Hello All,
I am referring to the ble_app_interactive example and it works fine. I wrote similar functions in my project to scan nearby BLE and connect BLE if it's RSSI goes > -30 then it will connect to that BLE and try to discover the services. There is no authentication in BLE it is simple iBeacon. I can also connect it using nRF Connect app.
But I notice there is a difference in the working / output even though I tried to make it all similar. Here is below function common in both my project as well as in ble_app_interactive project. I have added some NRF_LOG to display to get clear idea about the flow and value.
static void on_primary_srv_discovery_rsp(ble_gattc_evt_t const * p_ble_gattc_evt)
uint16_t count;
uint16_t bytes_to_copy;
uint16_t conn_handle;
static uint16_t offset = 0;
ret_code_t err_code;
NRF_LOG_INFO("Inside on_primary_srv_discovery_rsp");
// For readability.
ble_gattc_evt_prim_srvc_disc_rsp_t const * p_prim_serv =&(p_ble_gattc_evt->params.prim_srvc_disc_rsp);
conn_handle = p_ble_gattc_evt->conn_handle;
ble_gattc_service_t * const p_service =mp_device_srv[conn_handle]->services;
// Number of discovered services.
count = p_prim_serv->count;
NRF_LOG_INFO("Service count : %d conn_handle: %d",count,conn_handle);
// If no more services are found.
if ((count != 0) &&
(p_ble_gattc_evt->gatt_status == BLE_GATT_STATUS_SUCCESS))
NRF_LOG_INFO("inside if");
if ((count + offset) > 6)
bytes_to_copy = 6 - offset;
bytes_to_copy = count;
// Save services data.
memcpy((p_service),
p_prim_serv->services,
bytes_to_copy * sizeof(ble_gattc_service_t));
NRF_LOG_INFO(" %X ",p_prim_serv->services[0].uuid.uuid);
offset += count;
// If the last service has not been reached, this function must be called again with a new start handle.
err_code = sd_ble_gattc_primary_services_discover(
conn_handle,
p_prim_serv->services[count - 1].handle_range.end_handle + 1,
NULL);
NRF_LOG_INFO("inside else conn_handle : %d offset : %d ", conn_handle,offset);
mp_device_srv[conn_handle]->count = offset;
// If service UUID type is unknown, then look for a 128-bit UUID.
// Only the first one is searched for here, the rest is searched for in the @ref on_read_rsp.
for (uint8_t i = 0; i < offset; i++)
NRF_LOG_INFO("Inside for counter : %d start_handle : %d",i,p_service[i].handle_range.start_handle);
if (p_service[i].uuid.type == BLE_UUID_TYPE_UNKNOWN)
NRF_LOG_INFO("Inside BLE_UUID_TYPE_UNKNOWN");
m_vendor_uuid_read = true;
// Read service 128-bit UUID.
err_code = sd_ble_gattc_read(conn_handle, p_service[i].handle_range.start_handle, 0);
offset = 0;
return;
NRF_LOG_INFO("Services count: %d", offset);
uuid_print(p_ble_gattc_evt->conn_handle, p_service);
offset = 0;
In app_ble_interactive project I get below output
now here is the output from the project
If you notice there is start_handle : 2689 due that I guess there is error.
After checking line by line. I guess in my project There is problem below code
memcpy((p_service),
Because of above It is not able to save and hence not possible to fetch data displayed like in ble_app_interactive project.
Please help me, What I am doing wrong?
Thanks in advance.
Neeraj Dhekale
