i'm trying to change nrf/samples/bluetooth/throghput to coded PHY advertising.
I changed the scan options to BT_LE_SCAN_OPT_FILTER_DUPLICATE | BT_LE_SCAN_OPT_CODED | BT_LE_SCAN_OPT_NO_1M.
I changed the adv_start function to:
static void adv_start(void)
struct bt_le_adv_param *adv_param =
BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE |
BT_LE_ADV_OPT_ONE_TIME | BT_LE_ADV_OPT_EXT_ADV | BT_LE_ADV_OPT_CODED,
BT_GAP_ADV_FAST_INT_MIN_2,
BT_GAP_ADV_FAST_INT_MAX_2,
NULL);
int err;
struct bt_le_ext_adv *adv;
err = bt_le_ext_adv_create(adv_param, NULL, &adv);
if (err) {
printk("Failed to create advertiser (%d)\n", err);
return;
err = bt_le_ext_adv_set_data(adv, ad, ARRAY_SIZE(ad), NULL, 0);
if (err) {
printk("Failed to set advertiser data set (%d)\n", err);
return;
err = bt_le_ext_adv_start(adv, NULL);
if (err) {
printk("Failed to start advertiser (%d)\n", err);
return;
and added CONFIG_BT_EXT_ADV=y
there is a filter match but nothing happens next.. i tried to add a printk "scan_connecting_data" callback and it is called..
if i keep the same changes but remove the BT_LE_ADV/SCAN_OPT_CODED and BT_LE_SCAN_OPT_NO_1M it works again...
what can be the issue?
uart:~$
Central. Starting scanning
Filters matched. Address: F9:6C:29:6F:41:64 (random) connectable: 1
Connecting data callback
