we are using nrf9160 custom board. Modem connected to LTE network but it is not connected to AWS cloud service. It's giving the -111 error, means connection refused. But with same esim card connected to AWS modem version of 1.2.3.
Hi charlie,
Please find the attached file nrf9160 development kit modem tracing.
I can't able to find the custom board tracings, in the trace collector itself port not showing, but port showing in programmer.
Hi Jagadish,
The recording nRF9160DK.bin is still not valid. Let's do a simple test with your nRF9160DK.
1) You can build nRF9160: AWS IoT — nRF Connect SDK 2.2.0 documentation (nordicsemi.com) by just adding "CONFIG_NRF_MODEM_LIB_TRACE=y" and getting firmware.
2) Open Trace Collector V2 preview and start tracing, you will see File size increasing.
3) The pcapng file can be opened by Wireshark and you would find communication traffic in different levels of the OSI model.
Can you confirm everything works with this flow?
Charlie
Hi charlie,
trace-2023-02-16T10-02-50.404Z.pcapng
Please find the attached tracing file from nrf9160DK develpement kit. but cannot able to find from custom board. Custom board connected to nrf9160DK board over JTAG.
Hi Jagadish,
Very good! Now we can move forward a bit now.
Modem trace using UART1 as output backend. Can you enable modem trace in your firmware and collect modem trace from your UART1 port?
Maybe you need to use a USB to UART Adapter to collect with your PC. Let me know if you need more help.
Charlie
Hi charlie,
i have to use nrf9160DK (or) our custom board? and tell me which pins i have to use for uart1?
if need to take modem trace from our custom board then we are using P13 and P14 pins are using for uart1.
is it possible to take modem trace in our custom board?
reply me ASAP so we can test modem trace based on your reply.
Thanks
