Unable to create West Workspace
I've been successfully working with and building applications using the "freestanding" option in VSCode.
However, now comes a time where I want to switch over to a west workspace, so that I can include external libraries (i.e. the anjay sdk for LWM2M), however I'm unable to create even a basic hello world sample. Settings are as following:
After pressing "Create Application" I get the following error in the terminal:
[west]: updating /home/leon/Desktop/ivy/code/ivy-iot/iot/sensor/firmware/workspace/hello_world...
[west]: === updating sdk-nrf (nrf):
[west]: --- sdk-nrf: initializing
[west]: warning: templates not found in /home/leon/ncs/toolchains/v2.1.2/usr/share/git-core/templates
[west]: Initialized empty Git repository in /home/leon/Desktop/ivy/code/ivy-iot/iot/sensor/firmware/workspace/nrf/.git/
[west]: --- sdk-nrf: fetching, need revision v2.2.0
[west]: fatal: unable to find remote helper for 'https'
[west]: FATAL ERROR: command exited with status 128: fetch -f --tags --depth 1 -- https://github.com/nrfconnect/sdk-nrf v2.2.0
[west]: exited with code 128.
I'm running Ubuntu 20.04. Any idea how to fix this? git is already up to date (git version 2.25.1). I can clone any other https repository just fine.
Any idea on how to fix this?
  • Hello Leon,
    I will have to get back to you on this tomorrow.
    I just wanted to say a bit about workspace applications first. Workspace application is a type of application where you will have a dedicated separate copy of the nRF Connect SDK per application. Whereas if you use the freestanding option, you are creating a standalone application that will be linked to an existing copy of the nRF Connect SDK. So it is suitable for a project where it is important to have a full copy of all the files in the project.​
    I am just mentioning this because I believe you can still use the anjay sdk with a freestanding application.
    Elfving
  • Hello again,
    I assume then that you are facing the same issue as you were earlier in this post?
    Like my colleague Naaem suggested, could you try updating the SDK and toolchain? And are you sure you've selected both toolchain and SDK to v2,0.0 when you got the error message you provided? It is searching in the 2.1.2 toolchain, which is a bit interesting.
    Elfving
  • Hi Elfving,
    it's indeed the same issue. I currently have v2.1.2 and v2.2.0 installed, I can try removing the v2.1.2.
    I have also updated the SDK and toolchain.
    ... After removing all other versions, it looks in the v2.2.0 directory, but the error is the same.
    [west]: warning: templates not found in /home/leon/ncs/toolchains/v2.2.0/usr/share/git-core/templates
    [west]: git: 'remote-https' is not a git command. See 'git --help'.
    But you previously also selected both 2.2 for both toolchain and SDK?
    I am not able to reproduce it here.
    Have you tried what is being suggested on this stackoverflow thread?
    Elfving
