Failed to merge MCUBoot(w/ private key) on nRF5340 peripheral_uart sample(NCS 2.2.0)
Dear support team.
I'm trying to merge FOTA on nRF5340 on NCS 2.2.0(VSCode). However, after I flash the code on nRF5340DK, it continuously reboot again and again.
serial monitor(nRF5340)
With nRF52840, it works fine, also FOTA success.
serial monitor(nRF52840)
I think it is some compatibility issues between TFM and MCUboot, even I don't know what the exact points are.
In build configuration, I add bt-overlay.conf which comes from smp_svr sample(and set board as nrf5340dk_cpuapp_ns).
# Allow for large Bluetooth data packets.
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_BUF_ACL_TX_SIZE=502
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
# Enable the Bluetooth mcumgr transport (unauthenticated).
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_BT_AUTHEN=n
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL=y
# Enable the Shell mcumgr transport.
CONFIG_MCUMGR_SMP_SHELL=n
# Enable the mcumgr Packet Reassembly feature over Bluetooth and its configuration dependencies.
# MCUmgr buffer size is optimized to fit one SMP packet divided into five Bluetooth Write Commands,
# transmitted with the maximum possible MTU value: 498 bytes.
CONFIG_MCUMGR_SMP_REASSEMBLY_BT=y
CONFIG_MCUMGR_BUF_SIZE=2475
CONFIG_OS_MGMT_MCUMGR_PARAMS=y
CONFIG_MCUMGR_SMP_WORKQUEUE_STACK_SIZE=4608
# Enable the LittleFS file system.
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
# Enable file system commands
CONFIG_MCUMGR_CMD_FS_MGMT=y
# Enable the storage erase command.
CONFIG_MCUMGR_GRP_ZEPHYR_BASIC=y
CONFIG_MCUMGR_GRP_BASIC_CMD_STORAGE_ERASE=y
# Disable Bluetooth ping support
CONFIG_BT_CTLR_LE_PING=n
# Disable shell commands that are not needed
CONFIG_CLOCK_CONTROL_NRF_SHELL=n
CONFIG_DEVICE_SHELL=n
CONFIG_DEVMEM_SHELL=n
CONFIG_FLASH_SHELL=n # disable shell because it crash with nus
And I modified original prj.conf of peripheral_uart sample.
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=n
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=y # to see all logs in serial monitor
CONFIG_ASSERT=y
#### Below are config for DFU ###
CONFIG_BOOTLOADER_MCUBOOT=y
# Enable mcumgr.
CONFIG_MCUMGR=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# Some command handlers require a large stack.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
CONFIG_MAIN_STACK_SIZE=2048
Here is mcuboot.conf that locate in child_image folder of project.
CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/Users/<my user name>/NCS_V220/ncs220_peripheral_uart_20230202_nrf5340/priv.pem"
and this is modified main.c
#ifdef CONFIG_MCUMGR_CMD_OS_MGMT
#include "os_mgmt/os_mgmt.h"
#ifdef CONFIG_MCUMGR_CMD_IMG_MGMT
#include "img_mgmt/img_mgmt.h"
#ifdef CONFIG_MCUMGR_SMP_BT
#include <zephyr/mgmt/mcumgr/smp_bt.h>
// other uart related function defines(peripheral_uart sample original)
void start_smp_bluetooth(void)
	k_work_init(&advertise_work, advertise);
	/* Enable Bluetooth. */
	int rc = bt_enable(bt_ready);
	if (rc != 0) {
		LOG_ERR("Bluetooth init failed (err %d)", rc);
		return;
	/* Initialize the Bluetooth mcumgr transport. */
	rc = smp_bt_register();
	if (rc != 0) {
		LOG_ERR("smp_bt_register failed (err %d)", rc);
		return;
// omitted
void main(void)
	int blink_status = 0;
	volatile int err = 0;
	configure_gpio();
	err = uart_init();
	if (err) {
		LOG_ERR("Failed to call uart_init() with err %d.\n", err);
		error();
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
		if (err) {
			printk("Failed to register authorization callbacks.\n");
			return;
		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
		if (err) {
			printk("Failed to register authorization info callbacks.\n");
			return;
////// newly added
	os_mgmt_register_group();
	img_mgmt_register_group();
	start_smp_bluetooth();
////// newly added
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_nus_init(&nus_cb);
	if (err) {
		LOG_ERR("Failed to initialize UART service (err: %d)", err);
		return;
	int rc;
	bt_le_adv_stop();
	rc = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
			      ARRAY_SIZE(sd));
	if (rc) {
		LOG_ERR("Advertising failed to start (rc %d)", rc);
		return;
	LOG_INF("Advertising successfully started");
	LOG_INF("build time: " __DATE__ " " __TIME__);
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
Anyone have solved this issue or success to merge MCUboot(w/ private key) on nRF5340?
Best regards
Semin
