SDK 2.2 + "__device_dts_ord_XX" errors
Hi community,
I try to acces gpio0 and adc channels on a icarus board (nRF9160 + SDK 2.2).
On building, i have these errors "__device_dts_ord_94", "__device_dts_ord_95" and "__device_dts_ord_4".
DEVICE_DT_GET seems not accepted.
Any idea to solve this ?
Many thanks !
#define GPIO_NODE DT_NODELABEL(gpio0)
#define ADC_0 DT_CHILD(DT_NODELABEL(adc), channel_0)
#define ADC_5 DT_CHILD(DT_NODELABEL(adc), channel_5)
static const struct device *adc0;
static const struct device *adc5;
static const struct device *gpio;
adc0 = DEVICE_DT_GET(ADC_0);
adc5 = DEVICE_DT_GET(ADC_5);
gpio = DEVICE_DT_GET(GPIO_NODE);
and overlay
&adc {
	#address-cells = <1>;
	#size-cells = <0>;
	channel@0 {
		reg = <0>;
		zephyr,gain = "ADC_GAIN_1_6";
		zephyr,reference = "ADC_REF_INTERNAL";
		zephyr,acquisition-time = <ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 20)>;
		zephyr,input-positive = <NRF_SAADC_AIN0>;
		zephyr,resolution = < 10 >;
	channel@5 {
		reg = <5>;
		zephyr,input-positive = <NRF_SAADC_AIN5>;
  • Hello
    Could you please share the adc node in your generated device tree in build/zephyr/zephyr.dts?
    You'll need to add a "compatible" property if it isn't already defined.
    I also suspect you might have to add
    #size-cells = <0>;
    to your overlay if you define reg as simply <5>.
    Einar
  • The adc node
    adc: feather_adc: arduino_adc: adc@e000 {
    				compatible = "nordic,nrf-saadc";
    				reg = < 0xe000 0x1000 >;
    				interrupts = < 0xe 0x1 >;
    				status = "okay";
    				#io-channel-cells = < 0x1 >;
    				#address-cells = < 0x1 >;
    				#size-cells = < 0x0 >;
    				phandle = < 0x10 >;
    				channel@0 {
    					reg = < 0x0 >;
    					zephyr,acquisition-time = < 0x4014 >;
    					zephyr,input-positive = < 0x1 >;
    					zephyr,resolution = < 0xa >;
    				channel@5 {
    					reg = < 0x5 >;
    					zephyr,input-positive = < 0x6 >;
    the gpio node
    gpio0: gpio@842500 {
    				compatible = "nordic,nrf-gpio";
    				gpio-controller;
    				reg = < 0x842500 0x300 >;
    				#gpio-cells = < 0x2 >;
    				status = "okay";
    				port = < 0x0 >;
    				phandle = < 0xa >;
  • The #address-cells and #size-cells should be under the channel@x sub-nodes as they give info about the reg properties
    -Einar
  • I take example from this documentation
    In my overlay i have only that:
    &adc {
    	#size-cells = <0>;
    	channel@0 {
    		reg = <0>;
    	channel@5 {
    		reg = <5>;
    GPIO haven't overlay, and no works too. same error.
    If i put #address-cells and #size-cells, errors happened.
    I also test to put compatible property, failed too.
  • Can you please share your project so I can try to replicate?
    -Einar
