SDK 2.2 + "__device_dts_ord_XX" errors
Hi community,
I try to acces gpio0 and adc channels on a icarus board (nRF9160 + SDK 2.2).
On building, i have these errors "__device_dts_ord_94", "__device_dts_ord_95" and "__device_dts_ord_4".
DEVICE_DT_GET seems not accepted.
Any idea to solve this ?
Many thanks !
#define GPIO_NODE DT_NODELABEL(gpio0)
#define ADC_0 DT_CHILD(DT_NODELABEL(adc), channel_0)
#define ADC_5 DT_CHILD(DT_NODELABEL(adc), channel_5)
static const struct device *adc0;
static const struct device *adc5;
static const struct device *gpio;
adc0 = DEVICE_DT_GET(ADC_0);
adc5 = DEVICE_DT_GET(ADC_5);
gpio = DEVICE_DT_GET(GPIO_NODE);
and overlay
&adc {
	#address-cells = <1>;
	#size-cells = <0>;
	channel@0 {
		reg = <0>;
		zephyr,gain = "ADC_GAIN_1_6";
		zephyr,reference = "ADC_REF_INTERNAL";
		zephyr,acquisition-time = <ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 20)>;
		zephyr,input-positive = <NRF_SAADC_AIN0>;
		zephyr,resolution = < 10 >;
	channel@5 {
		reg = <5>;
		zephyr,input-positive = <NRF_SAADC_AIN5>;
  • yes device_dts_ord
    build error -> undefined reference to `__device_dts_ord_94' and undefined reference to `__device_dts_ord_95'
    I have no problem with pm_config.h
  • yes, how i can export him ? (i'm with VS Code)
  •  *  Exécution de la tâche : nRF Connect: Generate config [email protected] for /Users/alskandar/Documents/PbCo-App/test
    Building test
    west build --build-dir /Users/alskandar/Documents/PbCo-App/test/build /Users/alskandar/Documents/PbCo-App/test --pristine --board [email protected] -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/alskandar/Documents/PbCo-App/test"
    -- Application: /Users/alskandar/Documents/PbCo-App/test
    -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
    -- Cache files will be written to: /Users/alskandar/Library/Caches/zephyr
    -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr)
    -- Board: actinius_icarus_ns, Revision: 2.0.0
    -- Found host-tools: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/v2.2.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /opt/nordic/ncs/v2.2.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_ns.dts
    -- Found devicetree overlay: /opt/nordic/ncs/v2.2.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_ns_2_0_0.overlay
    -- Found devicetree overlay: /Users/alskandar/Documents/PbCo-App/test/boards/actinius_icarus_ns.overlay
    -- Generated zephyr.dts: /Users/alskandar/Documents/PbCo-App/test/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/alskandar/Documents/PbCo-App/test/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/alskandar/Documents/PbCo-App/test/build/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v2.2.0/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v2.2.0/zephyr/boards/arm/actinius_icarus/actinius_icarus_ns_defconfig'
    Merged configuration '/Users/alskandar/Documents/PbCo-App/test/prj.conf'
    Configuration saved to '/Users/alskandar/Documents/PbCo-App/test/build/zephyr/.config'
    Kconfig header saved to '/Users/alskandar/Documents/PbCo-App/test/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    CMake Warning at /opt/nordic/ncs/v2.2.0/zephyr/CMakeLists.txt:824 (message):
      No SOURCES given to Zephyr library: boards__arm__actinius_icarus
      Excluding target from build.
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/alskandar/Documents/PbCo-App/test/build
    [1/233] Preparing syscall dependency handling
    [2/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/base64.c.obj
    [3/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/nist_kw.c.obj
    [4/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1parse.c.obj
    [5/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1write.c.obj
    [6/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/bignum.c.obj
    [7/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/oid.c.obj
    [8/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/padlock.c.obj
    [9/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform.c.obj
    [10/233] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
    [11/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/constant_time.c.obj
    [12/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform_util.c.obj
    [13/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/version.c.obj
    [14/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pem.c.obj
    [15/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs12.c.obj
    [16/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs5.c.obj
    [17/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkparse.c.obj
    [18/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkwrite.c.obj
    [19/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/dhm.c.obj
    [20/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher.c.obj
    [21/233] Generating misc/generated/syscalls_subdirs.trigger
    [22/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher_wrap.c.obj
    [23/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md.c.obj
    [24/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk.c.obj
    [25/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk_wrap.c.obj
    [26/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha1.c.obj
    [27/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha256.c.obj
    [28/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha512.c.obj
    [29/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ripemd160.c.obj
    [30/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md5.c.obj
    [31/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aesni.c.obj
    [32/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aria.c.obj
    [33/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/camellia.c.obj
    [34/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/des.c.obj
    [35/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cmac.c.obj
    [36/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdh.c.obj
    [37/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ccm.c.obj
    [38/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/chachapoly.c.obj
    [39/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdsa.c.obj
    [40/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp.c.obj
    [41/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp_curves.c.obj
    [42/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/gcm.c.obj
    [43/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hkdf.c.obj
    [44/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hmac_drbg.c.obj
    [45/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa.c.obj
    [46/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa_alt_helpers.c.obj
    [47/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ctr_drbg.c.obj
    [48/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/entropy.c.obj
    [49/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
    [50/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
    [51/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
    [52/233] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a
    [53/233] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a
    [54/233] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [55/233] Generating include/generated/driver-validation.h
    [56/233] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [57/233] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [58/233] Generating ../../tfm/CMakeCache.txt
    -- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found version "3.9.6") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/alskandar/Documents/PbCo-App/test/build/tfm
    [59/233] Creating directories for 'tfm'
    [60/233] No download step for 'tfm'
    [61/233] No update step for 'tfm'
    [62/233] No patch step for 'tfm'
    [63/233] No configure step for 'tfm'
    [63/233] Performing build step for 'tfm'
    [1/2] Generating ../generated/secure_fw/spm/cmsis_func/tfm_spm_db_func.inc, ../generated/secure_fw/spm/cmsis_func/tfm_veneers.c, ../generated/interface/include/tfm_veneers.h, ../generated/tools/tfm_veneers_functions.txt, ../generated/secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc, ../generated/interface/include/psa_manifest/sid.h, ../generated/interface/include/psa_manifest/pid.h, ../generated/interface/include/config_impl.h, ../generated/tools/config_impl.cmake
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [1/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1parse.o
    [2/170] Building C object lib/fih/CMakeFiles/tfm_fih_implementation.dir/src/fih.o
    [3/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/bignum.o
    [4/170] Generating liboberon_mbedcrypto__psa_3.0.12.a
    [5/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/asn1write.o
    [6/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/base64.o
    [7/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/padlock.o
    [8/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/nist_kw.o
    [9/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/oid.o
    [10/170] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_s.o
    [11/170] Linking C static library lib/fih/libtfm_fih_implementation.a
    [12/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/version.o
    [13/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform_util.o
    [14/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform.o
    [15/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/tfm_psa_api_veneers.o
    [16/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [17/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [18/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [19/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o
    [20/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [21/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o
    [22/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o
    [23/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    [24/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch.o
    [25/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o
    [26/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_cross.o
    [27/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [28/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_core_utils.o
    [29/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_pools.o
    [30/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o
    [31/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_cross_call.o
    [32/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/interrupt.o
    [33/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o
    [34/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/thread.o
    [35/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o
    [36/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/idle_partition.o
    [37/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    [38/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz.o
    [39/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o
    [40/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/backend_ipc.o
    [41/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [42/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_cross.o
    [43/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [44/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [45/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [46/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o
    [47/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [48/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o
    [49/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o
    [50/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [51/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o
    [52/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o
    [53/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_main.o
    [54/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [55/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o
    [56/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o
    [57/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    [58/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_cross.o
    [59/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o
    [60/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [61/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [62/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [63/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [64/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [65/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_api.o
    [66/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [67/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    [68/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [69/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [70/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [71/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [72/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [73/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [74/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/constant_time.o
    [75/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [76/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [77/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_cipher.o
    [78/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_aead.o
    [79/170] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libmbedcrypto_base.a
    [80/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_mac.o
    [81/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_hash.o
    [82/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_client.o
    [83/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_ecp.o
    [84/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/memory_buffer_alloc.o
    [85/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_rsa.o
    [86/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_storage.o
    [87/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pem.o
    [88/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [89/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o
    [90/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs5.o
    [91/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkparse.o
    [92/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkcs12.o
    [93/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pkwrite.o
    [94/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/dhm.o
    [95/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md.o
    [96/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher_wrap.o
    [97/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha1.o
    [98/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk.o
    [99/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/pk_wrap.o
    [100/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha256.o
    [101/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto_slot_management.o
    [102/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ripemd160.o
    [103/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/sha512.o
    [104/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/md5.o
    [105/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aesni.o
    [106/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/aria.o
    [107/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/camellia.o
    [108/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/des.o
    [109/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cmac.o
    [110/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ccm.o
    [111/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/cipher.o
    [112/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdh.o
    [113/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/chachapoly.o
    [114/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecdsa.o
    [115/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp.o
    [116/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/ecp_curves.o
    [117/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/gcm.o
    [118/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hkdf.o
    [119/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o
    [120/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/hmac_drbg.o
    [121/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa_alt_helpers.o
    [122/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/rsa.o
    [123/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o
    [124/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o
    [125/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [126/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o
    [127/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [128/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [129/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [130/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [131/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [132/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [133/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [134/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [135/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o
    [136/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [137/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [138/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [139/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [140/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [141/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o
    [142/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [143/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/tfm_interrupts.o
    [144/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_otp.o
    [145/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o
    [146/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [147/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o
    [148/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o
    [149/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o
    [150/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o
    [151/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o
    [152/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o
    [153/170] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld
    [154/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o
    [155/170] Building C object platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/attest_hal.o
    [156/170] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o
    [157/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    [158/170] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_cross.o
    [159/170] Linking C static library platform/libplatform_s.a
    [160/170] Linking C static library secure_fw/partitions/platform/libtfm_psa_rot_partition_platform.a
    [161/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/psa_crypto.o
    [162/170] Linking C static library secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libcrypto_service_mbedcrypto.a
    [163/170] Linking C static library secure_fw/partitions/crypto/libtfm_psa_rot_partition_crypto.a
    [164/170] Linking C static library secure_fw/partitions/lib/sprt/libtfm_sprt.a
    [165/170] Linking C static library secure_fw/spm/libtfm_spm.a
    [166/170] Linking C executable bin/tfm_s.axf
    [167/170] Generating ../bin/tfm_s.bin
    [168/170] Generating ../bin/tfm_s.hex
    [169/170] Generating ../bin/tfm_s.elf
    [170/170] Linking C static library secure_fw/libtfm_s_veneers.a
    [65/233] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [66/233] Completed 'tfm'
    [67/233] Generating zephyr/tfm_secure.hex
    [68/233] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [69/233] Generating include/generated/offsets.h
    [70/233] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [71/233] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [72/233] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_secure.c.obj
    [73/233] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [74/233] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [75/233] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [76/233] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [77/233] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [78/233] Building C object CMakeFiles/app.dir/src/main.c.obj
    ../src/main.c: In function 'main':
    /Users/alskandar/Documents/PbCo-App/test/src/main.c:77:1: warning: control reaches end of non-void function [-Wreturn-type]
       77 | }
    [79/233] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [80/233] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [81/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [82/233] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [83/233] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [84/233] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [85/233] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [86/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [87/233] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [88/233] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [89/233] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [90/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [91/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [92/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [93/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [94/233] Generating linker_zephyr_pre0.cmd
    [95/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [96/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [97/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [98/233] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [99/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [100/233] Linking C static library app/libapp.a
    [101/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [102/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [103/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [104/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [105/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [106/233] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [107/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [108/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [109/233] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
    [110/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [111/233] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [112/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [113/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [114/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [115/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [116/233] Linking C static library zephyr/lib/libc/newlib/liblib__libc__newlib.a
    [117/233] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [118/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [119/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [120/233] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [121/233] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [122/233] Building C object zephyr/boards/arm/actinius_icarus/actinius_common/CMakeFiles/boards__common__actinius.dir/actinius_board_common.c.obj
    [123/233] Building C object zephyr/drivers/adc/CMakeFiles/drivers__adc.dir/adc_common.c.obj
    [124/233] Building C object zephyr/drivers/adc/CMakeFiles/drivers__adc.dir/adc_nrfx_saadc.c.obj
    [125/233] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [126/233] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [127/233] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [128/233] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [129/233] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [130/233] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/opt/nordic/ncs/v2.2.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [131/233] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [132/233] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [133/233] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [134/233] Linking C static library zephyr/boards/arm/actinius_icarus/actinius_common/libboards__common__actinius.a
    [135/233] Linking C static library zephyr/drivers/adc/libdrivers__adc.a
    [136/233] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [137/233] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [138/233] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [139/233] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [140/233] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [141/233] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [142/233] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [143/233] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [144/233] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj
    [145/233] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
    [146/233] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [147/233] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [148/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [149/233] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [150/233] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [151/233] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [152/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [153/233] Generating linker_zephyr_pre1.cmd
    [154/233] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [155/233] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [156/233] Linking C static library zephyr/libzephyr.a
    [157/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [158/233] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [159/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [160/233] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [161/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [162/233] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [163/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [164/233] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [165/233] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [166/233] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [167/233] Linking C static library zephyr/arch/common/libisr_tables.a
    [168/233] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [169/233] Linking C static library modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a
    [170/233] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [171/233] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [172/233] Building C object modules/nrf/modules/tfm/zephyr/CMakeFiles/tfm_api_nrf.dir/__/tfm/boards/src/tfm_ioctl_ns_api.c.obj
    [173/233] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj
    [174/233] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_crypto_ipc_api.c.obj
    [175/233] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [176/233] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_psa_ns_api.c.obj
    [177/233] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_ioctl_core_ns_api.c.obj
    [178/233] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [179/233] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [180/233] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [181/233] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [182/233] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [183/233] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [184/233] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/opt/nordic/ncs/v2.2.0/mbedtls/library/platform.c.obj
    [185/233] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [186/233] Linking C static library zephyr/arch/common/libarch__common.a
    [187/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [188/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [189/233] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [190/233] Linking C static library modules/nrf/modules/tfm/zephyr/libtfm_api_nrf.a
    [191/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [192/233] Linking C static library modules/trusted-firmware-m/libtfm_api.a
    [193/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [194/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [195/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [196/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [197/233] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [198/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [199/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [200/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [201/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [202/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [203/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [204/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [205/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [206/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [207/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [208/233] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/libmbedtls_zephyr.a
    [209/233] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [210/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [211/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [212/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [213/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [214/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [215/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [216/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [217/233] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [218/233] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [219/233] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [220/233] Linking C static library zephyr/kernel/libkernel.a
    [221/233] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    : && ccache /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/alskandar/Documents/PbCo-App/test/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/boards/arm/actinius_icarus/actinius_common/libboards__common__actinius.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/adc/libdrivers__adc.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/modules/tfm/zephyr/libtfm_api_nrf.a  modules/trusted-firmware-m/libtfm_api.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  /opt/nordic/ncs/v2.2.0/nrfxlib/nrf_modem/lib/cortex-m33/soft-float/libmodem.a  modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/libmbedtls_zephyr.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/thumb/v8-m.main/nofp"  -L/Users/alskandar/Documents/PbCo-App/test/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  tfm/secure_fw/s_veneers.o  -no-pie  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -lm  -Wl,-lc  -L"/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v8-m.main/nofp  -Wl,-lgcc  -lc  -specs=nano.specs  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a  /opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/soft-float/liboberon_mbedtls_3.0.12.a  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  /opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/soft-float/liboberon_3.0.12.a  -lc && cd /Users/alskandar/Documents/PbCo-App/test/build/zephyr && /opt/nordic/ncs/toolchains/v2.2.0/Cellar/cmake/3.20.5/bin/cmake -E echo
    /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `init_adc_0':
    /Users/alskandar/Documents/PbCo-App/test/src/main.c:45: undefined reference to `__device_dts_ord_94'
    /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `init_adc_5':
    /Users/alskandar/Documents/PbCo-App/test/src/main.c:61: undefined reference to `__device_dts_ord_95'
    collect2: error: ld returned 1 exit status
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.2.0/bin/cmake --build /Users/alskandar/Documents/PbCo-App/test/build
     *  Arrêt du processus de terminal. Code de sortie : 1.
     *  Le terminal sera réutilisé par les tâches, appuyez sur une touche pour le fermer.
