B       448 KB     22.03%
        IDT_LIST:          0 GB         2 KB      0.00%
build_prog.py finished. Report:
| 1050146584 |  False   | headset | Not selected |     Not selected    |     Not selected    |
| 1050193182 |   True   | gateway | Not selected |     Selected TBD    |     Not selected    |
| 1050112489 |  False   | headset | Not selected |     Not selected    |     Not selected    |
C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\tools\buildprog>python buildprog.py -c app -b debug -d gateway -p
Invoking build step
ninja: no work to do.
Programming app core on: 1050193182 gateway
Parsing parameters.
Writing.
Resetting 1050193182 gateway
Applying system reset.
Run.
| 1050193182 |   True   | gateway | Not selected |         Done        |     Not selected    |
And here's my JSON config file:
        "nrf5340_audio_dk_snr": 1050146584,
        "nrf5340_audio_dk_dev": "headset",
        "channel": "left"
        "nrf5340_audio_dk_snr": 1050193182,
        "nrf5340_audio_dk_dev": "gateway",
        "channel": "NA"
        "nrf5340_audio_dk_snr": 1050112489,
        "channel": "right"
Can you please explain why my gateway device does not light its central LED green? Does this indicate it really is not running the gateway code?
Thanks
  • I just ran nrfjprog-e so I could start afresh. Reprogramming both the net and app cores did not change the result. The board still seems to think it is a headset instead of gateway.
    C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\tools\buildprog>python buildprog.py -c both -b debug -d gateway -p
    | 1050193182 |   ←[32mTrue←[0m   | gateway | Not selected |     Selected TBD    |     Selected TBD    |
    Invoking build step
    Net core uses precompiled hex
    Using NET hex: C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\bin\ble5-ctr-rpmsg_3310.hex for 1050193182 gateway
    Programming net core on: 1050193182 gateway
    Parsing parameters.
    Writing.
    Run.
    | 1050193182 |   True   | gateway | Not selected |         Done        |         Done        |
  • p.s. LED3 is blinking yellow. The documentation only mentions green (meaning "The nRF5340 Audio DK application core is running"). See https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/README.html#testing
    I will have to get back to you on this next week.
    Elfving
  • Any news on this? Whilst my initial question highlighted the discrepancy between expected and actual LED colours, the bottom line is my gateway node is not working after a clean build. Could you help me get up and running, please?
