OS X VS Code nRF Electron Crash
VS Code v2023.1.44 will crash OS X Ventura 13.0.1 if I use nRF connect plugin and try to close the nRF terminal window after reflashing my board.
OS X crash report indicates that Electron is trying to use a bad pointer.  See crash report below.
I am running an 2021 14 in. M1 MacBook Pro.
Entering key stroke in this window will crash OS X:
Translated Report (Full Report Below)
Incident Identifier: 6EAA2B19-8160-4CC7-9532-9B7D9B1A4114
CrashReporter Key: D2FEB94C-94E5-9CDC-A227-EFA0ED6B2780
Hardware Model: MacBookPro18,3
Process: Electron [20596]
Path: /Applications/Visual Studio Code.app/Contents/MacOS/Electron
Identifier: com.microsoft.VSCode
Version: 1.75.0 (1.75.0)
Code Type: ARM-64 (Native)
Role: Unspecified
Parent Process: launchd [1]
Coalition: com.microsoft.VSCode [1018]
Responsible Process: [5815]
Date/Time: 2023-02-02 15:52:42.5173 -0700
Launch Time: 2023-02-02 15:52:41.7769 -0700
OS Version: macOS 13.0.1 (22A400)
Release Type: User
Report Version: 104
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0x000000019ca36560
Exception Codes: 0x0000000000000001, 0x000000019ca36560
VM Region Info: 0x19ca36560 is not in any region. Bytes after previous region: 2091885921
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
CoreAnimation 11fdf0000-11ff3c000 [ 1328K] rw-/rwx SM=PRV
UNUSED SPACE AT END
Termination Reason: SIGNAL 11 Segmentation fault: 11
Terminating Process: exc handler [20596]
Highlighted by Thread: 0
Backtrace not available
No thread state (register information) available
Binary Images:
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
Error Formulating Crash Report:
_dyld_process_info_create failed with 1
dyld_process_snapshot_create_for_process failed with 1
Failed to create CSSymbolicatorRef - corpse still valid ¯\_(ツ)_/¯
thread_get_state(PAGEIN) returned 0x10000003: (ipc/send) invalid destination port
thread_get_state(EXCEPTION) returned 0x10000003: (ipc/send) invalid destination port
thread_get_state(FLAVOR) returned 0x10000003: (ipc/send) invalid destination port
EOF
Full Report
{"app_name":"Electron","timestamp":"2023-02-02 15:52:43.00 -0700","app_version":"1.75.0","slice_uuid":"4c4c4486-5555-3144-a10d-816007e70c27","build_version":"1.75.0","platform":0,"bundleID":"com.microsoft.VSCode","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.0.1 (22A400)","roots_installed":0,"name":"Electron","incident_id":"6EAA2B19-8160-4CC7-9532-9B7D9B1A4114"}
"uptime" : 2800,
"procRole" : "Unspecified",
"version" : 2,
"userID" : 502,
"deployVersion" : 210,
"modelCode" : "MacBookPro18,3",
"coalitionID" : 1018,
"osVersion" : {
"train" : "macOS 13.0.1",
"build" : "22A400",
"releaseType" : "User"
"captureTime" : "2023-02-02 15:52:42.5173 -0700",
"incident" : "6EAA2B19-8160-4CC7-9532-9B7D9B1A4114",
"pid" : 20596,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2023-02-02 15:52:41.7769 -0700",
"procStartAbsTime" : 67909428274,
"procExitAbsTime" : 67910033191,
"procName" : "Electron",
"procPath" : "\/Applications\/Visual Studio Code.app\/Contents\/MacOS\/Electron",
"bundleInfo" : {"CFBundleShortVersionString":"1.75.0","CFBundleVersion":"1.75.0","CFBundleIdentifier":"com.microsoft.VSCode"},
"storeInfo" : {"deviceIdentifierForVendor":"A5834012-1CD3-57AD-B644-12A8C2794B53","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.microsoft.VSCode",
"crashReporterKey" : "D2FEB94C-94E5-9CDC-A227-EFA0ED6B2780",
"responsiblePid" : 5815,
"sip" : "enabled",
"vmRegionInfo" : "0x19ca36560 is not in any region. Bytes after previous region: 2091885921 \n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n CoreAnimation 11fdf0000-11ff3c000 [ 1328K] rw-\/rwx SM=PRV \n---> \n UNUSED SPACE AT END",
"exception" : {"codes":"0x0000000000000001, 0x000000019ca36560","rawCodes":[1,6922921312],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x000000019ca36560"},
"termination" : {"flags":1024,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":20596},
"vmregioninfo" : "0x19ca36560 is not in any region. Bytes after previous region: 2091885921 \n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n CoreAnimation 11fdf0000-11ff3c000 [ 1328K] rw-\/rwx SM=PRV \n---> \n UNUSED SPACE AT END",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"usedImages" : [
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"legacyInfo" : {
"threadHighlighted" : 0
"reportNotes" : [
"_dyld_process_info_create failed with 1",
"dyld_process_snapshot_create_for_process failed with 1",
"Failed to create CSSymbolicatorRef - corpse still valid ¯\\_(ツ)_\/¯",
"thread_get_state(PAGEIN) returned 0x10000003: (ipc\/send) invalid destination port",
"thread_get_state(EXCEPTION) returned 0x10000003: (ipc\/send) invalid destination port",
"thread_get_state(FLAVOR) returned 0x10000003: (ipc\/send) invalid destination port"
