Hi I have a project to use HID mouse and keyboard at the same time, I have tried , but it really can't work well. I've read the similar question and you don't give the clearly answer. So please help. Here are Link about the similar question and unsolved either.
The related code I coded are as follows:
#define INPUT_REPORT_COUNT 4 /**< Number of input reports in this application. */
#define INPUT_REP_BUTTONS_LEN 3 /**< Length of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_LEN 3 /**< Length of Mouse Input Report containing movement data. */
#define INPUT_REP_MEDIA_PLAYER_LEN 1 /**< Length of Mouse Input Report containing media player data. */
#define INPUT_REP_KEYBOARD_LEN 8 /**< Maximum length of the Input Report characteristic. */
#define OUTPUT_REP_KEYBOARD_LEN 1 /**< Maximum length of Output Report. */
#define INPUT_REP_BUTTONS_INDEX 0 /**< Index of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_INDEX 1 /**< Index of Mouse Input Report containing movement data. */
#define INPUT_REP_MPLAYER_INDEX 2 /**< Index of Mouse Input Report containing media player data. */
#define INPUT_REP_KEYBOARD_INDEX 3 /**< Index of Input Report. */
#define OUTPUT_REP_KEYBOARD_INDEX 0 /**< Index of Output Report. */
#define INPUT_REP_REF_BUTTONS_ID 1 /**< Id of reference to Mouse Input Report containing button data. */
#define INPUT_REP_REF_MOVEMENT_ID 2 /**< Id of reference to Mouse Input Report containing movement data. */
#define INPUT_REP_REF_MPLAYER_ID 3 /**< Id of reference to Mouse Input Report containing media player data. */
#define INPUT_REP_REF_KEYBOARD_ID 4 /**< Id of reference to Keyboard Input Report. */
#define OUTPUT_REP_REF_KEYBOARD_ID 4 /**< Id of reference to Keyboard Output Report. */
static void hids_init(void)
uint32_t err_code;
ble_hids_init_t hids_init_obj;
ble_hids_inp_rep_init_t inp_rep_array[INPUT_REPORT_COUNT];
ble_hids_inp_rep_init_t * p_input_report;
ble_hids_outp_rep_init_t outp_rep_array[1];
ble_hids_outp_rep_init_t * p_output_report;
uint8_t hid_info_flags;
static uint8_t rep_map_data[] =
0x05, 0x01, // Usage Page (Generic Desktop)
0x09, 0x02, // Usage (Mouse)
0xA1, 0x01, // Collection (Application)
// Report ID 1: Mouse buttons + scroll/pan
0x85, 0x01, // Report Id 1
0x09, 0x01, // Usage (Pointer)
0xA1, 0x00, // Collection (Physical)
0x95, 0x05, // Report Count (5)
0x75, 0x01, // Report Size (1)
0x05, 0x09, // Usage Page (Buttons)
0x19, 0x01, // Usage Minimum (01)
0x29, 0x05, // Usage Maximum (05)
0x15, 0x00, // Logical Minimum (0)
0x25, 0x01, // Logical Maximum (1)
0x81, 0x02, // Input (Data, Variable, Absolute)
0x95, 0x01, // Report Count (1)
0x75, 0x03, // Report Size (3)
0x81, 0x01, // Input (Constant) for padding
0x75, 0x08, // Report Size (8)
0x09, 0x38, // Usage (Wheel)
0x15, 0x81, // Logical Minimum (-127)
0x25, 0x7F, // Logical Maximum (127)
0x81, 0x06, // Input (Data, Variable, Relative)
0x05, 0x0C, // Usage Page (Consumer)
0x0A, 0x38, 0x02, // Usage (AC Pan)
0x81, 0x06, // Input (Data,Value,Relative,Bit Field)
0xC0, // End Collection (Physical)
// Report ID 2: Mouse motion
0x85, 0x02, // Report Id 2
0x75, 0x0C, // Report Size (12)
0x95, 0x02, // Report Count (2)
0x09, 0x30, // Usage (X)
0x09, 0x31, // Usage (Y)
0x16, 0x01, 0xF8, // Logical maximum (2047)
0x26, 0xFF, 0x07, // Logical minimum (-2047)
0xC0, // End Collection (Application)
// Report ID 3: Advanced buttons
0x09, 0x01, // Usage (Consumer Control)
0x85, 0x03, // Report Id (3)
0x15, 0x00, // Logical minimum (0)
0x25, 0x01, // Logical maximum (1)
0x09, 0xEA, // Usage (Volume Down)
0x09, 0xE9, // Usage (Volume Up)
0x09, 0xE2, // Usage (Mute)
0x09, 0xB5, // Usage (Scan Next Track)
0x09, 0xB6, // Usage (Scan Previous Track)
0x09, 0xCD, // Usage (Play/Pause)
0x09, 0xC0, // Usage (AL Consumer Control Configuration)MediaPlayer
0x09, 0xC1, // Usage (AC Back)
// Report ID 4: keyboard
0x09, 0x06, // Usage (Keyboard)
0x85, 0x04, // Report Id 4
0x05, 0x07, // Usage Page (Key Codes)
0x19, 0xe0, // Usage Minimum (224)
0x29, 0xe7, // Usage Maximum (231)
0x95, 0x08, // Report Count (8)
0x81, 0x01, // Input (Constant) reserved byte(1)
0x05, 0x08, // Usage Page (Page# for LEDs)
0x19, 0x01, // Usage Minimum (1)
0x29, 0x05, // Usage Maximum (5)
0x91, 0x02, // Output (Data, Variable, Absolute), Led report
0x91, 0x01, // Output (Data, Variable, Absolute), Led report padding
0x95, 0x06, // Report Count (6)
0x25, 0x65, // Logical Maximum (101)
0x05, 0x07, // Usage Page (Key codes)
0x19, 0x00, // Usage Minimum (0)
0x29, 0x65, // Usage Maximum (101)
0x81, 0x00, // Input (Data, Array) Key array(6 bytes)
0x09, 0x05, // Usage (Vendor Defined)
0x26, 0xFF, 0x00, // Logical Maximum (255)
0x75, 0x08, // Report Count (2)
0x95, 0x02, // Report Size (8 bit)
0xB1, 0x02, // Feature (Data, Variable, Absolute)
0xC0 // End Collection
memset(inp_rep_array, 0, sizeof(inp_rep_array));
// Initialize HID Service.
p_input_report = &inp_rep_array[INPUT_REP_BUTTONS_INDEX];
p_input_report->max_len = INPUT_REP_BUTTONS_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_BUTTONS_ID;
p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.write_perm);
p_input_report = &inp_rep_array[INPUT_REP_MOVEMENT_INDEX];
p_input_report->max_len = INPUT_REP_MOVEMENT_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_MOVEMENT_ID;
p_input_report = &inp_rep_array[INPUT_REP_MPLAYER_INDEX];
p_input_report->max_len = INPUT_REP_MEDIA_PLAYER_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_MPLAYER_ID;
p_input_report = &inp_rep_array[INPUT_REP_KEYBOARD_INDEX];
p_input_report->max_len = INPUT_REP_KEYBOARD_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_KEYBOARD_ID;
p_output_report = &outp_rep_array[OUTPUT_REP_KEYBOARD_INDEX];
p_output_report->max_len = OUTPUT_REP_KEYBOARD_LEN;
p_output_report->rep_ref.report_id = OUTPUT_REP_REF_KEYBOARD_ID;
p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.write_perm);
hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
memset(&hids_init_obj, 0, sizeof(hids_init_obj));
hids_init_obj.evt_handler = on_hids_evt;
hids_init_obj.error_handler = NULL;
hids_init_obj.is_kb = true;
hids_init_obj.is_mouse = true;
hids_init_obj.inp_rep_count = INPUT_REPORT_COUNT;
hids_init_obj.p_inp_rep_array = inp_rep_array;
hids_init_obj.outp_rep_count = 1;
hids_init_obj.p_outp_rep_array = outp_rep_array;
hids_init_obj.feature_rep_count = 0;
hids_init_obj.p_feature_rep_array = NULL;
hids_init_obj.rep_map.data_len = sizeof(rep_map_data);
hids_init_obj.rep_map.p_data = rep_map_data;
hids_init_obj.hid_information.bcd_hid = BASE_USB_HID_SPEC_VERSION;
hids_init_obj.hid_information.b_country_code = 0;
hids_init_obj.hid_information.flags = hid_info_flags;
hids_init_obj.included_services_count = 0;
hids_init_obj.p_included_services_array = NULL;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.rep_map.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.rep_map.security_mode.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.hid_information.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.hid_information.security_mode.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_mouse_inp_rep.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_mouse_inp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_mouse_inp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_boot_kb_inp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_ctrl_point.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_ctrl_point.write_perm);
err_code = ble_hids_init(&m_hids, &hids_init_obj);
