TLS Socket connection request return with error number -22(EINVAL)
Hi All,
I am trying to setup a thread network to send  RPC message to a remote http server:https://mainnet.incubed.net). I took http_client sample(sdk-zephyr) and modified slightly to adapt to my application. .
I was successful in sending RPC message to the server via TCP socket connection but I am really struggling to open secure channel(TLS) for communicating with the server. When my application tries to connect using TLS socket it throws an error with error number -22(EINVAL). I am not quite sure why and what mistake I did with respect to config options.
[00:00:58.561,645] <dbg> http_client: in3_register_https_client: in3 register https
[00:00:58.594,177] <dbg> http_client: setup_socket: Server address: fd97:6739:93e:2:0:0:A756:5EF8
[00:00:58.594,360] <dbg> net_sock_tls: tls_alloc: (main): Allocated TLS context, 0x20003478
[00:00:58.594,665] <dbg> net_tcp: tcp_conn_ref: (main): conn: 0x2002d320, ref_count: 1
[00:00:58.594,696] <dbg> net_tcp: tcp_conn_alloc: (main): conn: 0x2002d320
[00:00:58.594,757] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x2001031c, fd=1
[00:00:58.594,940] <dbg> net_ctx: net_context_bind: (main): Context 0x2001031c binding to TCP [::]:41215 iface 1 (0x20000a98)
[00:00:58.595,031] <dbg> net_tcp: net_tcp_connect: (main): context: 0x2001031c, local: ::, remote: fd97:6739:93e:2::a756:5ef8
[00:00:58.595,214] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2002d320 src: fd97:6739:93e:1:649e:fad5:e7ab:366d, dst: fd97:6739:93e:2::a756:5ef8
[00:00:58.595,336] <dbg> net_conn: conn_register_debug: (main): [0x200107b8/6/2/0x3f] remote fd97:6739:93e:2::a756:5ef8/443
[00:00:58.595,397] <dbg> net_conn: conn_register_debug: (main):   local ::/41215 cb 0x16fc9 ud 0x2001031c
[00:00:58.595,520] <dbg> net_tcp: tcp_in: (main):  [LISTEN Seq=548241854 Ack=0]
[00:00:58.595,764] <dbg> net_tcp: tcp_out_ext: (main): SYN Seq=548241854 Len=0
[00:00:58.595,947] <dbg> net_tcp: tcp_send_process_no_lock: (main): SYN Seq=548241854 Len=0
[00:00:58.596,160] <dbg> net_tcp: tcp_send: (main): SYN Seq=548241854 Len=0
[00:00:58.596,862] <dbg> net_tcp: tcp_in: (main): LISTEN->SYN_SENT
[00:00:58.648,925] <dbg> net_conn: net_conn_input: (rx_q[0]): Check TCP listener for pkt 0x2002c6d0 src port 443 dst port 41215 family 2
[00:00:58.648,956] <dbg> net_conn: net_conn_input: (rx_q[0]): [0x200107b8] match found cb 0x16fc9 ud 0x2001031c rank 0x3f
[00:00:58.649,261] <dbg> net_tcp: tcp_in: (rx_q[0]): SYN,ACK Seq=3167820546 Ack=548241855 Len=0 [SYN_SENT Seq=548241855 Ack=0]
[00:00:58.649,322] <dbg> net_tcp: tcp_options_check: (rx_q[0]): len=4
[00:00:58.649,353] <dbg> net_tcp: tcp_options_check: (rx_q[0]): opt: 2, opt_len: 4
[00:00:58.649,353] <dbg> net_tcp: tcp_options_check: (rx_q[0]): MSS=1460
[00:00:58.649,383] <dbg> net_tcp: tcp_in: (rx_q[0]): Lowering send window from 64240 to 3413
[00:00:58.649,414] <dbg> net_tcp: tcp_window_full: (rx_q[0]): conn: 0x2002d320 window_full=0
[00:00:58.649,597] <dbg> net_tcp: tcp_send_timer_cancel: (rx_q[0]): SYN Seq=548241854 Len=0
[00:00:58.649,902] <dbg> net_tcp: tcp_out_ext: (rx_q[0]): ACK Seq=548241855 Ack=3167820547 Len=0
[00:00:58.650,085] <dbg> net_tcp: tcp_send_process_no_lock: (rx_q[0]): ACK Seq=548241855 Ack=3167820547 Len=0
[00:00:58.650,268] <dbg> net_tcp: tcp_send: (rx_q[0]): ACK Seq=548241855 Ack=3167820547 Len=0
[00:00:58.650,390] <dbg> net_tcp: tcp_in: (rx_q[0]): SYN_SENT->ESTABLISHED
[00:00:58.650,604] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2002d320, ret=0
[00:00:58.650,665] <dbg> net_tcp: net_tcp_recv: (main): context: 0x2001031c, cb: 0x8ce1, user_data: (nil)
[00:00:58.662,567] <err> http_client: Cannot connect to IPv6 remote (-22)
[00:00:58.662,597] <err> http_client: Failed to connect to socket
[00:00:58.662,597] <dbg> http_client: run_https_post: starting tcp failed
[00:00:58.718,750] <dbg> main: main: Error sending rpc request: The request could not be send!
[00:01:06.033,477] <inf> net_l2_openthread: State changed! Flags: 0x00000064 Current role: router
#Socket settings
CONFIG_NET_SOCKETS_SOCKOPT_TLS=n
CONFIG_POSIX_MAX_FDS=8
CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=10
#MBEDTLS and security configuration
CONFIG_MBEDTLS_CFG_FILE="config-tls-generic.h"
CONFIG_OPENTHREAD_MBEDTLS_CHOICE=y
#CONFIG_MBEDTLS_TLS_VERSION_1_2=y
#CONFIG_MBEDTLS_TLS_LIBRARY=y
#CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# TLS configuration
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_BUILTIN=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=32768
CONFIG_MBEDTLS_X509_LIBRARY=y
CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y
# certificate must fit into one message, fragmenting is not supported
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=4096
Can someone tell me what should I try to resolve this problem.
Regards
Vipin Das
