The following error occurred When I compile the project under E:\ncs_work\v2.2.0\nrf\samples\openthread\cli
Please tell me that I should solve this problem
Scroll up, the detailed error message could be a few hundred lines above.
Building cli
west build --build-dir e:\ncs_work\myapps\cli\build e:\ncs_work\myapps\cli
[1/606] Generating include/generated/version.h
-- Zephyr version: 3.2.99 (E:/ncs_work/v2.2.0/zephyr), build: v3.2.99-ncs1
[2/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/base64.c.obj
[3/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/asn1parse.c.obj
[4/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/nist_kw.c.obj
[5/606] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[6/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/asn1write.c.obj
[7/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/padlock.c.obj
[8/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/bignum.c.obj
[9/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/platform.c.obj
[10/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/oid.c.obj
[11/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/version.c.obj
[12/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/platform_util.c.obj
[13/606] Generating include/generated/driver-validation.h
[14/606] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[15/606] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[16/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/E_/ncs_work/v2.2.0/mbedtls/library/constant_time.c.obj
[17/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_hash.c.obj
[18/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto.c.obj
[19/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_ecp.c.obj
[20/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_client.c.obj
[21/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_aead.c.obj
[22/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_cipher.c.obj
[23/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_coap_secure.cpp.obj
[24/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_coap.cpp.obj
[25/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_history.cpp.obj
[26/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_commissioner.cpp.obj
[27/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_joiner.cpp.obj
[28/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/data.cpp.obj
[29/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli.cpp.obj
[30/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/frame_builder.cpp.obj
[31/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/frame_data.cpp.obj
[32/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_dataset.cpp.obj
[33/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/error.cpp.obj
[34/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_network_data.cpp.obj
[35/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_tcp.cpp.obj
[36/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/border_agent_api.cpp.obj
[37/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/backbone_router_ftd_api.cpp.obj
[38/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_srp_server.cpp.obj
[39/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/border_router_api.cpp.obj
[40/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_udp.cpp.obj
[41/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_output.cpp.obj
[42/606] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_srp_client.cpp.obj
[43/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/channel_manager_api.cpp.obj
[44/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/border_routing_api.cpp.obj
[45/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/channel_monitor_api.cpp.obj
[46/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/backbone_router_api.cpp.obj
[47/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/child_supervision_api.cpp.obj
[48/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/commissioner_api.cpp.obj
[49/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/coap_secure_api.cpp.obj
[50/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dataset_updater_api.cpp.obj
[51/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/crypto_api.cpp.obj
[52/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/coap_api.cpp.obj
[53/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dataset_ftd_api.cpp.obj
[54/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dataset_api.cpp.obj
[55/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/error_api.cpp.obj
[56/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/history_tracker_api.cpp.obj
[57/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/diags_api.cpp.obj
[58/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_api.cpp.obj
[59/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/heap_api.cpp.obj
[60/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_server_api.cpp.obj
[61/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/jam_detection_api.cpp.obj
[62/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/instance_api.cpp.obj
[63/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/icmp6_api.cpp.obj
[64/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ip6_api.cpp.obj
[65/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_metrics_api.cpp.obj
[66/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/logging_api.cpp.obj
[67/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_api.cpp.obj
[68/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/multi_radio_api.cpp.obj
[69/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/joiner_api.cpp.obj
[70/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_raw_api.cpp.obj
[71/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/nat64_api.cpp.obj
[72/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/network_time_api.cpp.obj
[73/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/netdata_publisher_api.cpp.obj
[74/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/message_api.cpp.obj
[75/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/netdata_api.cpp.obj
[76/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ping_sender_api.cpp.obj
[77/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/random_crypto_api.cpp.obj
[78/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/netdiag_api.cpp.obj
[79/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/random_noncrypto_api.cpp.obj
[80/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/server_api.cpp.obj
[81/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/tcp_api.cpp.obj
[82/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/sntp_api.cpp.obj
[83/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/srp_server_api.cpp.obj
[84/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/srp_client_api.cpp.obj
[85/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/tcp_ext_api.cpp.obj
[86/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/srp_client_buffers_api.cpp.obj
[87/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/trel_api.cpp.obj
[88/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/tasklet_api.cpp.obj
[89/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/bbr_local.cpp.obj
[90/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/bbr_manager.cpp.obj
[91/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/thread_ftd_api.cpp.obj
[92/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/backbone_tmf.cpp.obj
[93/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/thread_api.cpp.obj
[94/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/ndproxy_table.cpp.obj
[95/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/bbr_leader.cpp.obj
[96/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/border_router/infra_if.cpp.obj
[97/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/border_router/routing_manager.cpp.obj
[98/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/multicast_listeners_table.cpp.obj
[99/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/udp_api.cpp.obj
[100/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/binary_search.cpp.obj
[101/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/crc16.cpp.obj
[102/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/appender.cpp.obj
[103/606] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[104/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/coap/coap_message.cpp.obj
[105/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/socket.cpp.obj
[106/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/coap/coap_secure.cpp.obj
[107/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/coap/coap.cpp.obj
[108/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/netif.cpp.obj
[109/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/heap_data.cpp.obj
[110/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/sntp_client.cpp.obj
[111/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/heap_string.cpp.obj
[112/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/heap.cpp.obj
[113/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/random.cpp.obj
[114/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/srp_client.cpp.obj
[115/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/instance.cpp.obj
[116/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/message.cpp.obj
[117/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/log.cpp.obj
[118/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/string.cpp.obj
[119/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/notifier.cpp.obj
[120/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/settings.cpp.obj
[121/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/trickle_timer.cpp.obj
[122/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/timer.cpp.obj
[123/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/uptime.cpp.obj
[124/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/tasklet.cpp.obj
[125/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/time_ticker.cpp.obj
[126/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/aes_ccm.cpp.obj
[127/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/ecdsa.cpp.obj
[128/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/tlvs.cpp.obj
[129/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/aes_ecb.cpp.obj
[130/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/hkdf_sha256.cpp.obj
[131/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/pbkdf2_cmac.cpp.obj
[132/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/storage.cpp.obj
[133/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/hmac_sha256.cpp.obj
[134/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/mbedtls.cpp.obj
[135/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/crypto_platform.cpp.obj
[136/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/sha256.cpp.obj
[137/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/channel_mask.cpp.obj
[138/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/data_poll_handler.cpp.obj
[139/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_filter.cpp.obj
[140/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/data_poll_sender.cpp.obj
[141/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/diags/factory_diags.cpp.obj
[142/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_frame.cpp.obj
[143/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac.cpp.obj
[144/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/link_raw.cpp.obj
[145/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_types.cpp.obj
[146/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/sub_mac_callbacks.cpp.obj
[147/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/sub_mac.cpp.obj
[148/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/border_agent.cpp.obj
[149/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_links.cpp.obj
[150/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/announce_begin_client.cpp.obj
[151/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_local.cpp.obj
[152/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_updater.cpp.obj
[153/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/commissioner.cpp.obj
[154/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset.cpp.obj
[155/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dtls.cpp.obj
[156/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_manager.cpp.obj
[157/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_manager_ftd.cpp.obj
[158/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/joiner_router.cpp.obj
[159/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/energy_scan_client.cpp.obj
[160/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/meshcop.cpp.obj
[161/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/extended_panid.cpp.obj
[162/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/meshcop_tlvs.cpp.obj
[163/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/checksum.cpp.obj
[164/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/joiner.cpp.obj
[165/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/network_name.cpp.obj
[166/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/meshcop_leader.cpp.obj
[167/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/panid_query_client.cpp.obj
[168/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/timestamp.cpp.obj
[169/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dnssd_server.cpp.obj
[170/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dns_dso.cpp.obj
[171/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dhcp6_server.cpp.obj
[172/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dhcp6_client.cpp.obj
[173/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/icmp6.cpp.obj
[174/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip4_types.cpp.obj
[175/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dns_client.cpp.obj
[176/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dns_types.cpp.obj
[177/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_address.cpp.obj
[178/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/nd6.cpp.obj
[179/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/nat64_translator.cpp.obj
[180/606] cmd.exe /C "cd /D E:\ncs_work\myapps\cli\build\modules\openthread\build && E:\ncs_work\toolchains\v2.2.0\opt\bin\cmake.exe -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0;OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0;OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0;OPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0;OPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0;OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1;OPENTHREAD_CONFIG_COAP_API_ENABLE=1;OPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0;OPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0;OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=1;OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0;OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=1;OPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1;OPENTHREAD_CONFIG_DIAG_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DNS_DSO_ENABLE=0;OPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0;OPENTHREAD_CONFIG_DUA_ENABLE=1;OPENTHREAD_CONFIG_ECDSA_ENABLE=1;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1;OPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1;OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=1;OPENTHREAD_CONFIG_JOINER_ENABLE=1;OPENTHREAD_CONFIG_LEGACY_ENABLE=0;OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=1;OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=1;OPENTHREAD_CONFIG_LINK_RAW_ENABLE=1;OPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0;OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=1;OPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0;OPENTHREAD_CONFIG_MLR_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1;OPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0;OPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0;OPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0;OPENTHREAD_CONFIG_OTNS_ENABLE=0;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0;OPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0;OPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0;OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1;OPENTHREAD_SETTINGS_RAM=0;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0;OPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0;OPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0;OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1;OPENTHREAD_CONFIG_UPTIME_ENABLE=0;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_3;OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=1;_ANSI_SOURCE;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=0;__PROGRAM_START;NRF52833_XXAA;NRF_802154_CCA_CORR_LIMIT_DEFAULT=2;NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45;NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45;NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=16;NRF_802154_PENDING_EXTENDED_ADDRESSES=16;NRF_802154_RX_BUFFERS=16;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_ENCRYPTION_ENABLED=1;NRF_802154_SECURITY_WRITER_ENABLED=1;NRF_802154_IE_WRITER_ENABLED=1;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;NRF_802154_ECB_PRIORITY=-1;NRF_802154_SWI_PRIORITY=1;MBEDTLS_CONFIG_FILE="nrf-config.h";MBEDTLS_USER_CONFIG_FILE="nrf-config-user.h"" -P E:/ncs_work/v2.2.0/modules/lib/openthread/etc/cmake/print.cmake"
PACKAGE_NAME=OPENTHREAD
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=1
_ANSI_SOURCE
__PROGRAM_START
NRF52833_XXAA
MBEDTLS_CONFIG_FILE=nrf-config.h
MBEDTLS_USER_CONFIG_FILE=nrf-config-user.h
[181/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_filter.cpp.obj
[182/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/nd_agent.cpp.obj
[183/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_headers.cpp.obj
[184/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6.cpp.obj
[185/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/tcp6_ext.cpp.obj
[186/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_mpl.cpp.obj
[187/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/srp_server.cpp.obj
[188/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/tcp6.cpp.obj
[189/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/radio.cpp.obj
[190/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/trel_link.cpp.obj
[191/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/trel_interface.cpp.obj
[192/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/trel_packet.cpp.obj
[193/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/udp6.cpp.obj
[194/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/radio_callbacks.cpp.obj
[195/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/radio_platform.cpp.obj
[196/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/announce_begin_server.cpp.obj
[197/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/address_resolver.cpp.obj
[198/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/announce_sender.cpp.obj
[199/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/anycast_locator.cpp.obj
[200/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/csl_tx_scheduler.cpp.obj
[201/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/discover_scanner.cpp.obj
[202/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/child_table.cpp.obj
[203/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/dua_manager.cpp.obj
[204/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/indirect_sender.cpp.obj
[205/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/link_metrics.cpp.obj
[206/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/key_manager.cpp.obj
[207/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/link_metrics_types.cpp.obj
[208/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/energy_scan_server.cpp.obj
[209/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle_types.cpp.obj
[210/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder.cpp.obj
[211/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/link_quality.cpp.obj
[212/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder_ftd.cpp.obj
[213/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/lowpan.cpp.obj
[214/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder_mtd.cpp.obj
[215/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle_router.cpp.obj
[216/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mlr_manager.cpp.obj
[217/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data.cpp.obj
[218/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_publisher.cpp.obj
[219/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/neighbor_table.cpp.obj
[220/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_leader.cpp.obj
[221/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle.cpp.obj
[222/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_service.cpp.obj
[223/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_local.cpp.obj
[224/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_tlvs.cpp.obj
[225/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_leader_ftd.cpp.obj
[226/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/radio_selector.cpp.obj
[227/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_notifier.cpp.obj
[228/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_types.cpp.obj
[229/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/time_sync_service.cpp.obj
[230/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/panid_query_server.cpp.obj
[231/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_diagnostic.cpp.obj
[232/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/uri_paths.cpp.obj
[233/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/thread_netif.cpp.obj
[234/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/router_table.cpp.obj
[235/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/channel_manager.cpp.obj
[236/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/heap.cpp.obj
[237/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/src_match_controller.cpp.obj
[238/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/history_tracker.cpp.obj
[239/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/topology.cpp.obj
[240/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/tmf.cpp.obj
[241/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/flash.cpp.obj
[242/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/channel_monitor.cpp.obj
[243/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/child_supervision.cpp.obj
[244/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/otns.cpp.obj
[245/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/parse_cmdline.cpp.obj
[246/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/jam_detector.cpp.obj
[247/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/cc/cc_newreno.c.obj
[248/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/ping_sender.cpp.obj
[249/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_sack.c.obj
[250/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_output.c.obj
[251/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_reass.c.obj
[252/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/slaac_address.cpp.obj
[253/606] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/srp_client_buffers.cpp.obj
[254/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_timewait.c.obj
[255/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_input.c.obj
[256/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_timer.c.obj
[257/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_subr.c.obj
[258/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/bsdtcp/tcp_usrreq.c.obj
[259/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/lib/lbuf.c.obj
[260/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_rsa.c.obj
[261/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/lib/bitmap.c.obj
[262/606] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp-ftd.dir/lib/cbuf.c.obj
[263/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_slot_management.c.obj
[264/606] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
[265/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_storage.c.obj
[266/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/psa_crypto_mac.c.obj
[267/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/pkcs12.c.obj
[268/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
[269/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/pkparse.c.obj
[270/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/pem.c.obj
[271/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/pkcs5.c.obj
[272/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/dhm.c.obj
[273/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/cipher_wrap.c.obj
[274/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/pkwrite.c.obj
[275/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/cipher.c.obj
[276/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/pk_wrap.c.obj
[277/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/md.c.obj
[278/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/pk.c.obj
[279/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/sha1.c.obj
[280/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/sha256.c.obj
[281/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/ripemd160.c.obj
[282/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/aria.c.obj
[283/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/aesni.c.obj
[284/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/md5.c.obj
[285/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/sha512.c.obj
[286/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/camellia.c.obj
[287/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/ccm.c.obj
[288/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/des.c.obj
[289/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/cmac.c.obj
[290/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/chachapoly.c.obj
[291/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/ecp_curves.c.obj
[292/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/ecdsa.c.obj
[293/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/ecdh.c.obj
[294/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/rsa.c.obj
[295/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/hmac_drbg.c.obj
[296/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/gcm.c.obj
[297/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/ecp.c.obj
[298/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/hkdf.c.obj
[299/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
[300/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/entropy.c.obj
[301/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/rsa_alt_helpers.c.obj
[302/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/E_/ncs_work/v2.2.0/mbedtls/library/ctr_drbg.c.obj
[303/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
[304/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/E_/ncs_work/v2.2.0/mbedtls/library/x509_create.c.obj
[305/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/E_/ncs_work/v2.2.0/mbedtls/library/x509.c.obj
[306/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
[307/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/debug.c.obj
[308/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/E_/ncs_work/v2.2.0/mbedtls/library/x509write_csr.c.obj
[309/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/E_/ncs_work/v2.2.0/mbedtls/library/x509_crl.c.obj
[310/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/E_/ncs_work/v2.2.0/mbedtls/library/x509_csr.c.obj
[311/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/net_sockets.c.obj
[312/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/E_/ncs_work/v2.2.0/mbedtls/library/x509_crt.c.obj
[313/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_cookie.c.obj
[314/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_cache.c.obj
[315/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_ciphersuites.c.obj
[316/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_ticket.c.obj
[317/606] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[318/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_cli.c.obj
[319/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_srv.c.obj
[320/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_tls13_keys.c.obj
[321/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_msg.c.obj
[322/606] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedx509.a
[323/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/E_/ncs_work/v2.2.0/mbedtls/library/ssl_tls.c.obj
[324/606] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedtls.a
[325/606] Linking CXX static library modules\openthread\build\third_party\tcplp\libtcplp-ftd.a
[326/606] Linking CXX static library modules\openthread\build\src\core\libopenthread-ftd.a
[327/606] Linking CXX static library modules\openthread\build\src\cli\libopenthread-cli-ftd.a
[328/606] Generating include/generated/offsets.h
[329/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[330/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[331/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[332/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[333/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[334/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[335/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[336/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
[337/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[338/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[339/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[340/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/util/fnmatch/fnmatch.c.obj
[341/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/backends/shell_uart.c.obj
[342/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/devmem_service.c.obj
[343/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_fprintf.c.obj
[344/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/device_service.c.obj
[345/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
[346/606] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[347/606] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[348/606] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[349/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[350/606] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[351/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service.c.obj
[352/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell.c.obj
[353/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_wildcard.c.obj
[354/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_help.c.obj
[355/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_history.c.obj
[356/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_ops.c.obj
[357/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_cmds.c.obj
[358/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_virtual.c.obj
[359/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init.c.obj
[360/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init_array.c.obj
[361/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_dtors.c.obj
[362/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_utils.c.obj
[363/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_ctors.c.obj
[364/606] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_vtable.cpp.obj
[365/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
[366/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
[367/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
[368/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
[369/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
[370/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[371/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[372/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_default.c.obj
[373/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[374/606] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_new.cpp.obj
[375/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
[376/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
[377/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[378/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
[379/606] Generating linker_zephyr_pre1.cmd
[380/606] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[381/606] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[382/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[383/606] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
[384/606] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[385/606] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/api_init/mpsl_fem_api_init.c.obj
[386/606] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
[387/606] Building C object modules/nrf/subsys/ieee802154/CMakeFiles/..__nrf__subsys__ieee802154.dir/nrf_802154_configurator.c.obj
[388/606] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
[389/606] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
[390/606] Building C object modules/nrf/drivers/mpsl/temp_nrf5/CMakeFiles/..__nrf__drivers__mpsl__temp_nrf5.dir/temp_nrf5_mpsl.c.obj
[391/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[392/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[393/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[394/606] Linking CXX static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[395/606] Linking CXX static library modules\nrf\subsys\mpsl\fem\lib..__nrf__subsys__mpsl__fem.a
[396/606] Linking CXX static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
[397/606] Linking CXX static library modules\nrf\subsys\ieee802154\lib..__nrf__subsys__ieee802154.a
[398/606] Linking CXX static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
[399/606] Linking CXX static library modules\nrf\drivers\mpsl\flash_sync\lib..__nrf__drivers__mpsl__flash_sync.a
[400/606] Linking CXX static library modules\nrf\drivers\mpsl\temp_nrf5\lib..__nrf__drivers__mpsl__temp_nrf5.a
[401/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[402/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[403/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[404/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[405/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[406/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[407/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[408/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[409/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[410/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[411/606] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[412/606] Building C object CMakeFiles/app.dir/src/main.c.obj
[413/606] Generating linker_zephyr_pre0.cmd
[414/606] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[415/606] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[416/606] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[417/606] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[418/606] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[419/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[420/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[421/606] Linking CXX static library zephyr\libzephyr.a
[422/606] Linking CXX static library app\libapp.a
[423/606] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[424/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[425/606] Linking CXX static library zephyr\arch\common\libisr_tables.a
[426/606] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[427/606] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/__aeabi_atexit.c.obj
[428/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[429/606] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[430/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[431/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[432/606] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[433/606] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[434/606] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[435/606] Linking CXX static library zephyr\arch\common\libarch__common.a
[436/606] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[437/606] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[438/606] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[439/606] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[440/606] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[441/606] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
[442/606] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[443/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6_nbr.c.obj
[444/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_tc.c.obj
[445/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv6.c.obj
[446/606] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[447/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/nbr.c.obj
[448/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmpv6.c.obj
[449/606] Linking CXX static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[450/606] Linking CXX static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
[451/606] Linking CXX static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[452/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/connection.c.obj
[453/606] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[454/606] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
[455/606] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[456/606] Building C object zephyr/subsys/net/l2/openthread/CMakeFiles/subsys__net__ip__l2__openthread.dir/openthread.c.obj
[457/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
[458/606] Building C object zephyr/subsys/net/l2/openthread/CMakeFiles/subsys__net__ip__l2__openthread.dir/openthread_utils.c.obj
[459/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
[460/606] Linking CXX static library zephyr\subsys\net\libsubsys__net.a
[461/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
[462/606] Linking CXX static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
[463/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_pkt.c.obj
[464/606] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[465/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_context.c.obj
[466/606] Linking CXX static library zephyr\subsys\net\l2\openthread\libsubsys__net__ip__l2__openthread.a
[467/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/udp.c.obj
[468/606] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[469/606] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
[470/606] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[471/606] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[472/606] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
[473/606] Linking CXX static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[474/606] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_shell.c.obj
[475/606] Building C object zephyr/drivers/sensor/CMakeFiles/drivers__sensor.dir/sensor_shell.c.obj
[476/606] Building C object zephyr/drivers/ieee802154/CMakeFiles/drivers__ieee802154.dir/ieee802154_nrf5.c.obj
[477/606] Linking CXX static library zephyr\subsys\random\libsubsys__random.a
[478/606] Linking CXX static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
[479/606] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[480/606] Linking CXX static library zephyr\drivers\console\libdrivers__console.a
[481/606] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_shell.c.obj
[482/606] Linking CXX static library zephyr\subsys\net\ip\libsubsys__net__ip.a
[483/606] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[484/606] Linking CXX static library zephyr\drivers\gpio\libdrivers__gpio.a
[485/606] Linking CXX static library zephyr\drivers\sensor\libdrivers__sensor.a
[486/606] Linking CXX static library zephyr\drivers\ieee802154\libdrivers__ieee802154.a
[487/606] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
[488/606] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[489/606] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[490/606] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[491/606] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[492/606] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[493/606] Linking CXX static library zephyr\drivers\flash\libdrivers__flash.a
[494/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/alarm.c.obj
[495/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/entropy.c.obj
[496/606] Linking CXX static library zephyr\drivers\entropy\libdrivers__entropy.a
[497/606] Linking CXX static library zephyr\drivers\serial\libdrivers__serial.a
[498/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/radio.c.obj
[499/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/spi.c.obj
[500/606] Linking CXX static library zephyr\drivers\timer\libdrivers__timer.a
[501/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/diag.c.obj
[502/606] Linking CXX static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[503/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/platform.c.obj
[504/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/misc.c.obj
[505/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/logging.c.obj
[506/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/memory.c.obj
[507/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/settings.c.obj
[508/606] Building C object modules/openthread/platform/CMakeFiles/openthread_platform.dir/shell.c.obj
[509/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_zephyr.c.obj
[510/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/radio/platform/nrf_802154_random_zephyr.c.obj
[511/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_clock_zephyr.c.obj
[512/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_gpiote_crit_sect.c.obj
[513/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_irq_zephyr.c.obj
[514/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/E_/ncs_work/v2.2.0/nrf/modules/nrfxlib/nrf_802154/sl/platform/nrf_802154_platform_sl_lptimer_zephyr.c.obj
[515/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/E_/ncs_work/v2.2.0/nrf/modules/nrfxlib/nrf_802154/sl/platform/nrf_802154_hp_timer.c.obj
[516/606] Building C object modules/hal_nordic/nrf_802154/CMakeFiles/nrf-802154-platform.dir/sl_opensource/platform/nrf_802154_temperature_zephyr.c.obj
[517/606] Linking CXX static library modules\openthread\platform\libopenthread_platform.a
[518/606] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/E_/ncs_work/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf52833.c.obj
[519/606] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/E_/ncs_work/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[520/606] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/E_/ncs_work/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[521/606] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[522/606] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/E_/ncs_work/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[523/606] Building C object modules/segger/CMakeFiles/modules__segger.dir/E_/ncs_work/v2.2.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
[524/606] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/E_/ncs_work/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
[525/606] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
[526/606] Linking CXX static library modules\hal_nordic\nrf_802154\libnrf-802154-platform.a
[527/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[528/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[529/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[530/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[531/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[532/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[533/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/__/legacy/entropy_poll.c.obj
[534/606] Linking CXX static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[535/606] Linking CXX static library modules\segger\libmodules__segger.a
[536/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/E_/ncs_work/v2.2.0/mbedtls/library/memory_buffer_alloc.c.obj
[537/606] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/__/legacy/mbedtls_heap.c.obj
[538/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154.c.obj
[539/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug_assert.c.obj
[540/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_aes_ccm.c.obj
[541/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core_hooks.c.obj
[542/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_core.c.obj
[543/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_encrypt.c.obj
[544/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_critical_section.c.obj
[545/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug.c.obj
[546/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rx_buffer.c.obj
[547/606] Linking CXX static library modules\nrfxlib\nrfxlib\nrf_security\src\zephyr\libmbedtls_zephyr.a
[548/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_rssi.c.obj
[549/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_peripherals_alloc.c.obj
[550/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_queue.c.obj
[551/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_pib.c.obj
[552/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_dppi.c.obj
[553/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_swi.c.obj
[554/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_stats.c.obj
[555/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx_ppi.c.obj
[556/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_trx.c.obj
[557/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_csma_ca.c.obj
[558/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_tx_power.c.obj
[559/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_tx_work_buffer.c.obj
[560/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_delayed_trx.c.obj
[561/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_pib_ram.c.obj
[562/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ie_writer.c.obj
[563/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_ifs.c.obj
[564/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_filter.c.obj
[565/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_frame_parser.c.obj
[566/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_data.c.obj
[567/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_ack_generator.c.obj
[568/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_enh_ack_generator.c.obj
[569/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_security_writer.c.obj
[570/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/nrf_802154_precise_ack_timeout.c.obj
[571/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_request_swi.c.obj
[572/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/mac_features/ack_generator/nrf_802154_imm_ack_generator.c.obj
[573/606] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_notification_swi.c.obj
[574/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[575/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[576/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[577/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[578/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[579/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[580/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[581/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[582/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[583/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[584/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[585/606] Linking CXX static library modules\nrfxlib\nrf_802154\nrf_802154\driver\libnrf-802154-driver.a
[586/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[587/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[588/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[589/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[590/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[591/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[592/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[593/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[594/606] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
[595/606] Linking CXX static library zephyr\kernel\libkernel.a
[596/606] Linking CXX executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && E:\ncs_work\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-g++.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D E:\ncs_work\myapps\cli\build\zephyr && E:\ncs_work\toolchains\v2.2.0\opt\bin\cmake.exe -E echo ""
e:/ncs_work/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
e:/ncs_work/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 18096 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'e:\ncs_work\toolchains\v2.2.0\opt\bin\cmake.EXE' --build 'e:\ncs_work\myapps\cli\build'
* Terminal process has terminated, exit code: 1.
* The terminal will be reused by the task, press any key to close.
Here's all the print information Can't find any error on it I don't know what the problem is
I recompiled it and this is the specific error information
There is a wr0ng number in your overlay: 7A000 vs. 7C000. Might be inherited from the board, check the generated dts in build/zephyr.
It has been solved as you said
thank you very much!
