Why did the 9160 fail to resolve the domain name?
I developed a product on 9160 using the ncs1.9.0 SDK and the 1.3.2 modem firmware. When debugging, I found a problem. That is, when connecting to a domain name, the modem returned the error of domain name resolution failure. However, using the same hardware device, running the ncs1.2.0 SDK can connect to this address, that is, there is no problem with the network and the background domain name, Then why is there an error on ncs1.9.0? This is the modem trace I captured.
trace-2023-01-28T09-43-24.379Z.bin
This is my conf file and overlay file:
# Copyright (c) 2019 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
CONFIG_GPIO=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# Log
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_MODE_OVERFLOW=y
CONFIG_LOG_BACKEND_RTT_MODE_DROP=y
CONFIG_LOG_BACKEND_SHOW_COLOR=n
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=n
# watch dog
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_TIMEOUT_MSEC=10000
# Modem info
CONFIG_MODEM_INFO=y
# Modem library
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n
CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y
# BSD library
#CONFIG_BSD_LIBRARY=y
#CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
# NVS
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS=y
CONFIG_NVS_LOG_LEVEL_DBG=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# GPS
# Enable to use an external GNSS antenna
CONFIG_GNSS_SAMPLE_ANTENNA_EXTERNAL=y
# Enable to use nRF Cloud A-GPS
CONFIG_GNSS_SAMPLE_ASSISTANCE_NRF_CLOUD=n
# Secure User-Plane Location (SUPL) client library (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/others/supl_os_client.html)
CONFIG_GNSS_SAMPLE_ASSISTANCE_SUPL=y
# AT_CMD
#CONFIG_AT_HOST_LIBRARY=y
#CONFIG_UART_INTERRUPT_DRIVEN=y
# Console
CONFIG_CONSOLE_SUBSYS=n
CONFIG_CONSOLE_HANDLER=n
CONFIG_CONSOLE_GETCHAR=n
CONFIG_CONSOLE=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_USE_FALLBACK=y
CONFIG_LTE_NETWORK_TIMEOUT=180
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=n
CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
# PSM
CONFIG_MODEM_AUTO_REQUEST_POWER_SAVING_FEATURES=y
# Set Periodic-TAU timer to 1 hour and Active-Time to 10 seconds.
CONFIG_LTE_PSM_REQ_RPTAU="01000110"
CONFIG_LTE_PSM_REQ_RAT="00000101"
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=n
CONFIG_MQTT_KEEPALIVE=300
CONFIG_MQTT_PUB_TOPIC="device/e2/pushdata"
CONFIG_MQTT_SUB_TOPIC="device/e2/"
CONFIG_MQTT_CLIENT_ID="my-client-id"
CONFIG_MQTT_USER_NAME="admin123"
CONFIG_MQTT_PASSWORD="admin123"
CONFIG_MQTT_DOMESTIC_BROKER_HOSTNAME="47.107.51.89"
CONFIG_MQTT_DOMESTIC_BROKER_PORT=1883
CONFIG_MQTT_FOREIGN_BROKER_HOSTNAME="18.135.53.53"
CONFIG_MQTT_FOREIGN_BROKER_PORT=1883
CONFIG_MQTT_MESSAGE_BUFFER_SIZE=512
CONFIG_MQTT_PAYLOAD_BUFFER_SIZE=512
# Library for buttons and LEDs
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_INVERT_LEDS=n
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_HW_STACK_PROTECTION=y
# SPI
CONFIG_SPI=y
# I2C
CONFIG_I2C=y
# UART
CONFIG_SERIAL=y
# ANIMATION
CONFIG_ANIMATION_SUPPORT=y
# PPG
CONFIG_PPG_SUPPORT=n
# IMU
CONFIG_IMU_SUPPORT=n
CONFIG_STEP_SUPPORT=n
CONFIG_SLEEP_SUPPORT=n
CONFIG_FALL_DETECT_SUPPORT=n
# WIFI
CONFIG_WIFI_SUPPORT=n
# TP
CONFIG_TOUCH_SUPPORT=y
# AUDIO
CONFIG_AUDIO_SUPPORT=n
# Data Sync
CONFIG_SYNC_SUPPORT=y
# Temperature
CONFIG_TEMP_SUPPORT=n
# CRC Check
CONFIG_CRC_SUPPORT=y
# DEVICE POWER MANAGEMENT
CONFIG_PM_DEVICE=y
# Download client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=192
CONFIG_DOWNLOAD_CLIENT_MAX_FILENAME_SIZE=64
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# DATA UPDATE
CONFIG_DATA_DOWNLOAD_SUPPORT=y
CONFIG_DATA_DOWNLOAD_HOST_HK="aug-fm-files-hk.oss-cn-hongkong.aliyuncs.com"
CONFIG_DATA_DOWNLOAD_HOST_CN="aug-fm-files-cn.oss-cn-shenzhen.aliyuncs.com"
# IMG
CONFIG_IMG_DATA_UPDATE=y
CONFIG_IMG_DATA_DOWNLOAD_FILE="e2_img.bin"
# FONT
CONFIG_FONT_DATA_UPDATE=y
CONFIG_FONT_DATA_DOWNLOAD_FILE="e2_font.bin"
# PPG
CONFIG_PPG_DATA_UPDATE=y
CONFIG_PPG_DATA_DOWNLOAD_FILE="e2_ppg.bin"
# fota download
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
CONFIG_FOTA_DOWNLOAD_HOST_HK="aug-fm-files-hk.oss-cn-hongkong.aliyuncs.com"
CONFIG_FOTA_DOWNLOAD_HOST_CN="aug-fm-files-cn.oss-cn-shenzhen.aliyuncs.com"
CONFIG_FOTA_DOWNLOAD_FILE="e2_update.bin"
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# DFU Target
CONFIG_DFU_TARGET=y
# Modem key management
CONFIG_MODEM_KEY_MGMT=y
# Application Upgrade support
CONFIG_BOOTLOADER_MCUBOOT=y
&spi2{
	status = "disabled";
	sck-pin = <3>;
	mosi-pin = <4>;
	miso-pin = <5>;
&spi3{
	status = "okay";
	sck-pin = <22>;
	mosi-pin = <20>;
	miso-pin = <5>;
&i2c1{
	sda-pin = <30>;
	scl-pin = <31>;
	clock-frequency = <I2C_BITRATE_FAST>;
&i2c2{
&uart0 {
	current-speed = <115200>;
	tx-pin = <12>;
	rx-pin = <11>;
	/* delete rts-pin&cts-pin to release the related 2 pins for other uses */
	/delete-property/ rts-pin;
	/delete-property/ cts-pin;
&uart1{
	status = "okay";
	tx-pin = <12>;
	rx-pin = <11>;
&uart2{
	status = "okay";
	tx-pin = <18>;
	rx-pin = <19>;
  • Hi Biao,
    duxinglang said:
    5. We just conducted another experiment: porting the 9160 from the old device to the new device, and the new device can also operate normally. This indicates that the problem may not be caused by our principle design, but is related to the 9160 itself. Strangely, the old device and the new device use the same batch of 9160 (its silk screen is the same: nrf9160 SICA B1 2110C3), and both are versions of mfw1.3.2.
    Ok, this is very interesting to see. For the new devices, how many you have tested by far? Do all of them have the same issue?
    I will properly ask our QA team to check the nRF9160 chips you got for the next step.
    Charlie
  • Yes, we have tried many new devices that are unable to resolve domain names (greater than 20). But with the combination of ncs1.2.0+mfw1.3.2, the new device can operate normally.
  • My understanding is that when you unsoldered one nRF9160 chip from the old version device and then solder it to the new version device, then the modified new version device will work with ncs1.9.0+mfw1.3.2. Is this correct?
    if yes, could you do two more of this kind of transplants? If all the nRF9160 chips from the old version device will make modified new version devices work. Could you share the picture of these six nRF9160 chips?
    Charlie
  • Yes, after testing, we found that by disassembling the 9160 from the old device and installing it on the new device, it can work normally; At the same time, we removed the 9160 from the new device and installed it on the old device, but it still couldn't resolve the domain name. In other words, it wasn't the circuit design of our device that caused this domain name resolution anomaly, but the 9160 itself. This is very strange because from the screen printing perspective, the 9160 from the old device and the new device are in the same batch.
    By the way, they are all the same firmware, equipped with ncs1.9.0+mfw1.3.2.
  • Hi Biao,
    The case is now with field quality team.
    Can you please fill out the attached form for 4 samples? I will then prepare RMA document for shipping the samples for further analysis.
    6281.CustomerFailureReportV3.2.docx
    Cheers,
    Amin Zavieh, Field Quality Manager
