"Bricking" a custom board by unplugging SWD debugger mid-session?
Hey guys.
I'm having a weird issue. I'm using a custom PCB with NRF52810 and S112 soft device, which has tag-connect connector for SWD debugger and it does not click into place, so it happens sometimes that connection is cut during debugging session.
After N sessions, board stops responding. I have 4 different boards infront of me, all of them used to work, and then suddenly stoppe. I keep getting that: Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device.
The code seems to still run on the IC, but I cannot connect to it anymore.
I tried using command tools to recover board and I keep getting the same error. It seems that board just does not respond.
There was one instance of a different error, where I tried connecting to the board via NRF Connect programmer and got the message that memory is protected (I did not activate this..). But when I restarted the tool, I got the first message again (unsupported device).
So my question would be, is it possible that this happens because of random connection cut while debugging? Or could there be something else?
Any help would be greatly appreciated as I have only one board left.
command line log:
C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin>nrfjprog --recover
[error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
ERROR: Unable to connect to a debugger.[error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
Thanks!
Kristjan
