"Bricking" a custom board by unplugging SWD debugger mid-session?
Hey guys.
I'm having a weird issue. I'm using a custom PCB with NRF52810 and S112 soft device, which has tag-connect connector for SWD debugger and it does not click into place, so it happens sometimes that connection is cut during debugging session.
After N sessions, board stops responding. I have 4 different boards infront of me, all of them used to work, and then suddenly stoppe. I keep getting that: Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device.
The code seems to still run on the IC, but I cannot connect to it anymore.
I tried using command tools to recover board and I keep getting the same error. It seems that board just does not respond.
There was one instance of a different error, where I tried connecting to the board via NRF Connect programmer and got the message that memory is protected (I did not activate this..). But when I restarted the tool, I got the first message again (unsupported device).
So my question would be, is it possible that this happens because of random connection cut while debugging? Or could there be something else?
Any help would be greatly appreciated as I have only one board left.
command line log:
C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin>nrfjprog --recover
[error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
ERROR: Unable to connect to a debugger.[error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
Thanks!
Kristjan
    Mathew said:
    The log file looks identical as that shown in the original post by Kristjan so I have not included it.
    There will be a .log file generated, which holds more info than what is written to stdout. can you attach this?
    Håkon
  • [2023-Jun-15 11:16:07] [ info] --------------------------------------------------------------------------------
    [2023-Jun-15 11:16:07] [ info] nrfjprog --recover -c 125 --log
    [2023-Jun-15 11:16:07] [ info] nrfjprog version 10.14.0 external
    [2023-Jun-15 11:16:07] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
    [2023-Jun-15 11:16:07] [ info] Library loaded, loading member functions.
    [2023-Jun-15 11:16:07] [ info] Member functions succesfully loaded.
    [2023-Jun-15 11:16:07] [debug] [ Client] - open
    [2023-Jun-15 11:16:07] [debug] [ Client] - start
    [2023-Jun-15 11:16:08] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence eb186995-c78c-4406-85fc-7b4a7a6a7385.
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2023-Jun-15 11:16:08] [debug] [ JLink] - Logger sink registered in JLink logger
    [2023-Jun-15 11:16:08] [debug] [ nRFXX] - open
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - open_dll
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2023-Jun-15 11:16:08] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2023-Jun-15 11:16:08] [trace] [ Client] - Command open executed for 138 milliseconds with result 0
    [2023-Jun-15 11:16:08] [debug] [ Client] - enum_emu_snr
    [2023-Jun-15 11:16:08] [trace] [ Client] - Command enum_emu_snr executed for 2 milliseconds with result 0
    [2023-Jun-15 11:16:08] [debug] [ Client] - connect_to_emu_with_snr
    [2023-Jun-15 11:16:08] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2023-Jun-15 11:16:08] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - dll_version
    [2023-Jun-15 11:16:08] [ info] [SeggerBackend] - Segger dll version 7.54.b loaded.
    [2023-Jun-15 11:16:08] [trace] [ Worker] - Command open executed for 67 milliseconds with result 0
    [2023-Jun-15 11:16:08] [debug] [ nRFXX] - enum_emu_snr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - enum_emu_snr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_get_num_emus
    [2023-Jun-15 11:16:08] [trace] [ Worker] - Command enum_emu_snr executed for 2 milliseconds with result 0
    [2023-Jun-15 11:16:08] [debug] [ nRFXX] - connect_to_emu_with_snr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - Segger logging enabled.
    [2023-Jun-15 11:16:08] [trace] [ JLink] - Firmware: J-Link Lite-Cortex-M V8 compiled Sep 15 2016 12:05:01
    [2023-Jun-15 11:16:08] [trace] [ JLink] - Hardware: V8.00
    [2023-Jun-15 11:16:08] [trace] [ JLink] - S/N: 518005754
    [2023-Jun-15 11:16:08] [trace] [ JLink] - OEM: SEGGER
    [2023-Jun-15 11:16:08] [trace] [ JLink] - Feature(s): GDB
    [2023-Jun-15 11:16:08] [trace] [ JLink] - TELNET listener socket opened on port 19021
    [2023-Jun-15 11:16:08] [trace] [ JLink] - WEBSRV Starting webserver
    [2023-Jun-15 11:16:08] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 15.630ms returns "O.K."
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_HasError()
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_Lock()
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_GetHWStatus(...)
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.442ms returns 0
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.040ms returns 0x01
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.062ms returns 0x00
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.036ms returns 0x00
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.049ms returns 0
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.912ms returns 0x00
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_SetSpeed(125)
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.145ms
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_GetSN()
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.007ms returns 518005754
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - read_debug_port_idr
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - read_debug_port_register
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - coresight_configure
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 5.938ms returns 0
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.377ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ Client] - Command connect_to_emu_with_snr executed for 91 milliseconds with result -102
    [2023-Jun-15 11:16:08] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.365ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.529ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.525ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.430ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.374ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 1.692ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.545ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.350ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.370ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.500ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.341ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.346ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.344ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.345ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.340ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.404ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.338ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.333ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.325ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.332ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.342ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.463ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.382ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.031ms
    [2023-Jun-15 11:16:08] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 91 milliseconds with result -102
    [2023-Jun-15 11:16:08] [debug] [ nRFXX] - close
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_IsOpen()
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.008ms returns 0x01
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - close
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - disconnect_from_emu
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - is_connected_to_device
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_IsConnected()
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.006ms returns FALSE
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.389ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.352ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.339ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.328ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.378ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.355ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.538ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.360ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.359ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.423ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.343ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.347ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.443ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.369ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.408ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.357ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.367ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.373ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.390ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.334ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.449ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.348ms returns -1
    [2023-Jun-15 11:16:08] [trace] [ JLink] - - 0.034ms
    [2023-Jun-15 11:16:08] [trace] [ JLink] - JLINK_Close()
    [2023-Jun-15 11:16:08] [trace] [ Client] - Command close executed for 56 milliseconds with result 0
    [2023-Jun-15 11:16:08] [debug] [ Client] - terminate
    [2023-Jun-15 11:16:08] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2023-Jun-15 11:16:08] [debug] [SeggerBackend] - Segger Backend closed.
    [2023-Jun-15 11:16:08] [debug] [ nRFXX] - nRF family DLL closed
    [2023-Jun-15 11:16:08] [trace] [ Worker] - Command close executed for 56 milliseconds with result 0
    [2023-Jun-15 11:16:08] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2023-Jun-15 11:16:08] [trace] [ Worker] - Executed 5 commands for 216 milliseconds
    [2023-Jun-15 11:16:08] [debug] [ Client] - Child process terminated with result 0
    [2023-Jun-15 11:16:08] [trace] [ Client] - Executed 5 commands for 287 milliseconds
    Looks like the debugger isn't able to connect at all.
    Have you tried to use JLinkExe instead to see that it outputs?
    Here's a quick way to connect to a nrf52832:
    device nrf52
    si 1
    speed 250
    connect
    If it still fails, then it sounds like there's a electrical problem in the SWD lines.
    Håkon
