nRF5340 audio DK, CONFIG_BT_SHELL Question
I am using nRF Connect SDK v2.1.1 with nRF5340 audio DK PCA10121. I am able to have LC3 audio CIS example code working for gateway and headset. I turned on CONFIG_BT_SHELL to be enable BT shell for cmd_fal_add() but I got into compiler error. Here are my prj.conf configuration:
# Shell related defines
CONFIG_SHELL=y
CONFIG_KERNEL_SHELL=y
CONFIG_USE_SEGGER_RTT=y
## Disable logs on RTT
CONFIG_SHELL_RTT_INIT_LOG_LEVEL_NONE=y
CONFIG_SHELL_BACKEND_RTT=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_SHELL_VT100_COLORS=y
CONFIG_SHELL_STACK_SIZE=4096
CONFIG_SHELL_CMD_BUFF_SIZE=128
## Reduce shell memory usage
CONFIG_SHELL_WILDCARD=n
CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=n
CONFIG_SHELL_STATS=n
CONFIG_SHELL_CMDS=n
CONFIG_SHELL_HISTORY=y
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SHELL=y
CONFIG_BT_FILTER_ACCEPT_LIST=y
The compiler error is:
c:/ncs/toolchains/v2.1.1/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr/subsys/bluetooth/shell/libsubsys__bluetooth__shell.a(audio.c.obj):C:\Projects\le-audio\gateway\zephyr\subsys\bluetooth\shell\audio.c:607: multiple definition of `unicast_client_cbs'; app/libapp.a(le_audio_cis_gateway.c.obj):C:\Projects\le-audio\gateway\gateway\src\bluetooth\le_audio_cis_gateway.c:195: first defined here
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.1.1\opt\bin\cmake.EXE' --build 'c:\Projects\le-audio\gateway\gateway\build'
When I comment out unicast_client_cbs in either audio.c:607 or le_audio_cis_gateway.c:195, I got different compiler errors. Do I need another CONFIG_BT option, that I don't see, for nRF Connect SDK v2.1.1 with nRF5340 audio DK PCA10121?
Dennis
  • Hi Dennis,
    While in NCS v2.1.1, please try following modifications in to your prj.conf file
    @@ -33,11 +33,11 @@ CONFIG_UART_CONSOLE=y
     CONFIG_SHELL=y
    -CONFIG_USE_SEGGER_RTT=y
    +CONFIG_USE_SEGGER_RTT=n
    -CONFIG_SHELL_BACKEND_RTT=y
    -CONFIG_SHELL_BACKEND_SERIAL=n
    +CONFIG_SHELL_BACKEND_RTT=n
    +CONFIG_SHELL_BACKEND_SERIAL=y
     CONFIG_SHELL_STACK_SIZE=1024
    @@ -45,7 +45,7 @@ CONFIG_SHELL_CMD_BUFF_SIZE=128
    -CONFIG_SHELL_CMDS=n
    +CONFIG_SHELL_CMDS=y
     # Turn off default shell commands
    @@ -54,7 +54,7 @@ CONFIG_HWINFO_SHELL=n
     CONFIG_CLOCK_CONTROL_NRF_SHELL=n
     CONFIG_FLASH_SHELL=n
     CONFIG_DEVICE_SHELL=n
    +CONFIG_BT_SHELL=y
     # Suppress err msg from sd_check_card_type. Because SPI_SDHC has no card presence method,
     # assume card is in slot. Thus error message is always shown if card is not inserted
     CONFIG_SD_LOG_LEVEL_OFF=y
    Additionally, you should consider upgrading to NCS v2.2.0. Please let me know if these changes work for you in both NCS v2.1.1 and v2.2.0.
    Dejan
  • I updated the CONFIGs for v2.1.1 and I did get v2.2.0. Same problems in both SDK. I read and looked at the compiler error. It is duplicated unicast_client_cbs in \gateway\zephyr\subsys\bluetooth\shell\audio.c:607 and \gateway\gateway\src\bluetooth\le_audio_cis_gateway.c:195. This is why the audio example works when CONFIG_BT_SHELL=n
  • I really need more information to get CONFIG_BT_SHELL=y working
  • To fix this, in \gateway\zephyr\subsys\bluetooth\shell\audio.c, I renamed unicast_client_cbs to audio_unicast_client_cbs to remove the duplicates
