nrf9160 HTTPs_CLIENT example not working
I'm using nrf9160dk  and i want to run HTTPS_CLIENT example to send some ping.
when i run the HTTPS_CLIENT  I'm getting error:-  "getaddrinfo() failed, err 0"
i haven't change anything in code expect  HTTPS_HOSTNAME.
please help to clear this Error.
Thanks
  • Hi Bhanu,
    Can you do a quick test with ICMP echo request #XPING? Try to ping both www.google.com and your target hostname.
    Charlie
  • Hi charlie,
    i need to post method and get method.
    may i know why  HTTPS_CLIENT  example code is not working and getting Error  "getaddrinfo() failed, err 0"
    below is example code for "HTTPS_CLIENT" I just changed the HTTPS_HOSTNAME.
     * Copyright (c) 2020 Nordic Semiconductor ASA
    #include <string.h>
    #include <zephyr/kernel.h>
    #include <stdlib.h>
    #include <zephyr/net/socket.h>
    #include <modem/nrf_modem_lib.h>
    #include <zephyr/net/tls_credentials.h>
    #include <modem/lte_lc.h>
    #include <modem/modem_key_mgmt.h>
    #define HTTPS_PORT 443
    #define HTTPS_HOSTNAME "https://************herokuapp.com/api/sensor_reading_https/_"
    #define HTTP_HEAD                                                              \
    	"HEAD / HTTP/1.1\r\n"                                                  \
    	"Host: " HTTPS_HOSTNAME ":443\r\n"                                     \
    	"Connection: close\r\n\r\n"
    #define HTTP_HEAD_LEN (sizeof(HTTP_HEAD) - 1)
    #define HTTP_HDR_END "\r\n\r\n"
    #define RECV_BUF_SIZE 2048
    #define TLS_SEC_TAG 42
    static const char send_buf[] = HTTP_HEAD;
    static char recv_buf[RECV_BUF_SIZE];
    /* Certificate for `example.com` */
    static const char cert[] = {
    	#include "../cert/DigiCertGlobalRootCA.pem"
    BUILD_ASSERT(sizeof(cert) < KB(4), "Certificate too large");
    /* Provision certificate to modem */
    int cert_provision(void)
    	int err;
    	bool exists;
    	int mismatch;
    	/* It may be sufficient for you application to check whether the correct
    	 * certificate is provisioned with a given tag directly using modem_key_mgmt_cmp().
    	 * Here, for the sake of the completeness, we check that a certificate exists
    	 * before comparing it with what we expect it to be.
    	err = modem_key_mgmt_exists(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists);
    	if (err) {
    		printk("Failed to check for certificates err %d\n", err);
    		return err;
    	if (exists) {
    		mismatch = modem_key_mgmt_cmp(TLS_SEC_TAG,
    					      cert, strlen(cert));
    		if (!mismatch) {
    			printk("Certificate match\n");
    			return 0;
    		printk("Certificate mismatch\n");
    		err = modem_key_mgmt_delete(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN);
    		if (err) {
    			printk("Failed to delete existing certificate, err %d\n", err);
    	printk("Provisioning certificate\n");
    	/*  Provision certificate to the modem */
    	err = modem_key_mgmt_write(TLS_SEC_TAG,
    				   cert, sizeof(cert) - 1);
    	if (err) {
    		printk("Failed to provision certificate, err %d\n", err);
    		return err;
    	return 0;
    /* Setup TLS options on a given socket */
    int tls_setup(int fd)
    	int err;
    	int verify;
    	/* Security tag that we have provisioned the certificate with */
    	const sec_tag_t tls_sec_tag[] = {
    		TLS_SEC_TAG,
    #if defined(CONFIG_SAMPLE_TFM_MBEDTLS)
    	err = tls_credential_add(tls_sec_tag[0], TLS_CREDENTIAL_CA_CERTIFICATE, cert, sizeof(cert));
    	if (err) {
    		return err;
    	/* Set up TLS peer verification */
    	enum {
    		NONE = 0,
    		OPTIONAL = 1,
    		REQUIRED = 2,
    	verify = REQUIRED;
    	err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
    	if (err) {
    		printk("Failed to setup peer verification, err %d\n", errno);
    		return err;
    	/* Associate the socket with the security tag
    	 * we have provisioned the certificate with.
    	err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag,
    			 sizeof(tls_sec_tag));
    	if (err) {
    		printk("Failed to setup TLS sec tag, err %d\n", errno);
    		return err;
    	err = setsockopt(fd, SOL_TLS, TLS_HOSTNAME, HTTPS_HOSTNAME, sizeof(HTTPS_HOSTNAME) - 1);
    	if (err) {
    		printk("Failed to setup TLS hostname, err %d\n", errno);
    		return err;
    	return 0;
    void main(void)
    	int err;
    	int fd;
    	char *p;
    	int bytes;
    	size_t off;
    	struct addrinfo *res;
    	struct addrinfo hints = {
    		.ai_family = AF_INET,
    		.ai_socktype = SOCK_STREAM,
    	printk("HTTPS client sample started\n\r");
    #if !defined(CONFIG_SAMPLE_TFM_MBEDTLS)
    	/* Provision certificates before connecting to the LTE network */
    	err = cert_provision();
    	if (err) {
    		return;
    	printk("Waiting for network.. ");
    	err = lte_lc_init_and_connect();
    	if (err) {
    		printk("Failed to connect to the LTE network, err %d\n", err);
    		return;
    	printk("OK\n");
    	err = getaddrinfo(HTTPS_HOSTNAME, NULL, &hints, &res);
    	if (err) {
    		printk("getaddrinfo() failed, err %d\n", errno);
    		return;
    	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTPS_PORT);
    	if (IS_ENABLED(CONFIG_SAMPLE_TFM_MBEDTLS)) {
    		fd = socket(AF_INET, SOCK_STREAM | SOCK_NATIVE_TLS, IPPROTO_TLS_1_2);
    	} else {
    		fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
    	if (fd == -1) {
    		printk("Failed to open socket!\n");
    		goto clean_up;
    	/* Setup TLS socket options */
    	err = tls_setup(fd);
    	if (err) {
    		goto clean_up;
    	printk("Connecting to %s\n", HTTPS_HOSTNAME);
    	err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
    	if (err) {
    		printk("connect() failed, err: %d\n", errno);
    		goto clean_up;
    	off = 0;
    	do {
    		bytes = send(fd, &send_buf[off], HTTP_HEAD_LEN - off, 0);
    		if (bytes < 0) {
    			printk("send() failed, err %d\n", errno);
    			goto clean_up;
    		off += bytes;
    	} while (off < HTTP_HEAD_LEN);
    	printk("Sent %d bytes\n", off);
    	off = 0;
    	do {
    		bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off, 0);
    		if (bytes < 0) {
    			printk("recv() failed, err %d\n", errno);
    			goto clean_up;
    		off += bytes;
    	} while (bytes != 0 /* peer closed connection */);
    	printk("Received %d bytes\n", off);
    	/* Make sure recv_buf is NULL terminated (for safe use with strstr) */
    	if (off < sizeof(recv_buf)) {
    		recv_buf[off] = '\0';
    	} else {
    		recv_buf[sizeof(recv_buf) - 1] = '\0';
    	/* Print HTTP response */
    	p = strstr(recv_buf, "\r\n");
    	if (p) {
    		off = p - recv_buf;
    		recv_buf[off + 1] = '\0';
    		printk("\n>\t %s\n\n", recv_buf);
    	printk("Finished, closing socket.\n");
    clean_up:
    	freeaddrinfo(res);
    	(void)close(fd);
    	lte_lc_power_off();
    please help me to clear this issue ASAP
    Thanks & Regards
    Bhanu
  • Hi Charlie,
    I'm waiting for your response.
    Thanks
  • Hi Bhanu,
    Please check the following points.
    1) Please use the pure HTTPS_HOSTNAME "herokuapp.com". Your local network may not provide DNS, please try with the server IP directly if it still does not work.
    2) Use the send_buf to send something like the below. You also need to change cert[] with CA used by your server domain. I suggest you verify with some REST clients like Postman first to make sure the server side works.
    #define HTTP_REQUEST
    	"POST /api/sensor_reading_https/"                                     \
    	"Host: " HTTPS_HOSTNAME ":80\r\n"                                     \
    Charlie
  • Hi charlie,
    i have used this host name alsoand im getting connect() failed ,err: 111
    our host name doesn't have certificates we are using https with out certificates
    And i have tested the host name in postman application and it working fine that.
    thanks
