nPM1100. From were this current is coming?
Hi All.
I am using your NPM1100 PMIC as part of an IoT project in which low consumption is a critical restriction. The PMIC is working as expected, but there is a detail I don't understand. Once the charging cycle is completed and the green LED gets off, there is a remaining consumption of 1,7 to 1,9 mA through the VBUS, even if I disconnect the charged battery from VBAT and the secondary load from VOUTB. All this happens with the SW1 switch set to automatic, and If I set it to PWM -still with the secondary load disconnected-, the leak current goes even higher till 5,5 mA.
Could you tell me where this current is coming from? Can I be sure that this current won't load the battery, diminishing the module power autonomy once the primary charging power gets disconnected from VBUS?
Thanks
