nRF5340 ble_audio_services: Discovery of MCS failed (-61)
I'm working on developing a pair of true wireless earbuds using the nRF5340 Audio DK and have run into an issue where whenever I try to connect a device (eg. Pixel 6 Pro smartphone w/ Android 13 or Dell XPS 13 laptop running Windows 11) I get the error code: <err> ble_audio_services: Discovery of MCS failed (-61) over the serial connection followed by the DK disconnecting from my devices. You can see this series of events in the serial log below with my device connecting, failing MCS discovery, then disconnecting.
Here is the full serial output:
*** Booting Zephyr OS build v3.2.99-ncs1 ***
HL [00:00:00.259,368] <inf> fw_info:
nRF5340 Audio nRF5340 Audio DK cpuapp
NCS base version: 2.2.0
Cmake run : Thu Feb 02 12:25:36 2023
HL [00:00:00.259,399] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.259,399] <inf> fw_info: HEADSET left device
HL [00:00:00.270,019] <inf> board_version: Compatible board/HW version found: 1.0.0
HL [00:00:02.318,267] <wrn> bt_hci_core: Controller to host flow control not supported
HL [00:00:02.321,319] <inf> bt_hci_core: No ID address. App must call settings_load()
HL [00:00:02.321,380] <inf> ble: MAC: 00:00:00:00:00:00 (public)
HL [00:00:02.321,960] <inf> ble: Controller version: 3310
HL [00:00:02.324,676] <inf> bt_settings: Saving ID
HL [00:00:02.447,662] <inf> cis_headset: Advertising successfully started
HL [00:04:15.823,028] <inf> cis_headset: Connected: 4C:79:6E:D5:2C:CA (public)
HL [00:04:17.311,065] <err> ble_audio_services: Discovery of MCS failed (-61)
HL [00:04:22.593,444] <inf> cis_headset: Disconnected: 4C:79:6E:D5:2C:CA (public) (reason 0x13)
HL [00:04:22.594,055] <inf> cis_headset: Set direct advertising to 4C:79:6E:D5:2C:CA (public)
HL [00:04:22.594,696] <inf> cis_headset: Advertising successfully started
I am using the nrf5340_audio application example with no modifications. I have programmed it using the provided programming scripts in accordance with the programming guide. It is configured in headset CIS mode. Any assistance in determining the cause of this issue would be greatly appreciated, thanks!
