Timer under 5ms
I have added a timer to my code, which I need to be of 1ms. The handler of the timer is correctly called when the timer is 5ms or above. However, if I change it to less than 5ms the handler is never called.
Here is some of the code I used (using softdevice):
static app_timer_id_t timtecil;
uint32_t counter=0;
void timtecil_handler(void * p_context)
	UNUSED_PARAMETER(p_context);
	counter++;
err_code=app_timer_create(&timtecil,APP_TIMER_MODE_REPEATED,timtecil_handler);
err_code=app_timer_start(timtecil,APP_TIMER_MULTIPLICADOR*0.001,NULL);
    for (;;)
        app_sched_execute();
        power_manage();
The constant APP_TIMER_MULTIPLICADOR (= 1024) is used to match the necessary number of ticks so I write only the period in seconds. I use APP_TIMER_PRESCALER = 31 (so the shortest timer possible is 0,000976563 seconds).
Any explanation?
Thank you very much.
