mcumgr over openthread UDP Error 8
I'm trying to implement mcumgr over openthread UDP. to update firmware.
mcumgr echo works fine but when I try to list images the respond is Error 8.
prj.conf:
CONFIG_DK_LIBRARY=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
# Network settings
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POLL_MAX=4
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_NET_BUF_USER_DATA_SIZE=24
CONFIG_NET_CONFIG_SETTINGS=y
# Network shell
CONFIG_NET_SHELL=y
CONFIG_SHELL_ARGC_MAX=26
CONFIG_SHELL_CMD_BUFF_SIZE=416
## SMP
# Enable mcumgr.
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_MCUMGR_BUF_COUNT=6
# Enable the UDP mcumgr transports.
CONFIG_MCUMGR_SMP_UDP=y
CONFIG_MCUMGR_SMP_UDP_IPV6=y
# OpenThread
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_NEWLIB_LIBC=y
# Enable floating point Hard ABI
CONFIG_FPU=y
CONFIG_FP_HARDABI=y
# Generic networking options
CONFIG_NETWORKING=y
# Kernel options
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_INIT_STACKS=y
# Increase set for threads with meta-irq priority
CONFIG_NUM_METAIRQ_PRIORITIES=1
# Logging
CONFIG_NET_LOG=y
CONFIG_NET_STATISTICS=y
# Disable certain parts of Zephyr IPv6 stack
CONFIG_NET_IPV6_NBR_CACHE=n
CONFIG_NET_IPV6_MLD=n
# Stack sizes configuration
CONFIG_NET_TX_STACK_SIZE=1200
CONFIG_NET_RX_STACK_SIZE=1500
# L2 OpenThread enabling
CONFIG_NET_L2_OPENTHREAD=y
CONFIG_OPENTHREAD_DEBUG=y
CONFIG_OPENTHREAD_L2_DEBUG=y
CONFIG_OPENTHREAD_L2_LOG_LEVEL_INF=y
CONFIG_BOOTLOADER_MCUBOOT=y
#RTT seiral
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
# Enable flash operations.
CONFIG_FLASH=y
# Required by the `taskstat` command.
CONFIG_THREAD_MONITOR=y
# Support for taskstat command
CONFIG_OS_MGMT_TASKSTAT=y
# Enable statistics and statistic names.
CONFIG_STATS=y
CONFIG_STATS_NAMES=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_STAT_MGMT=y
# Enable the shell mcumgr transport.
CONFIG_MCUMGR_SMP_SHELL=y
# mcumgr-cli application doesn't accepts log in the channel it uses
CONFIG_SHELL_LOG_BACKEND=n
I'm using nrf52840 with nrf connect SDK 2.2.0.
+ is this the right implementation of DFU using openthread?
    Not sure how you set SMP over UPD in the application, but you could refer to and test the SMP Server Sample and build with the overlay-udp.conf.
    Amanda H.
  • Hello Amanda,
    I followed the instruction on the SMP Server Sample, I just integrated OpenThread with the sample.
    Instructions like echo and stat are working but anything related to the image will give me error 8.
    I looked for the meaning of error 8 and it seems to mean that the command is not supported. not sure if thats the case or if something is wrong with my code
    #include <zephyr/kernel.h>
    #include <zephyr/stats/stats.h>
    #define LOG_LEVEL LOG_LEVEL_DBG
    LOG_MODULE_REGISTER(smp_sample);
    #include <zephyr/net/openthread.h>
    #include <zephyr/net/socket.h>
    #include <openthread/thread.h>
    #include <stdio.h>
    #include <zephyr/mgmt/mcumgr/smp_udp.h>
    #include <zephyr/net/net_mgmt.h>
    #include <zephyr/net/net_event.h>
    #include <zephyr/net/net_conn_mgr.h>
    #include "os_mgmt/os_mgmt.h"
    #ifdef CONFIG_MCUMGR_CMD_FS_MGMT
    #include <zephyr/device.h>
    #include <zephyr/fs/fs.h>
    #include "fs_mgmt/fs_mgmt.h"
    #include <zephyr/fs/littlefs.h>
    #ifdef CONFIG_MCUMGR_CMD_OS_MGMT
    #ifdef CONFIG_MCUMGR_CMD_IMG_MGMT
    #include "img_mgmt/img_mgmt.h"
    #ifdef CONFIG_MCUMGR_CMD_STAT_MGMT
    #include "stat_mgmt/stat_mgmt.h"
    #ifdef CONFIG_MCUMGR_CMD_SHELL_MGMT
    #include "shell_mgmt/shell_mgmt.h"
    #define EVENT_MASK (NET_EVENT_L4_CONNECTED | NET_EVENT_L4_DISCONNECTED)
    static struct net_mgmt_event_callback mgmt_cb;
    static void event_handler(struct net_mgmt_event_callback *cb,
    			  uint32_t mgmt_event, struct net_if *iface)
    	if ((mgmt_event & EVENT_MASK) != mgmt_event) {
    		return;
    	if (mgmt_event == NET_EVENT_L4_CONNECTED) {
    		LOG_INF("Network connected");
    		if (smp_udp_open() < 0) {
    			LOG_ERR("could not open smp udp");
    		return;
    	if (mgmt_event == NET_EVENT_L4_DISCONNECTED) {
    		LOG_INF("Network disconnected");
    		smp_udp_close();
    		return;
    void get_ieee_eui64(uint8_t *ieee_eui64)
    	uint64_t factory_address;
    	uint32_t index = 0;
    	// By default, the device uses Nordic Semiconductor's MA-L (fa-ce-36). It can be modified by overwriting
    	const uint32_t nordic_oui = 0xf4ce36;
    	// Set the MAC Address Block Larger (MA-L) formerly called OUI.
    	ieee_eui64[index++] = (nordic_oui >> 16) & 0xff;
    	ieee_eui64[index++] = (nordic_oui >> 8) & 0xff;
    	ieee_eui64[index++] = nordic_oui & 0xff;
    	// Use device identifier assigned during the production.
    	factory_address = (uint64_t)NRF_FICR->DEVICEID[0] << 32;
    	factory_address |= NRF_FICR->DEVICEID[1];
    	memcpy(ieee_eui64 + index, &factory_address, sizeof(factory_address) - index);
    void get_macaddress(uint8_t *macaddr)
    	uint8_t eui64[8];
    	get_ieee_eui64(eui64);
    	// get the last 6 bytes, ignoring the first two bytes of Nordic Semiconductor's MA-L
    	memcpy(macaddr, &eui64[2], 6);
    void insert_ip_addr(){
    	// add manual ip, CUSTOM PREFIX + macaddress
    	uint8_t macaddr[6];
    	char manual_ip[46];
    	get_macaddress(macaddr);
    	sprintf(manual_ip, "fdaa:bb:1::%02x%02x:%02x%02x:%02x%02x",
    		macaddr[0], macaddr[1], macaddr[2], macaddr[3],
    		macaddr[4], macaddr[5]);
    	LOG_INF("Adding manual ip: %s", manual_ip);
    	otNetifAddress aAddress;
    	otIp6AddressFromString(manual_ip, &aAddress.mAddress);
    	aAddress.mPrefixLength  = 64;
    	aAddress.mPreferred     = true;
    	aAddress.mValid         = true;
    	aAddress.mAddressOrigin = OT_ADDRESS_ORIGIN_MANUAL;
    	otIp6AddUnicastAddress(openthread_get_default_context()->instance, &aAddress);
    void main(void)
    	insert_ip_addr();
    	// init SMP
    	os_mgmt_register_group();
    	// init SMP UDP
    	LOG_INF("STARTING SMP UDP");
    	net_mgmt_init_event_callback(&mgmt_cb, event_handler, EVENT_MASK);
    	net_mgmt_add_event_callback(&mgmt_cb);
    	net_conn_mgr_resend_status();
    	LOG_INF("SMP: build time: " __DATE__ " " __TIME__);
    	LOG_INF("Device fully initialized!");
  • Before integrating, do you test  SMP Server Sample with overlay-udp.conf? Do you get any errors?
    -Amanda H
  • I just tried the SMP sample with connection over ethernet it seems to be working fine unlike with openthread
  • Do you add the configs in this overlay-udp.conf into your project config?
    This similar case might help, but it needs to increase CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE.
    -Amanda H.
